Author Topic: What kind of Lube for Stabilizers?  (Read 10435 times)
Offline lamenthe
« on: Wed, 31 July 2019, 23:32:03 »
I'm sure this has been answered somewhere, but all the threads I've found so far are several years old.
As the title says: what kind of lube do you find works best for stabilizers? I've been just using what I have lying around (Krytox 205g0). But I'm curious if a lighter, thinner lube might be "better." What's everyone's thoughts?
Offline Sup
Re: What kind of Lube for Stabilizers?
« Reply #1 on: Thu, 01 August 2019, 12:07:16 »
I have great success with Superlube. Makes the stabs smoother less rattle and most important more silent.
current
Coming soon
Offline lamenthe
« Reply #2 on: Sun, 04 August 2019, 22:51:09 »
Thanks Sup, I'll give it a shot.
Offline Acereconkeys
  • Happiness = life - expectations
« Reply #3 on: Mon, 05 August 2019, 01:14:31 »
https://switchmod.net/products/krytox-gpl-205-grade-0 This stuff is the tits on stabs. Highly recommend.
I use it for all plastic on plastic interaction, and super lube grease for the spots where the wire rests in the housing.
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
