Author Topic: Measurements for a 60% Keyboard Case  (Read 3901 times)
Offline The Real Hexed
« on: Tue, 30 July 2019, 08:04:46 »
Does anyone know where I can find the measurements for a 60% keyboard case? I'm looking to make one out of exotic wood and I can't seem to find the specifications anywhere!
Thanks so much :)
Offline doki
Re: Measurements for a 60% Keyboard Case
« Reply #1 on: Tue, 30 July 2019, 09:52:47 »
https://www.reddit.com/r/MechanicalKeyboards/comments/532yj4/60_pcb_dimensions/ here u have standard pcb, everything else is your design. GL
Offline eniigma
    • Storefront:
« Reply #2 on: Thu, 01 August 2019, 08:22:22 »
These are measurements for a PCB, but you could probably build a case around it. Here!
(not mine)
https://i.imgur.com/LQXco3J.png
