Author Topic: Suggestions for an 80% Kit  (Read 7020 times)
Offline liquidvel
« on: Sat, 20 July 2019, 01:48:32 »
Hi,
I'm looking for a good 80% Kit. The KBD8x (ANSI) seemed reasonable but is out of stock.
Do you guys know any other manufacturers or active group buys which sell 80% sets at a reasonable price (< 250 Euro).
Greets
Offline rxc92
Re: Suggestions for an 80% Kit
« Reply #1 on: Sat, 20 July 2019, 03:03:00 »
What are you looking for, first off?
Offline actualglacier
  • ¯\_(ツ)_/¯
« Reply #2 on: Sat, 20 July 2019, 05:25:47 »
I don't think there's an active group buy for a TKL right now, but I can tell you it's hard to beat the kbd8x's quality for that price. I think you should wait a bit.
actualglacier on youtube
Offline liquidvel
« Reply #3 on: Tue, 23 July 2019, 12:38:14 »
I want to build a 80% keyboard for max. 250$. I don't mind soldering but I've read you can mod any PCB to make it hotswappable. Is this true?
I've found the XD87 The price seems OK, I don't know if it is any good?
Offline tydlwav
« Reply #4 on: Tue, 23 July 2019, 20:41:20 »
If you're not looking to build, you can look at Drop CTRL and Hexgears Dusk/Dawn. They're pretty cheap for what they can do.
Offline liquidvel
« Reply #5 on: Wed, 24 July 2019, 09:02:50 »
I want to build my own.
Offline rxc92
« Reply #6 on: Wed, 24 July 2019, 09:18:38 »
Hmm, what are some other features?
e.g. weight; do you like a very heavy metal keyboard (3+ kilos)? In terms of angle, do you like an inbuilt positive (closer end lower) or negative (closer end higher) tilt? What sort of layout do you like; if you like 60% or in between it and TKL, what sort fits your uses and aesthetics? If you're getting a TKL, it's a moot point however. Are you a fan of keyboard lighting? You can get one with a diffuser (lit on the PCB itself, with a translucent piece inside the case to show off the lighting better) or per-key LEDs, and even both. It'll be much easier for you to find your ideal keyboard (or at least one you're eager to try out) if you know what you want.
For me, I got a keyboard from KBDfans; they sell the kits as well as assembly services. Their prices are very reasonable for the quality they offer (~$200 or less for aluminum cases+brass weights and diffuser/backlighting, as well as a huge variety of switches), so I'll vouch for them.
Offline OnceS
« Reply #7 on: Sat, 27 July 2019, 01:54:22 »
The KBD8X is now regularly available on KBDFans. Surely a great pick up.
E6 | Kira60 | R60 | HHKB Carbon
IG: https://www.instagram.com/onces1314/
Offline EMC Labs
« Reply #8 on: Sat, 27 July 2019, 05:54:09 »
Totally agree with you. Although, when is the next restock, if you know?
Offline HungerMechanic
« Reply #9 on: Sat, 27 July 2019, 11:15:17 »
The KBD8x mkii (R1) will ship in early August. At that point, the extras will be made available for purchase. They will go quickly, and then you will have to wait for the next GB.
[I shouldn't be telling you this, because I will be competing with you for the extras.  ;D]
Offline EMC Labs
« Reply #10 on: Sat, 27 July 2019, 21:08:25 »
Haha, thanks for letting me know.
Offline eniigma
    • Storefront:
« Reply #11 on: Fri, 09 August 2019, 10:32:25 »
If you're okay with an integrated plate and are looking for some budget options, I think there are a few TKL groupbuys that are going to open soon that are under $200.
Sent from my SM-G973U using Tapatalk
Offline liquidvel
« Reply #12 on: Sat, 14 September 2019, 12:31:46 »
Well I bought the XD87 HS PCB a few weeks ago. The PCB looks nice.
I also bought the stainless steel case with acrylic diffusor and I regret it. It looked like a regular case with acrylic bottom. But the case is not fully enclosed. The sides are totally open and the acrylic plate does not cover the whole bottom or even stands on it. Imo the picture does not show this clearly. Now I have the PCB and can't even use it.  :( Will never buy cheap again!
Are there any updates on TKL boards/group buys?
Offline eniigma
    • Storefront:
« Reply #13 on: Sun, 15 September 2019, 16:51:32 »
If you are EU, the CU80 is currently running which also support ISO and hotswap.
Offline Adelscott
« Reply #14 on: Sun, 15 September 2019, 18:34:02 »
CU80 is weird.The rear foot is way too short.
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline woodruff
« Reply #15 on: Mon, 16 September 2019, 09:09:30 »
That's peculiar, I didn't notice it
After the gh60, a new gh80 is the only solution:
https://geekhack.org/index.php?topic=102444.0
