Author Topic: [GB] Klippe R3 Pre-Order  (Read 32037 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« on: Sun, 28 July 2019, 17:48:08 »
Reddit post
Store listing
Klippe is one of the best high end affordable keyboard kits on the market. With the most improved tray mount screw placement, machined stabilising points, PCB compability, fine tuned since 2017 for each revision, and originally based on the Fjell mounting. The case alone weighs over 1kg, which is up to a 40% increase compared to keyboard cases in the same price range. And the weight is not only just an added heft, it is distributed in the case walls to make the case pingless and promotes the switch feel. A combination of the mounting, weight and aluminium amount is why so many people say the Klippe and Fjell sound so great, and so different from other tray mount cases.
Now, for the first time, available as a kit ($199) & you only need to add:
Stabilisers
Switches
Keycaps
You can buy the case alone for $120, and the other parts for a good price as well.
Updates from the second design(rev. 2(Klippe 2019) to rev.3):
1mm height adjustment, slightly heavier.
USB hole adjustments, 1mm wider to the left for better hot swap compability
Better USB C compability
Two Optional Mouning Points, same as Fjell Round 4
New colors.
Shipping estimated october - november 2019
« Last Edit: Wed, 31 July 2019, 05:46:06 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] Klippe R3 Pre-Order
« Reply #1 on: Mon, 29 July 2019, 06:36:25 »
approval pls
(reserved)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #2 on: Mon, 29 July 2019, 12:51:17 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #3 on: Tue, 30 July 2019, 05:51:03 »
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
« Reply #4 on: Wed, 31 July 2019, 05:52:45 »
Approved! Lykke til  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #5 on: Wed, 31 July 2019, 10:16:29 »
There is also possible to just buy the parts:
https://mekanisk.co/collections/keyboard-parts
Offline kipawazi
« Reply #6 on: Thu, 01 August 2019, 13:52:16 »
Coooool  ;D
I think I'm in.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #7 on: Fri, 02 August 2019, 15:51:12 »
Coooool  ;D
I think I'm in.
Cool, thanks :)
Offline nyry43
« Reply #8 on: Fri, 02 August 2019, 16:18:52 »
I'm in for an ultramarine. Looks great!
Offline dwarflemur
« Reply #9 on: Fri, 02 August 2019, 17:20:59 »
joined for one
Camp C225 | Norbatouch | ALF X2 + X3 | Orange TKL | CA66 | Leaf 60 | a bunch of others
Offline Lufenia
« Reply #10 on: Fri, 02 August 2019, 23:12:12 »
Anyone know how to polish the brass plate.  Both my brass plates came really scratched
Offline mSSM
« Reply #11 on: Sat, 03 August 2019, 05:44:26 »
The last Fjell had bad timing, so I missed it. But I am in on this one!  :D
Offline nickaster1
« Reply #12 on: Sat, 03 August 2019, 07:53:18 »
Do the plate and the pcb support alps?
Offline Lil
    • designedbydark
« Reply #13 on: Sat, 03 August 2019, 08:08:57 »
Got an ultramarine boys!
« Last Edit: Sat, 03 August 2019, 08:13:57 by Lil »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #14 on: Wed, 23 October 2019, 03:09:07 »
Offline ConfuseBill
« Reply #15 on: Thu, 24 October 2019, 03:44:58 »
Hi LeandreN,
Is the PCB compatible for bottom right arrow key?
Cause i notice the bottom right plate has universal holes. If yes, is the Right shift ready for 1.75u?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #16 on: Thu, 24 October 2019, 16:15:20 »
Hi LeandreN,
Arrow keys on a 60% is not a standard feature and not a feature on this PCB.
The right shift can be split yes, that is part of the HHKB layout.
Have a nice day :)
Offline ConfuseBill
« Reply #17 on: Thu, 24 October 2019, 17:43:09 »
Hi LeandreN,
Have a nice day :)
LeandreN,
Thanks for the detail info
Meaning, if i want arrow keys, i just need to source different PCB.
I think this run with reduced and affordable price will attract more people. Good luck.
Cheers
Offline OliveOil
« Reply #18 on: Fri, 25 October 2019, 20:48:44 »
Hey, im new to the whole keeb community and GBs. Is it still too late to order a Klippe R3??
« Reply #19 on: Fri, 25 October 2019, 20:50:58 »
yes
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #20 on: Fri, 08 November 2019, 05:10:35 »
Shipping :)
Offline regionfree
« Reply #21 on: Fri, 08 November 2019, 08:45:32 »
LeandreN, nothing is available on the website. Will there be extras?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #22 on: Fri, 08 November 2019, 17:55:03 »
There will probably be a few extras, but a US vendor might have more available, and before.
Offline cigs_coffee
« Reply #23 on: Fri, 08 November 2019, 18:56:19 »
. [ups, wrong thread  :-\]
« Last Edit: Fri, 08 November 2019, 19:04:26 by cigs_coffee »
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #24 on: Fri, 08 November 2019, 19:22:49 »
Who is the US vendor?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #25 on: Tue, 12 November 2019, 01:38:43 »
1upkeyboards.com
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #26 on: Tue, 12 November 2019, 01:40:14 »
Hello!
Quite a few Klippe R3 orders was shipped the last few days :)
I except shipping to be finished well before the end of November, but there might be some delays if some cases need to be reanodized etc.
Thank you for your patience.
Offline Zeelobby
« Reply #27 on: Fri, 31 January 2020, 18:53:57 »
Hello!
Are there any extras from R3?
Offline dwarflemur
« Reply #28 on: Fri, 31 January 2020, 23:41:04 »
Hello!
https://www.1upkeyboards.com/shop/bases-and-cases/aluminum-base/mekanisk-klippe-r3-high-profile-case/
Offline Zeelobby
« Reply #29 on: Sat, 01 February 2020, 07:19:01 »
Hello!
Thanks! Dunno how I missed this.
