Author Topic: Need full-size, flat board with spherical caps  (Read 3314 times)
Offline nikk
« on: Wed, 24 July 2019, 15:18:22 »
Newbie here. Just starting to learn the lingo but I already have strong preferences for a keyboard. Can you help me find it?
Must have:
Full-size with dedicated media keys
Flat-profile, no slope (tilt) or very little -- I want flat, flat, flat!
Tactile bump switches
Really hope to have:
Spherical caps
RGB (because I really love orange back-lighting)
Thanks for any help.
Offline rxc92
Re: Need full-size, flat board with spherical caps
« Reply #1 on: Wed, 24 July 2019, 15:26:01 »
I W A N T I T I N E E D I T
Offline sncbraxsc2
  • ⭐Domesticated Dweeb⭐
« Reply #2 on: Wed, 24 July 2019, 15:41:20 »
I don't think any fullsize board comes with sphericals. You may want to find what you're looking for in a board first and get the sphericals separately
Offline chive_
« Reply #3 on: Wed, 24 July 2019, 20:40:06 »
Agreed. You'd be best finding a keyboard you like and then buying the keycaps later, you'll be able to get the most customized experience that way! Are you considering building at all, or do you want a pre-built keyboard?
Offline nikk
« Reply #4 on: Wed, 24 July 2019, 22:05:00 »
Thanks guys. Yes, I am definitely open to buying a board and changing the caps. Don't want to get into any complex build though.
So, I need two recommendations, full-size flat boards and and spherical caps!
I guess that I should have asked first if this was even a realistic thing to do, or is it just stupid?
Offline chive_
« Reply #5 on: Thu, 25 July 2019, 00:00:02 »
So, for keycaps on the more budget-friendly side I'd recommend checking out KBDFans for something. If you're looking for the flattest profile possible (DSA), this may be down your alley: https://kbdfans.com/collections/keycaps/products/dsa-pbt-145keys-keycaps-laser-etched-front-printed-legends
As for keyboards, since you're looking for a full-size pre-built with tactile keys and no slant to it, I'm going to have to default to someone else a bit more experience in full-size options out there. Good luck though! I'm sure there are Corsair keyboards with media controls that may work, not sure about the angle of the boards though.
Offline nikk
« Reply #6 on: Thu, 25 July 2019, 00:37:09 »
Thanks for the key cap link, Chive.
Corsair makes a low-profile board now, the K70 RGB MK.2 Low Profile, but the problem with Corsair is that they have a non-standard bottom row, so replacing the key caps is a no-go.
Offline Surefoot
« Reply #7 on: Thu, 25 July 2019, 03:29:46 »
A GMMK or one of the chinese knock-offs with hotswap switches might be the solution here. They are flat, you can put whatever switch in them (GMMK only allows plate-mount switches though), and whatever keycaps (you can buy DSA, XDA, XDAS... separately).
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #8 on: Thu, 25 July 2019, 09:13:20 »
hehe same
Just my thoughts
Offline nikk
« Reply #9 on: Thu, 25 July 2019, 10:27:55 »
hehe same
Yeah... the GMMK may be my only solution. It doesn't have dedicated media keys tho. If it did, my search would be over. Thanks guys.
Offline Surefoot
« Reply #10 on: Thu, 25 July 2019, 10:55:06 »
You should check on various chinese seller sites (most have a front on aliexpress) there are quite a few similar products like Durgod, etc.
Offline Riverman
« Reply #11 on: Thu, 25 July 2019, 11:02:43 »
Akko has a couple of Ducky-made keyboards called the 3108 that come with DSA keycaps, which are spherical, I believe.  There's a "Steam Engine" colorway that was just on Massdrop, and I think that their 9009 keyboard also comes with DSA keycaps.
Offline nikk
« Reply #12 on: Thu, 25 July 2019, 19:03:24 »
I not having any luck but thanks for the recommendation.
Offline nikk
« Reply #13 on: Thu, 25 July 2019, 19:07:40 »
Could not find what you were referencing but I checked out Massdrop. They had some great boards there, I'm talking about the CTRL and the ALT. Sweeeet! No full-size tho.
Offline Surefoot
« Reply #14 on: Fri, 26 July 2019, 03:18:21 »
There are a lot of options on KRepublic, YMDK.. For the most part you'll have to buy the keycaps separately.
