Author Topic: Replacing MX switches  (Read 1571 times)
Offline filcomanfilthy
« on: Sun, 14 July 2019, 09:06:50 »
Code: [Select]
I am buying vintage mx blacks but im not sure how to take off the switches and put new ones on. Does anyone know a good guide?
Filthy
Offline Venaros
Re: Replacing MX switches
« Reply #1 on: Tue, 16 July 2019, 08:56:02 »
You'll need to desolder and solder if your board isn't hotswap. If it is hotswap, you just pull out the existing switches with a tool and put the new ones in; you may need to clip the plastic legs though.
« Last Edit: Tue, 16 July 2019, 08:57:49 by Venaros »
