Author Topic: [IC] Aristotle 2.0 stems (pre-sale closes 7/31/19)  (Read 5144 times)
Offline mounds
  • Builder of things and stuff
    • The Mounds Abides
« on: Sun, 21 July 2019, 18:32:28 »
Hey folks, didn't see this around Geekhack, but figured some would be interested in this: https://www.reddit.com/r/mechmarket/comments/cfcb3h/ic_repost_aristotle_20_update_finally/
Looking to pick up a substantial lot myself once the testers clear them. There's a review of some of the pitfalls of the NOS/OG stems for those unfamiliar! I hope for better tolerances from newer mfg methods  :thumb:
Tada68 (Jailhouse Aristotles) / MiniVan (Jailhouse Aristotles) / Planck (Aristotles) / Teensy m0116 (Matias QC) / ALPS64 ('Pine' SKCM White) / Teensy NeXT Non-ADB (SKCM Cream) / ALPS HHKB (SKCM Orange)
Offline vosechu
Re: [IC] Aristotle 2.0 stems (pre-sale closes 7/31/19)
« Reply #1 on: Sun, 21 July 2019, 18:39:07 »
Thanks! I totally missed this and absolutely want some. Well caught!
Offline equalunique
« Reply #2 on: Sun, 21 July 2019, 21:39:32 »
Will def join
I wanna try these with the jailhouse mod
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline sl70309
« Reply #3 on: Sun, 21 July 2019, 22:11:22 »
will the stem crack the hole of keycaps?
« Last Edit: Sun, 21 July 2019, 22:17:21 by sl70309 »
Offline Tom_Kazansky
  • Oblivion Knight
« Reply #4 on: Sun, 21 July 2019, 23:08:17 »
I already have signed up for 300 ;D
the "old" Aristotle stem is too loose for some keyscaps, you can take the cap off with pretty much no efforts.
the Aristotle 2.0 stem should be well-fit. (the IC runner mentioned about fixing the stem issue)
« Reply #5 on: Mon, 22 July 2019, 00:43:56 »
Wow, thanks! Signed up! I have some I'm going to use in my Tris, but I'd be interested in checking these.
Plus, it's heroinbob. Can never go wrong with that guy.
Offline mounds
    • The Mounds Abides
« Reply #6 on: Fri, 26 July 2019, 18:13:17 »
No problem!
People seem really pleased by his other products, so I'm hopeful for this redux
