Author Topic: Serial numpad in Vista?  (Read 2636 times)
Offline nowsharing
  • Swoop
« on: Fri, 28 May 2010, 14:47:49 »
My RS232 serial bracket finally arrived, and I was expecting to be able to just plug it in to my motherboard and connect my Genovation 623-21 serial number pad, but that doesn't seem to be the case.
I only get a blinking numlock light on it during startup.
Does anyone have experience with this?
Offline EverythingIBM
« Reply #1 on: Fri, 28 May 2010, 15:14:47 »
Try it in windows 98 to see if you get any better results.
Offline ch_123
« Reply #2 on: Fri, 28 May 2010, 15:30:25 »
Damn, I never would have thought of that course of action...
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #3 on: Fri, 28 May 2010, 15:41:58 »
I do remember that Microsoft removed an accessibility feature that let you plug a terminal into your computer's serial port, and use that instead of a keyboard. I think they may have been concerned that this was allowing computers to be accessed in a networked fashion for which they wanted to charge extra.
Offline nowsharing
  • Swoop
« Reply #4 on: Fri, 28 May 2010, 15:41:59 »
It doesn't work in Ubuntu either, so I'm starting to doubt the OS as the source of my problem.
Offline ch_123
« Reply #5 on: Fri, 28 May 2010, 15:44:16 »
Was there any sort of software that accompanied the numpad?
Offline nowsharing
  • Swoop
« Reply #6 on: Fri, 28 May 2010, 15:53:21 »
Good suggestion, I hadn't considered the serial devices need software to operate. I'm getting some strange results from genovation's Keydriver 1.04 program.
If I convert the keystrokes to Macros they work, but send to many keypresses. For example pressing 1 results in 111. I'll mess with this a little and see if I can make it work.
Offline nowsharing
  • Swoop
« Reply #7 on: Fri, 28 May 2010, 15:58:30 »
Got it! Thanks for putting me on the right track ch_123.
Offline nowsharing
  • Swoop
« Reply #8 on: Fri, 28 May 2010, 16:05:21 »
It works with my USB to Serial adapter now too.
Offline ch_123
« Reply #9 on: Fri, 28 May 2010, 16:07:59 »
Catastrophe averted.
It's because the background colour of the boot screen is kinda lavender, isn't it?
