Author Topic: [GB] Case wooden 60% - Dragon Việt Nam  (Read 9469 times)
Offline dodung.breakwood
« on: Mon, 29 July 2019, 22:57:01 »
It’s finally GB time for the **Dragon - Viet Nam**.  To keep it simple, we’ll only offer the case.
[Album ](https://imgur.com/gallery/)
[Link GB ](https://docs.google.com/forms/d/1HZCpMJdy_JB1V0R3WTQlutG45mF4L39xknlHexF31yU/)
_________________________________________________________________________________
Specs:
        * Made of Narra Padauk wood.
        * High profile case.
        * Length x Width x Height: 310 x 124 x 35 (mm) or 12" x 4 4/5" x 1 3/8" (inches).
        * 5 degrees angle.
        * 3M feet included.
        *  Wood/Brass weights.
        * Screw holes supports most standard 60% PCB. Tested with BFake.
        * Weight (fully assembled):
                1. Weight fully assembled with brass : 2500g
Pricing : 350$
Shipping:
* 80$
Time frame:
        * GB open for 2 weeks until 8/15/19
        * Estimated shipping time is in 10 month closse GB
You’ll need these to fully assemble a 60% keyboard:
        * a PCB.
        * a Plate.
        * Switches.
        * Stabilizers.
        * Keycaps.
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Case wooden 60% - Dragon Việt Nam
« Reply #1 on: Tue, 30 July 2019, 06:07:54 »
Approved
Offline rinkaan
« Reply #2 on: Tue, 30 July 2019, 06:35:02 »
Woah that's one hell of a carve....
Sent from my MI 6 using Tapatalk
Offline gaustin
« Reply #3 on: Tue, 30 July 2019, 11:35:42 »
Looks amazing. I’m in.
« Reply #4 on: Tue, 30 July 2019, 13:10:01 »
Thank you very much  ;D ;D
« Reply #5 on: Fri, 02 August 2019, 10:26:20 »
The patterns are clad in wood quite meticulously.
