Author Topic: filco blue, brown, or black?  (Read 3647 times)
Offline d-blank
« on: Fri, 28 May 2010, 19:36:35 »
I am looking to get 2nd keyboard, which have different feel compare to the HHKB pro2, any suggestions?
definitely love the pro2, but would like to try something else.
Offline d-blank
« Reply #1 on: Fri, 28 May 2010, 20:19:51 »
easy, easy. can't afford new woman... LOL...
the blue... umm sounds good, it seems like the 10 keyless is more popular than full sized one. any reason?
thanks
Offline elbowglue
« Reply #2 on: Fri, 28 May 2010, 20:35:24 »
Tenkeyless is preferrable unless you use a setup with a raised mouse platform like so:
If your mouse is next to your keyboard on the same surface, you will much prefer a smaller layout keyboard such as the filco tenkeyless which is only 14 inches across.  That is, as long as you won't miss the tenkey section.
Since you already have the HHKB pro I assume you have experienced the joy of a smaller keyboard?
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline muchadoaboutnothing
« Reply #3 on: Fri, 28 May 2010, 23:43:48 »
Quote from: elbowglue;187864
HHKB and Tenkeyless folks can pry my numpad from my COLD DEAD HANDS!
:fencing:
Technically having your mouse on the same level as the keyboard is more ergonomic (at least, from what I've read) but I have a 104 key Filco in the keyboard tray and a mouse above it on the desk and I'm managing fine.
Offline SpatiallyAware
« Reply #4 on: Sat, 29 May 2010, 07:18:24 »
Here's my input:
I started out with a tenkeyless cherry blue and loved it for everything except gaming (it's primary purpose..) So, I traded it for a tenkeyless with blacks.
I hadn't even shipped out my blue board before buying a 104 key with blues (I missed that right enter key, I use it after typing in URLs - also the numpad for addresses and my finance/excel junk)
As soon as my 104 key with blues arrived I ordered a tenkeyless with browns along with a seperate number pad..
So..
In about 1 month I've bought:
tenkeyless blues
tenkeyless blacks
tenkeyless browns (not here yet... arg)
104 key with blues.
I'll probably end up with a unicomp on order before monday, and as soon as I see a lightly used topre at a decent price I'll have one of those too.
Good luck..
« Reply #5 on: Sat, 29 May 2010, 07:19:00 »
Oh, I also would rather have the tenkeyless w/ blues since I've ordered a seperate numpad.. lmk if you want to buy my 104 key w/ blues..
Offline trievalot
« Reply #6 on: Sat, 29 May 2010, 08:54:54 »
im interested.......cost fot freight to AU?
[SIGPIC]
« Reply #7 on: Sat, 29 May 2010, 11:25:07 »
Quote from: trievalot;187968
Last time I shipped int'l it was $$$$$....  And as far as freight, I have no idea.
Offline hyperlinked
« Reply #8 on: Sat, 29 May 2010, 15:19:25 »
The only problem with that approach is that it's kinda like chopping off your tenkey. Your tenkey becomes hard to access since you have to push the mousing platform away first. This got really annoying to me so what I do now when I want my mouse closer is I turn my keyboard tray so that I sit at a slight angle to my monitor. When I need to be closer to the mouse for high precision work, I turn my chair to the right so that I'm lined up straight with my mouse.
When I start typing again, I turn back to the left around 10 degrees.
For casual swipes of the mouse, I don't turn my chair. I just reach for the mouse normally.
Topre: Realforce 103U Cherry: Filco Majestouch 104 (Brown), Ione Scorpius M10 (Blue)
Buckling Spring: IBM Model M1391401 ALPS: Apple Extended Keyboard II (Cream), ABS M1 (Fukka/Black), MicroConnectors Flavored USB (Black)
Domes: Matias Optimizer, Kensington ComfortType, Microsoft Internet Keyboard
Scissors: Apple Full Sized Aluminum
Pointy Stuff: Razer Imperator, Razer Copperhead, DT225 Trackball, Apple Magic Mouse, Logitech MX1000, Apple Mighty Mouse
Systems: MacPro, MacBook Pro, ASUS eeePC netbook, Dell D600 laptop, a small cluster of Linux Web servers
Displays: Apple Cinema Display 30", Apple Cinema Display 23"
Ergo Devices: Zody Chair, Nightingale CXO, Somaform, Theraball, 3M AKT180LE Keyboard Tray
Offline Phaedrus2129
« Reply #9 on: Sun, 30 May 2010, 17:01:26 »
Quote from: muchadoaboutnothing;187903
:fencing:
Hello. My name is Muchadoaboutnothing. You killed my numpad. Prepare to die.
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
« Reply #10 on: Sun, 30 May 2010, 18:05:12 »
Quote from: Phaedrus2129;188333
Offline itlnstln
« Reply #11 on: Mon, 31 May 2010, 15:58:12 »
Damn straight.  I even have an external numpad with my HHKB.  I am not a UNIX programmer.
Offline imsto
    • imsto.cn
« Reply #12 on: Thu, 03 June 2010, 13:27:34 »
get 3 and try to find out which is the suitable...
imsto.cn
imsto's AiKB Taobao Shop
IBM Model M*3, IBM M13,M5, IBM with balls.Cherry   3000  3494 3700 4100*6 700*2 11900 8113 DAS4 TG3 KBC PokerDucky09Ducky1087 apple pink alps Ducky bull,tiger,rabbit,dragon version No:0000002
Offline washuai
    • http://home.earthlink.net/~haruai/
« Reply #13 on: Sat, 05 June 2010, 00:08:58 »
Actually, the trackball reach, because the controller box is to the right of my number pad making my full key keyboard even longer does make my right hand hurt occasionally.  I guess I get to request an ergo eval and I'll ask for a 10keyless and a number pad.  If they'll get me the right mechanical, I'm willing to sacrifice the num pad or plug in the roll up.
Suggestions:  You've got plastic, quiet smoothness.  Get the loudest heavy full sized vintage metal.
« Last Edit: Sat, 05 June 2010, 00:15:06 by washuai »
⌨(home)Realforce 87U ⌨(backup) Filco Majestouch 104 Brown ⌨(backup)Cherry G80-8200LPDUS ⌨(work)Leopold FC200RT/AB
☛CST L-Trac-X ☛Logitech Wireless Optical Trackman ☛ Razer 3500 dpi ☛MS Explorer DeathAdder
Lay-a-bouts:  ⌨Full 109 Key Virtually Indestructable  Keyboard ⌨Compaq Radio Quack GYUR84SK
Wishlist: ⌨KBDmania Pure ⌨Déck 82 ice/frost/toxic/royal ⌨Ricercar spos G86-62410EUAGSA ☠ ✞⌨miniGuru(s) ☠
 ✐Intuos or Cintiq
Offline Rusty Rat
« Reply #14 on: Sun, 06 June 2010, 07:03:59 »
Hi all, some advice and knowledge please. I have been reading all the topics on the Cherry Blue vs Brown. I am about press the button on a Filco Tenkeyless.  This is to temporarily replace a proper keyboard (Model M) for the desktop and to fit into my notebook bag. So the blues are tactile and clicky and the browns are tactile but not clicky which means more chance of bottoming out. From a subjective point of view can anybody tell me how the actual noise on the Filco Blue compares with their own Model M. ‘ripster’ describes the blues like dominoes clicking. Is this a much sharper noise or louder noise than the semi baritone of a Model M and is it annoying? It would seem that the clicky blues would be closer to BS technology in noise and feel albeit with less pressure required. Am I on the right track here?
I am in Australia so keyboard shipping from the US requires a bank loan bigger than a Wall street analysts annual salary. We now have a distributor for Filco down under and a Filco Tenkeyless is A$176 delivered which on current exchange rates is about US$146 which I think is pretty reasonable.
Offline Mental Hobbit
« Reply #15 on: Sun, 06 June 2010, 10:41:34 »
Quote from: Rusty Rat;190154
It's not louder, but it's a much sharper sound. I like the sharp click and find the spring ping of Ms annoying, but that's a matter of personal preference.
Yes.
Typing on blues.
« Reply #16 on: Sun, 06 June 2010, 10:48:32 »
Quote from: ripster;190178
Sounds like this...
I find the sound on this video very inaccurate. I hear no spring ping on the Unicomp. I hear no click on the DAS, just the sound of thin keycaps bottoming out. Only the browns seem right to me.
« Last Edit: Sun, 06 June 2010, 11:38:28 by Mental Hobbit »
Typing on blues.
