Author Topic: How to disassemble G80-8200  (Read 2072 times)
Offline Phaedrus2129
« on: Mon, 31 May 2010, 17:44:18 »
So I'd like to do a dissection of my G80, but there's a bit of a problem. Rather than being held together with screws like every other keyboard I've opened, instead it's got some sort of snap-together arrangement that I'm not sure how to undo. Has anyone opened up their G80-8xxx board before, and if so how is it done?
Daily Driver: Noppoo Choc Mini
Currently own: IBM Model M 1391401 1988,  XArmor U9 prototype
Previously owned: Ricercar SPOS, IBM M13 92G7461 1994, XArmor U9BL, XArmor U9W prototype, Cherry G80-8200LPDUS, Cherry G84-4100, Compaq MX-11800, Chicony KB-5181 (SMK Monterey), Reveal KB-7061, Cirque Wave Keyboard (ergonomic rubber domes), NMB RT101 (rubber dome), Dell AT101W
Offline sixty
    • http://deskthority.net
« Reply #1 on: Tue, 01 June 2010, 12:13:27 »
I don't have a 8200, but I assume they use the same "snap in" mechanism as all the other G80 and G81 series boards. You should be able to snap the top ones open with just your fingers. If you spot any smaller holes that seem to also hold the case together you will need a flathead screwdriver.
Check Sandy's page about the G80-2100 and see how the back of the case and the opened case for reference on where the case is being held together. I am assuming that G80-8200 is held together in similar places due to the size.
http://sandy55.fc2web.com/keyboard/g80-2100.html
