Author Topic: [IC] Key 65  (Read 146994 times)
Offline littleairbison
Re: [IC] Key 65 (old name NR65) | Finalized the logo options
« Reply #400 on: Wed, 11 September 2019, 23:00:49 »
The one in e-white is very attractive. I will definitely join the GB for this when it drops!
Offline //gainsborough
  • MATRIXの日常
« Reply #401 on: Wed, 11 September 2019, 23:18:14 »
any progress on the alps plate?  Definitely buying one assuming alps is supported!
Offline prototype26
« Reply #402 on: Thu, 12 September 2019, 01:15:18 »
The logo kinda grows on me to be honest, I like it better now. Some questions tho:
1. Will there be extra hotswap pcb with standard layout? (2u bspace, 6.25u spacebar etc)
2. Any anodized option, specifically Teal / Turquoise / Tiffany Blue color? I know you will have e-teal but wonder if it's available anodized
« Last Edit: Thu, 12 September 2019, 08:04:13 by prototype26 »
Offline suparnemo
« Reply #403 on: Thu, 12 September 2019, 09:39:59 »
Yeah, I want to know about this, too. Standard layout hotswap would be preferred.
Offline hcoopos
« Reply #404 on: Fri, 13 September 2019, 01:44:11 »
Would definitely be in for a blue alu top+bottom and a PC middle. Curious if there's a render for that?
Also would like to hear more about the PCB; RGB underglow would be a huge plus for PC middle/bottom layers. Hotswap is probably nice too.
Offline WAVES_D0NT_DIE
« Reply #405 on: Fri, 13 September 2019, 02:01:54 »
Would definitely be in for the white version :D. Will there be hotswap PCBs available?
Offline Feenoh
« Reply #406 on: Fri, 13 September 2019, 02:04:16 »
Absolutely sold on the white split space   :eek:
Offline Vyndem
« Reply #407 on: Fri, 13 September 2019, 13:54:24 »
I definitely like the Chinese/Kanji character 键/鍵. Looks really clean
Offline ACF101015
« Reply #408 on: Fri, 13 September 2019, 22:49:19 »
Most likely in for a PC version with split spacebar! Are there still plans for a rotary encoder on the top right?
Offline Omnomnominous
« Reply #409 on: Sat, 14 September 2019, 02:11:12 »
100% in for a blue/white or red/white version.
Offline dannyny
« Reply #410 on: Sun, 15 September 2019, 04:53:11 »
I'm still super interested in learning more about the newer stuff I've never seen before in keyboards; G10 case and Pattern Welded steel weight, are you having protos made for these so we can sort of estimate what they would look like/sound/feel if they were to happen?
The factory told me that G10 is too difficult to work with with their machines. I insisted to order a prototype. Let's see how would it turns out.
I also ordered a pattern-welded steel weight. The patterns on the sample material are not very good. The supplier can offer more options only if we have a bulk purchase. The prototyping is more for verifying this option. I don't think many people will choose this weight but I really want to offer it at least once.
I need that G10 case!!
Offline Lisinge
« Reply #411 on: Sun, 15 September 2019, 10:33:21 »
What anode colors are you looking to provide? I'm super excited but think i provide the more metallic look of anode over e-coat.
Yellow(gold), Red, Blue, Grey in that order is prefered for me :D
PS. Rose gold would guarantee a purchase for my GF.
« Last Edit: Sun, 15 September 2019, 10:43:44 by Lisinge »
Offline Wobafet
« Reply #412 on: Sun, 15 September 2019, 22:33:01 »
In for either a PC version or the ewhite version.
has there been any updates on whether the gb will start this month or next?
Offline Jetstream
« Reply #413 on: Mon, 16 September 2019, 13:58:08 »
Any ETA on the prototypes?
Offline Feenoh
« Reply #414 on: Tue, 17 September 2019, 02:04:07 »
Any way we could pick our own color combinations? So hyped for this gb
Offline aydio
« Reply #415 on: Tue, 17 September 2019, 05:41:18 »
I'm definitely in!
Offline vitaport
« Reply #416 on: Wed, 18 September 2019, 09:49:43 »
In for PC version
specifically, PC with top right logo, left WKL blocker and brass Kanji weight :^)
« Last Edit: Wed, 18 September 2019, 09:55:34 by vitaport »
Offline Tequila_Heineken
« Reply #417 on: Wed, 18 September 2019, 15:51:17 »
Is FR4 plate a possibility?
Offline senter
Re: [IC] Key 65 (old name NR65) | Prototyping finished
« Reply #418 on: Fri, 20 September 2019, 19:46:59 »
Prototyping has been finished. Here is a comparison between the render and the real thing.
More photos:
Unfortunately, the G10 case and the damast steel weight didn't turn out to be good. We haven't given up but we decide to run the GB without these two options first. GB will start on Sept. 25th and last two weeks.
Offline senter
« Reply #419 on: Fri, 20 September 2019, 19:50:13 »
ALPS plate has been canceled due to limited demand. Your reply is the first one I've seen about this option. The PCB still supports ALPS but I won't provide ALPS plate options in the GB. I'll make ALPS plates for myself tho. If you wanna join, I can help you with the ALPS plate. PM me.
Offline senter
« Reply #420 on: Fri, 20 September 2019, 19:51:59 »
1. The hotswap PCB supports 7u space and 2u bs
2. Two anodized colors will be available. They are blue and grey.
Offline Incarnius26
« Reply #421 on: Fri, 20 September 2019, 19:52:07 »
Will there be any way to get the logo blocker to be a shiny badge rather than an e-coated brass? Prototypes look good though!
Offline senter
« Reply #422 on: Fri, 20 September 2019, 19:53:02 »
Unfortunately no due to lack of demand and motivation.
Offline senter
« Reply #423 on: Fri, 20 September 2019, 19:55:54 »
I didn't consider that. What's so good about FR4? I used FR4 plates before with a tray mount case. I wasn't terribly impressed when I use them.
Offline senter
« Reply #424 on: Fri, 20 September 2019, 19:58:02 »
Oh your comment is quick.
No shiny badges will be provided but you can always hand polish the badge to a mirror finish if you want. Just remember to paint with a clear coat to avoid oxidation.
Offline Kingjunguhn
« Reply #425 on: Fri, 20 September 2019, 20:03:40 »
Is that a blue grey version I see?
Sent from my ONEPLUS A6013 using Tapatalk
url=https://geekhack.org/index.php?topic=107845.0][/url
Offline rrsurmeier
    • Attachments
« Reply #426 on: Fri, 20 September 2019, 20:05:24 »
would be in on this too.
Offline senter
« Reply #427 on: Fri, 20 September 2019, 20:12:05 »
You can choose each part's color and material. That's why it's called a CUSTOM keyboard :)
Offline Cresc3nt
« Reply #428 on: Fri, 20 September 2019, 20:18:24 »
The white and polycarb options looks amazing. Are the prices all decided for the GB yet?
Offline o3okevin
« Reply #429 on: Fri, 20 September 2019, 20:20:26 »
Hype!
Offline belgium_waffles
« Reply #430 on: Fri, 20 September 2019, 20:47:43 »
me like
Offline prototype26
« Reply #431 on: Fri, 20 September 2019, 20:52:42 »
What kind of blue is it? Is it teal or dark blue?
And please won’t you make the hotswap PCB has standard layout (6.25u space) as it’s more common for keycaps?
Offline noodleman
« Reply #432 on: Fri, 20 September 2019, 21:44:24 »
no chance that the hotswap pcb supporting 6.25u instead?
Offline suparnemo
« Reply #433 on: Fri, 20 September 2019, 22:07:15 »
I'll second this.
Offline jooobe
« Reply #434 on: Fri, 20 September 2019, 22:21:34 »
Does the pcb have build in under side led? Is there gonna be ona proxy site or like a google form order type of thing
Sent from my iPad using Tapatalk
« Last Edit: Fri, 20 September 2019, 22:28:51 by jooobe »
Offline vi0till
« Reply #435 on: Fri, 20 September 2019, 23:36:59 »
Hi.
Can you share the supported layout and what is the typing angle for this board?
Offline Choppersuey
« Reply #436 on: Sat, 21 September 2019, 03:26:37 »
Protos look great, definitely in for a PC one :thumb:
Offline Cresc3nt
« Reply #437 on: Sat, 21 September 2019, 03:27:44 »
I would also like a hotswap pcb that just has a standard 6.25u spacebar.
Offline Adelscott
« Reply #438 on: Sat, 21 September 2019, 04:04:11 »
Same here.
ISO + 6.25 + WK + hotswap + BT = dream keeb. The first 3 are non negotiable
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline Vireca
« Reply #439 on: Sat, 21 September 2019, 04:14:14 »
So the price is 295 and, will be a proxy? Do you ship from usa por eu?
Offline OmniSzron
« Reply #440 on: Sat, 21 September 2019, 11:02:28 »
Damn, those prototypes look clean. The pink and black version caught my eye. I wonder how well would it go with GMK 8008 (the pink in the keycaps is probably a lot brighter, though). Also, is the PCB going to feature underglow? This might tip me in favour of the polycarb board (which looks pretty sick, too).
Fox Lab Key 65 split space
« Reply #441 on: Sat, 21 September 2019, 14:07:28 »
Agreed. The 7u spacebar on the hotswap PCB is kind of a dealbreaker for me.
Offline rope
  • yeet
« Reply #442 on: Sat, 21 September 2019, 14:22:05 »
More photos:
these are beautiful senter, so excited!
Offline PotatoTM
« Reply #443 on: Sat, 21 September 2019, 15:12:35 »
Sad to hear the fake damascus didn't make it but still looking forward to this GB, GL!
Offline Solotov
« Reply #444 on: Sat, 21 September 2019, 19:07:21 »
Hey~ Can we see how the logo look on PC version? The photos didn't show that part, and I really wanna see it!
The proto looks really awesome though!  :thumb:
Flex is love, flex is life.
Offline dannyny
« Reply #445 on: Sat, 21 September 2019, 21:22:00 »
More photos:
Sell me the G10 prototype?
« Last Edit: Sat, 21 September 2019, 21:33:27 by dannyny »
Offline Yahhms
« Reply #446 on: Sat, 21 September 2019, 22:05:02 »
Can we get renders of the full board straight on?
Offline lac29
« Reply #447 on: Sun, 22 September 2019, 10:30:13 »
So what materials have actually been decided?
Offline Felt
« Reply #448 on: Sun, 22 September 2019, 17:25:08 »
Will this come with PCB?
Offline pengle
« Reply #449 on: Mon, 23 September 2019, 00:33:42 »
I'm definitely down for a polycarb if it's under $300
