Author Topic: Cherry g80-3000lscrc-2 (MX blue) in stock at Gemini!  (Read 12381 times)
Offline ruumis
« on: Sat, 29 May 2010, 15:16:19 »
I know there's always considerable demand for these here at geekhack, so let the ordering frenzy begin!! $66.25 with free UPS ground!
______________________
IBM Model M (82G2383) | IBM Model M (51G8572) | Apple Extended Keyboard 1 (M0115) | ABS M1 (x2) | Dell AT101W white | Dell QuietKey RT7D5JTW black | Cherry G80-3000LSCRC-2 w/double-shots from a G81-8000HPBUS-2 / 03
Offline elbowglue
« Reply #1 on: Sat, 29 May 2010, 15:31:40 »
Nice find! no shipping or tax for me!
Does anyone know where the controller sits on this keyboard?  Is it under the caps lock / numlock led?  I am thinking about getting one of these and taking a hacksaw to it, but I think the controller location might make it tricky..
And I gave away my old g80-3000lscrc already :P
« Last Edit: Sat, 29 May 2010, 15:55:12 by elbowglue »
My keyboards: Filco Cherry Blue Tenkeyless(daily home), Compaq MX11800 (modded to blacks), Compaq "MX 84u",  Wellington\'s Dampened Endurapro, Pinkalicious Filco Blue Cherry, Chicony KB-5191, Chicony KB-5181, Desko MOS 5023 UP "elbowglue" spos (modded to blues), Siig Minitouch (monterey blue), SMK-88 (blue cherries), Ricercar SPOS
Smallest to biggest keyboards in inches (Length X Height) - Length is most important for a midline mouse position
KBC Poker: 11.6 x 3.9 - HHKB: 11.6 x 4.3 - Siig Minitouch (Geekhack Space Saver): 11.6 x 6 - Deck/Tg3 82: 12 x 6 - Noppoo Choc Mini 12.4 x 5.3 - Compaq "MX 84u": 13.1 x 7.5 - Filco Tenkeyless: 14 x 5.3 - Cherry "ricercar spos" G86-62410EUAGSA: 14 x 7.75 - Topre Realforce 86u: 14.4 x 6.65 - Desko "elbowglue spos" MOS 5023 UP: 14.5 x 8.4 - IBM Model M Spacesaver: 15.3 x 7 - G80-1800: 15.9 x 7.1 - Adesso MKB-125B: 16 x 7.3 - Compaq Mx11800, Cherry G80-11900: 16.25 x 7.5 - Filco Standard: 17.3 x 5.4 - Unicomp Endurapro: 17.9 x 7.1 - Adesso MKB-135B: 18.3 x 6.0 - Cherry G80-3000: 18.5 x 7.6 - IBM Model M, Unicomp Customizer: 19.3 x 8.27
Offline ruumis
« Reply #2 on: Sat, 29 May 2010, 16:05:46 »
Quote from: elbowglue;188040
I believe I saw it there while doing the double-shot key swap. But I can't be 100% certain, so take what I say with a grain of salt.
Also, this board is a lot more pleasant to type on after doing the swap. No more unpleasant scratchy feeling from the laser etching. If I had another donor board waiting in the wings, I'd order a second one right now!
Offline (X "_____")
« Reply #3 on: Sat, 29 May 2010, 16:11:57 »
If it's the same as mine, which I assume it is as they're both made recently, the controller is right under the lock LEDs and you'll need quite a lot of wires if you want to hack off the numpad. I think I ended up with 30-40 wires after cutting off the alphanumeric part of mine, though I think I probably could have cut the number down to the high twenties, and you'll need slightly fewer wires if you just remove the numberpad.
Offline grilkip
« Reply #4 on: Sat, 29 May 2010, 16:43:27 »
What the fudge? The cheapest air shipping is $140. I'm in Europe :(.
Filco tenkeyless (browns) - IBM Model M - Cherry G80-3000LSCEU (blues) Das Prof. S (blues)
ANSI FTW
Offline Phaedrus2129
« Reply #5 on: Sat, 29 May 2010, 16:51:40 »
Are these MX blues, browns, what?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline grilkip
« Reply #6 on: Sat, 29 May 2010, 16:56:46 »
Blues
ANSI FTW
Offline grilkip
« Reply #7 on: Sat, 29 May 2010, 16:59:06 »
I ordered one and selected ground, let's see how that goes.
ANSI FTW
Offline ruumis
« Reply #8 on: Sat, 29 May 2010, 21:05:10 »
Quote from: Phaedrus2129;188059
it's right there in the title of the thread, mate.
Offline Henry
« Reply #9 on: Sat, 29 May 2010, 21:06:22 »
Quote from: grilkip;188062
Unless you want the Chinese letterings for some reason, you should rather look for a g80-3000lsceu. I know that they are in short supply in Europe, but I'm pretty sure you'd be able to find a German online shop willing to order one for you. They're usually sold for under 60€.
Offline Tr0j4nM4x1mus
« Reply #10 on: Sun, 30 May 2010, 00:19:19 »
looks like they have a few again also
Keyboards - 4 Cherry G80-3000lscrc-2 (two with black DS keys one with black & white DS keys)
HHKB Professional white
2 ABS M1 (modded with complicated alps one with pinks & one with rubber bumper whites)
2 IBM Model M\'s one 89 & one 97
Dell AT-101W black (modded with rubber bumper whites- M1 keys)
Focus FK2001 with cover
Focus FK2000 with cover
Unicomp Model M black mighty mouse
Cherry G84-4100 white
Looking For - Compaq G80-1838
Offline firegun9
« Reply #11 on: Sun, 30 May 2010, 03:10:41 »
Don't consider the Chinese layout, is this any different from Filco tenkeyless with blue switches?
Offline ch_123
« Reply #12 on: Sun, 30 May 2010, 03:46:04 »
They use PCB mounted switches instead of plate mounted ones. Some prefer one over the other for various reasons.
Offline grilkip
« Reply #13 on: Sun, 30 May 2010, 04:12:18 »
Quote from: Henry;188101
The lettering would bother me less than the iso layout would.
ANSI FTW
Offline Henry
« Reply #14 on: Sun, 30 May 2010, 05:25:54 »
EU stands for QWERTY US (i.e. 104 keys ANSI layout) with € symbol on the 5 key.
Offline Mental Hobbit
« Reply #15 on: Sun, 30 May 2010, 05:52:29 »
Quote from: grilkip;188056
Uhm?
Typing on blues.
Offline grilkip
« Reply #16 on: Sun, 30 May 2010, 06:06:50 »
Quote from: Mental Hobbit;188166
Uhm?
Thanks, I was just looking at one of the mentioned sites.
ANSI FTW
Offline audioave10
« Reply #17 on: Wed, 02 June 2010, 00:59:50 »
I just checked this site and they are still in stock. I ordered one. Can't wait.
$66.25 total shipped...not bad.
« Last Edit: Thu, 03 June 2010, 21:44:01 by audioave10 »
DECK Legend "Toxic" - SOLD
96 IBM Model M 82G2383- 95 IBM Model M 92G7453 - SOLD
Cherry G80-3000/Blues
new: MechanicalEagle Z77 RGB/Blues
Offline Oqsy
« Reply #18 on: Wed, 02 June 2010, 21:24:19 »
what exactly is meant by USB-PS/2 combo?  is it natively PS/2 with included adapter?  I'm looking for a USB board for work, and this would really work nicely since I've been wanting a blue board anyway.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
« Reply #19 on: Wed, 02 June 2010, 21:48:50 »
native usb - comes with usb to ps2 adapter
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #20 on: Wed, 02 June 2010, 22:02:53 »
Specifically, comes with and works with a passive adapter, because the keyboard controller itself is compatible with either interface electronically.
kishy.ca
Offline Oqsy
« Reply #21 on: Wed, 02 June 2010, 22:09:28 »
thanks folks, exactly what I wanted to know :D
Offline audioave10
« Reply #22 on: Thu, 03 June 2010, 11:54:41 »
Mine is here already. Very well packaged in a huge box. Feels very nice but I have to go to work so I'll put up some pictures later.
Edit: It shows them still in stock.
« Last Edit: Thu, 03 June 2010, 12:23:53 by audioave10 »
Offline eyesonly
« Reply #23 on: Thu, 03 June 2010, 14:11:20 »
Chinese lettering on the board or not?
Offline audioave10
« Reply #24 on: Thu, 03 June 2010, 21:27:51 »
Yes, but I don't mind. I'm sitting here (this morning) wondering why I don't yet have the E-mail confirmation that I'm to recieve from GeminiComputers.com and the doorbell rings...its UPS with the package already. Seems they have a warehouse in MS. which is close to me.
Pics are hard to take with that shiny surface...
I would describe the clicky as (high-pitched but not overly loud) and for me takes only a light touch.
I like very much. I can see where you can type with this and not bottom out. I sure can't do it yet.
« Last Edit: Thu, 03 June 2010, 21:34:39 by audioave10 »
« Reply #25 on: Thu, 03 June 2010, 21:44:54 »
Out of stock. :(
Offline audioave10
« Reply #26 on: Thu, 03 June 2010, 21:54:34 »
Wow, they don't last long.
Offline ruumis
« Reply #27 on: Fri, 04 June 2010, 06:23:31 »
Quote from: Phaedrus2129;189409
Out of stock. :(
that's why I post about it whenever I see these in stock.... they never last. don't wait so long next time :bolt:
Offline elbowglue
« Reply #28 on: Fri, 04 June 2010, 12:28:04 »
Dude the best part about this keyboard is the switch under the spacebar.  It is dreamy.
If I could get a whole keyboard made of cherry greens I would be so pumped.
When this keyboard comes in stock guys, just buy it.  Like buy 2 of them.  It's a no brainer.  Except for in my case in which my wife would decapitate me if I did that, then it would really be a no brainer.
Offline Oqsy
« Reply #29 on: Fri, 04 June 2010, 19:49:46 »
damn missed the boat.
