Author Topic: Do you use mechanical keyboards at work? If so, what switch?  (Read 18769 times)
Offline Surefoot
Re: Do you use mechanical keyboards at work? If so, what switch?
« Reply #50 on: Mon, 30 September 2019, 03:44:10 »
Yes. At the moment, KBD75v2 with lubed Healios. Going for a rotation with Gat Ink Black Silents.
Offline _PixelNinja
  • C=Q/V=ε(A/t)
« Reply #51 on: Mon, 30 September 2019, 03:53:49 »
I alternate between Ergo Clears, Zilent V2s and Topre.
Offline killyou
« Reply #52 on: Mon, 30 September 2019, 04:09:12 »
I work from home but twice a year I have to appear in the office for 3 weeks and I do that equipped with my trusty Vortex Pok3r loaded with Zealios/Kailh BOX Reds. My choice would be Kailh BOX Pinks for typing but I don't want to piss people off. There is no real opposition agains mech keyboards, I converted two of my coworkers and doing the work on the rest of them so we can throw out HP crap away.
Offline ideus
  • Björkö.
« Reply #53 on: Mon, 30 September 2019, 09:37:20 »
My own version of Ergo Clears with original Cherry base and Gateron's tops. 55g springs.
Offline funderburker
« Reply #54 on: Mon, 30 September 2019, 10:05:03 »
Used modded MX Silent Blacks previously with a neoprene foam and was quieter than other rubber domes around the office. Now I'm using MX Blacks and haven't heard anyone complaining. It sounds so good though so why would they?
Keyboard design by Skepur
Offline L0rdN1k0n
« Reply #55 on: Mon, 30 September 2019, 12:48:44 »
I use my old Corsair Vengeance K70 with Cherry MX Browns + o-rings. Hoping it'll get stolen or die eventually so I can justify replacing it. Unfortunately it's been pretty rock solid although I loathe the non-standard keycap set that I can't replace.
Nobody cares about the noise, even before the o-rings. Honestly if you really jam on a membrane keyboard it can be just as loud or louder.
Ducky One 2 Horizon full-size Cherry MX brown /w Tai-Hao Midnight Dawn ABS
Cooler Master CK550 full-size Gateron blue /w Tai-Hao blood red/black PBT and Dota 2 Juggernaut aluminium artisan
Compaq RT101 full-size WKL NMB dome /w slider
Dell QuietKey RT7D5JTW full-size NMB dome /w slider
Offline Bawsky
  • Give Deathcaps pls
« Reply #56 on: Mon, 30 September 2019, 16:12:07 »
I use a lot of loud switches to I try to spare my coworkers from that.
Offline Darksair
    • My Homepage
« Reply #57 on: Mon, 30 September 2019, 17:44:34 »
Topre Type Heaven. It’s about as loud as the Dells and Lenovos others are using.
What amazes me the most is although it has ABS keycaps, it’s retaining the texture pretty well after 3 years.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #58 on: Mon, 30 September 2019, 17:54:55 »
Just some random HP membrane. It hurts but not allowed to have our own stuff  :confused:
If i'm ever in a cubicle job i will bring in my mech keeb - that is with silent switches so that way everyone doesn't have to hate me.
Just my thoughts
« Reply #59 on: Mon, 30 September 2019, 18:18:09 »
I had my JD40 with jailhoused MX blues (skeleton case means they're still quite loud) alongside my hot-glue numberpad with MX blacks for a while when I last worked in an office, people complained when they had to use my computer but were fine with the noise of me using them.
Offline frydaja
  • "It's my last keyboard, I swear"
« Reply #60 on: Tue, 01 October 2019, 07:54:38 »
I just bring my QF TK and another cable. The keyboard is filled with shelf liner, so it is somewhat quiet. It's not that much louder, but the noise from MX Browns is much sharper than from a HP rubber-dome (PR1101u, my arch-nemesis).
Anne Pro 2 w/ Kailh Box Browns | CM Storm Quickfire TK Stealth w/ MX Browns | Unknown Chinese keyboard w/ Outemu Reds | Compaq-branded NMB RT101 | Gigabyte Force K81 w/Kailh Reds
Offline Kavik
« Reply #61 on: Tue, 01 October 2019, 10:57:26 »
When I had my own office, I used MX Blues, Matias Clickies, and a Model M.
Now that I'm in a shared area, I've used Box Royals, Kailh choc clickies (not very loud), Outemu Browns, MX Reds, Zealios, and rubber domes. I used a Model M for a month or two, but I took it home because I felt self-conscious. No one complained, but one coworker joked about it once, and the rest of them are probably just too nice to have said anything.
Offline shadowku
« Reply #62 on: Tue, 01 October 2019, 14:16:27 »
I use Topre. At first, I had hypersphere'd Topre which was definitely the quietest keyboard I've ever tried - quieter than the Apple chiclet keyboards that everyone else around me was using. Then I changed the domes to BKE lights which made the keyboard a louder but is still okay.
HHKB Pro2      FC660C
Offline mizzoperator
  • "This can't be good for me, but I feel great!"
    • Milk Time: The Mizz Domain
« Reply #63 on: Tue, 01 October 2019, 14:27:10 »
I'm technically in an educational environment, but I'm gonna count it as work.
The one time I attempted to use a mech (which was an Eagletec KG010 with Outemu Blues, please forgive me), people got sick of it after approximately three minutes of typing. I was forced to switch back to a bog-standard Dell rubber dome keyboard, which feels alright to type on, but is nonetheless still kind of mushy and stiff.
Linears are for linear people. No offense if you use linears.
I prefer tactile switches, I'm reluctantly using the AULA SI-859 and my pronouns are she/her.
Offline Fate
« Reply #64 on: Wed, 02 October 2019, 07:29:34 »
I use one of my Stand Asides with BOX Ancient Grays, since I'm in an open-plan office. It's quieter than a membrane board, and lets me use my physical layout.
Offline NoPunIn10Did
    • NoPunIn10Key
« Reply #65 on: Wed, 02 October 2019, 08:19:57 »
Either some silent/linear switches or some tactile switches with dampeners should allow you to use something better.
« Reply #66 on: Wed, 02 October 2019, 08:21:41 »
That's a good point. Tactile switches with dampeners would probably be the best, because silent/linear switches make my face hurt.
Offline Stupidface
  • Lifelong edge use case
« Reply #67 on: Wed, 02 October 2019, 08:45:49 »
What exactly IS that thing?
It is the theoretical great-great-grandfather of the computer on your desk: Charles Babbage's Difference Engine No. 2.
If you are curious, you can find a general overview of it here:
https://science.howstuffworks.com/innovation/inventions/who-invented-the-computer.htm
Whilst a near cog-by-cog animated explanation of the far more ambitious Analytical Engine by the wondrous Sydney Padua can be found here:
https://sydneypadua.com/2dgoggles/the-marvellous-analytical-engine-how-it-works/
I was not acquainted with Sydney Padua or her work until I set about writing my reply.  I am grateful to you for your query because, without it, I would likely have remained forever so.  That would have been a great pity because, once I understood just what it was that Babbage was seeking to do with his Analytical Engine, it evoked a sense of awe and wonder that I have not felt for some time.
It truly was one of the great might-have-beens of history.
Offline phinix
« Reply #68 on: Wed, 09 October 2019, 07:14:46 »
Topre, RF most of the time. But I tend to swap them once a week, bringing other ones. Most of keyboards are Topre, so its either plain RF, Novatouched RF or NT. Then sometimes I bring my Tealios.
Offline kagamineryuki
« Reply #69 on: Wed, 09 October 2019, 07:59:30 »
KBP V60 White Fukka.
Although, I type on it below my desk so the sound isn't resonating inside my office and a bit dampened ;D
Offline nickheller
  • Cherry ML life
    • hickneller.com
« Reply #70 on: Wed, 09 October 2019, 09:17:44 »
Tealios and vintage blacks.
« Reply #71 on: Wed, 09 October 2019, 09:44:35 »
Do you use them while skateboarding around the office?
Offline ergonaut
« Reply #72 on: Thu, 10 October 2019, 03:19:19 »
Cherry MX Browns on a Kinesis Advantage. No complaints yet. My colleagues mostly type on those Apple Butterfly keyboards, which aren't exactly silent either.
I'm pondering getting Kailh Box Whites for my next keyboard, maybe those might be too loud?
Offline yui
« Reply #73 on: Thu, 10 October 2019, 05:05:49 »
Unicomp PC122, or office being in the middle of a noisy workshop no ones complains, and it is not louder than mouse clicks.
Offline Sintpinty
    • My Roblox Profile
« Reply #74 on: Thu, 10 October 2019, 08:00:42 »
Using Ergo Clears at work with this guy:
really nice keyboard at work
Just my thoughts
Offline Sintpinty
    • My Roblox Profile
« Reply #75 on: Thu, 10 October 2019, 08:02:07 »
My keyboard, although TKL size would simply not work with the computers i have at school. They're too old.
You may already have thought of this, but just in case: have you considered starting a new thread giving the makes/models of the computers and the make/model of the keyboard you would like to use on them?
I would be very surprised, indeed, if someone on GH could not contrive a way for you to use the keyboard you enjoy with the computers with which you are stuck.
I only wish I had something to offer in the way of practical advice.  However, my own formative computing years were spent cranking away* on one of these:
...and keyboards did not enter the picture until much later, alas.
*When I say, "cranking away," I am not speaking in a metaphorical sense.
Are you from the 1890s or something?
Just my thoughts
Offline Greko
« Reply #76 on: Thu, 10 October 2019, 09:31:20 »
Holy Pandas, lubed Gateron Yellow and Topre 55g.  I rotate between them. No noise complaints  ;D
IBM Model M White Label | Leopold FC750R | GMMK TKL | Realforce 87U 55G | Matias Mini Quiet Pro
Offline yuppie
« Reply #77 on: Thu, 10 October 2019, 10:59:12 »
Mainly using a Canoe with MX Zilent Blacks. Pretty quiet and smooth. Lately I switched up to my FC660C, modded with purple sliders and lubed.
In an open office layout, staying quiet is the best bet.
"Overall, it's a good community..  wish you well on your Pokemon Journey.." - TP4
Current Trades -- Wishlist
Offline Olumin
  • "Guy walks into a doctor's office..."
« Reply #78 on: Thu, 10 October 2019, 18:06:22 »
Well I currently work as a Watchmaker, so not many keyboards there.
But previously to that I used a Model M at work. I wanted to use a F, but didn't want to risk bringing it to work.
So that would be buckling springs to adress your question directly.
Also tried Topre for a while at work.
Offline eksuen
  • Ambassador of explosions.
« Reply #79 on: Thu, 10 October 2019, 22:11:57 »
I do use a mechanical keyboard at work. Currently, my work board is a Rama M65-A with Holy Pandas. I change it up every couple of months or so.
Offline gingerjack
« Reply #80 on: Thu, 10 October 2019, 22:45:10 »
About 1 1/2 years back got myself a Gamdias Mechanical Keyboard. Absolutely fantastic to use, key pressing, response time, durability is all there. Will never go back.
My work PC has a Tesoro Mechanical keyboard, still will not trade for anything else. Productivity is smooth as.
Offline Sintpinty
    • My Roblox Profile
« Reply #81 on: Fri, 11 October 2019, 05:36:57 »
Wow interesting
Just my thoughts
Offline Whale_algorithm
« Reply #82 on: Sun, 13 October 2019, 11:58:30 »
I use silenced topre at work. Haven’t had an issue. A few people use browns and they are noticeably louder but manageable.
