Author Topic: [IC] Alpha65 - Gasket Mounted 65% (Project Retired)  (Read 47560 times)
Offline Esheu2
Re: [IC] Alpha65 - Gasket Mounted 65% (Design Revised and new Prototypes arrived)
« Reply #100 on: Tue, 19 January 2021, 15:44:18 »
very nice !! i'm interested
btw could you describe the typing feel for me? rigid, or soft?
and why do you choose aluminum 5052 instead of 6063 or 6061?
many thanks
The current build I have is using Alpacas on an FR4 half plate. Overall typing feel is very soft without being bouncy.
5052 just because it was recommended to me for use in the Fallacy and I'm just continuing to use it. Both 6063 and 5052 are easier to do colored anodized finishes than 6061.
Ojou
