Author Topic: Kailh KH switches.  (Read 4023 times)
Offline ideus
  • Björkö.
Kailh KH switches.
« on: Fri, 28 June 2019, 23:46:22 »
I just found the Kailh KH switches family with three types, red, brown and blue. They follow the convention for linear, tactile and clicky, but they appear to have shorter travel. Does anyone have information about them?
http://www.kailh.com/en/Products/Ks/KHS/
« Last Edit: Fri, 28 June 2019, 23:48:56 by ideus »
Offline Hyde
  • White Tofu Extraordinaire
Re: Kailh KH switches.
« Reply #1 on: Sat, 29 June 2019, 21:07:26 »
Upon quick glance it looks like it has the same mounting space/pin location as cherry mx, so my assumption is that it's compatible to any cherry mx pcb but just shorter.
Making it a lot easier to build a keyboard with this and use your existing kits/keycaps.
« Reply #2 on: Sun, 30 June 2019, 07:02:18 »
The "Tesoro Agile" switch in the Tesoro Gram Spectrum could be this switch.
Edit: TaeKeyboards' review, with closeups. They look the same as in the image above.
« Last Edit: Sun, 30 June 2019, 07:16:25 by Findecanor »
Offline ideus
  • Björkö.
« Reply #3 on: Sun, 30 June 2019, 17:08:34 »
I hope that its mounting locations are MX compatible. I may try them for a rebuild of a PCB that I have. Also, I am not sure if these switches may get standard MX caps.
Offline ideus
  • Björkö.
« Reply #4 on: Sun, 30 June 2019, 17:09:08 »
The switches in the video look the same as the KH.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #5 on: Sun, 30 June 2019, 17:11:43 »
Do you know when these switches are released? They look medium profile. They must certainly feel good too.
Just my thoughts
Offline ideus
  • Björkö.
« Reply #6 on: Sun, 30 June 2019, 17:20:37 »
They are available at AliExpress.
I am thinking if I should buy some to try them. Not sure yet though.
Offline pixelpusher
« Reply #7 on: Sun, 30 June 2019, 17:55:47 »
I'd say wait.  If they're any good, mike will stock them on Novelkeys. :)
Offline ideus
  • Björkö.
« Reply #8 on: Sun, 30 June 2019, 17:58:21 »
I will definitely. They aren't cheap.
Offline Sintpinty
    • My Roblox Profile
« Reply #9 on: Tue, 02 July 2019, 15:35:28 »
Ok
Just my thoughts
