Author Topic: [GB] Morgan 40 Wireless Unifying Ortho + Hotswap Mechanical Keyboard  (Read 11519 times)
Offline venderzhao
Morgan 40 is now live!
GB: July 31 - Aug 5
ETA: Dec, 2019
Morgan 40 is a portable wireless ortho with kailh hotswap sockets and equipped with the Unifying wireless module which is a superior solution over Bluetooth.
With the 2.4GHz wireless, there's no need for pairing, just plug and play and instant wake up!
Acrylic cutouts are available to work as signal exist to ensure stability. An extra Acrylic piece with random color pattern will be provided for you to swap out
Brass version (Aluminum Top with Gold PVD Brass bottom housing) available, limited to 3 units. On Aug 3rd, 10:00 p.m. PDT
Theoretical battery life is 3 months per battery. Morgan 40 can be powered by up to 4 CR2032 batteries.
An USB Unifying 2.4 GHz signal receiver - U2U Pro will be provided.
  • Unifying 2.4 GHz Wireless Connection
  • Beadblasted and anodized aluminum housing
  • Top + Bottom two piece housing design
  • Aluminum nametag
  • No visible screws and screw holes on every surface
  • Acrylic + brass weight (PVD) design
  • 5° slope
  • Acrylic signal exist
  • Kailh hotswap sockets
Join Discord group of DT.Heart for more info!
https://discordapp.com/invite/RteVhRY
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [GB] Morgan 40 Wireless Unifying Ortho + Hotswap Mechanical Keyboard
« Reply #1 on: Sun, 04 August 2019, 06:03:16 »
Approved
Offline mtuanvu
« Reply #2 on: Sun, 04 August 2019, 07:27:49 »
The kb is very nice but I'm not ready for a Orthor yet  :p
Offline Owl-
« Reply #3 on: Thu, 22 August 2019, 04:40:45 »
Did anyone have their morgan40 GB order suddenly cancelled on zfrontier?
Offline nathanchere
« Reply #4 on: Tue, 10 September 2019, 12:14:45 »
Yep, look like the GB was canned
