Author Topic: Any mods to remove wobbling?  (Read 11921 times)
Offline cassiozen
« on: Tue, 23 July 2019, 17:17:43 »
I have a bunch of leftover Cherry Clear switches that I want to use on a build (and since it will be my first build, I will use what I already have at hand).
Compared to my current keyboard (Zilents) I find the Clears very wobbly - Are there any mods or hacks to improve this? I already plan to disassemble them to lube...
Offline nevin
Re: Any mods to remove wobbling?
« Reply #1 on: Tue, 23 July 2019, 17:26:37 »
depending on age, switch films can help. your results may vary
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #2 on: Tue, 23 July 2019, 17:27:17 »
https://txkeyboards.com/en/products/switch-films-detail
Place these on the bottom housing before you close each switch after modding.
Offline cassiozen
« Reply #3 on: Tue, 23 July 2019, 17:31:42 »
Switch films sound good, but the stem itself has a lot of wobble - any way to improve that?
Offline equalunique
« Reply #4 on: Tue, 23 July 2019, 18:36:32 »
Short of a different switch housing, there isn't much you can do.
Lubing all around the sliders will help at least with the *sound of* switch wobble.
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Online Findecanor
« Reply #5 on: Tue, 23 July 2019, 18:41:21 »
There has also been the self-adhesive variety: "switch stickers", "sticker modding".
