Author Topic: [IC] GMK Astral  (Read 145962 times)
Offline Karni
Re: [IC] GMK Astral
« Reply #200 on: Mon, 02 November 2020, 02:45:59 »
in love with the set
Offline stevenopoly
Re: [IC] GMK Astral
« Reply #201 on: Mon, 02 November 2020, 09:50:36 »
shame the op went dark as this was such a cool set.  :'(
Offline underling
Re: [IC] GMK Astral
« Reply #202 on: Fri, 06 November 2020, 17:51:31 »
i was wondering, i noticed the OP was really old.. is this like a necro thread now?
I also noticed there was a "Dark Astral" near the top now too..
Both of them are gorgeous.
Offline The_Runz
Re: [IC] GMK Astral
« Reply #203 on: Sun, 08 November 2020, 02:16:19 »
Still really wanting this set
Offline NaturalPack
    • NaturalPack's Website
Re: [IC] GMK Astral
« Reply #204 on: Sat, 05 December 2020, 16:21:13 »
Added kits and novelties
Offline Pach
Re: [IC] GMK Astral
« Reply #205 on: Sat, 05 December 2020, 16:44:34 »
whooooo! Waiting paid off!
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Astral
« Reply #206 on: Sat, 05 December 2020, 16:47:08 »
A few remarks/suggestions:
  • ISO support in the extension kit is currently inconsistent: it's halfway between the two commonly used approaches (R3 \|, R4 <> and R3 #~, R4 \|), but it's not consistent with either of them, which poses a problem. There's also an extra key that isn't necessary for basic ISO support. I suggest removing '@ and changing #~ to \|; this should fix the issues.
  • Based on popularity, I would say that ISO layouts are more common than 660 layouts. There's only been a couple of GBs for 660-layout boards recently, and its popularity has waned quite a bit over the past few years. For this reason, I think it would be prudent to move the four ISO keys (ISO Enter, R4 1.25u Shift, R3 \|, R4 <>) to the base kit and the second 2.25u Shift to the extension kit. It's fine to keep the accent ISO Enter in extension.
  • On a related note, I think you can move the accent numpad Enter key to the extension kit.
  • The R4 1u Ctrl key in the extension kit isn't very useful. Consider changing it to a 1c space, which would be useful.
  • Speaking of space, the key choice in the spacebars kit is pretty odd as far as the small spacekeys go. There are two 1c keys (out of which only one is useful since this set doesn't have ortho support), but there's no 2c. I recommend removing one of the two 1c spaces and instead adding accent-colored 2c and 1.25c.
  • It would be a good idea to move the second B key from the extension kit into base. This is so that users have the option to choose whether they want to buy the extension kit or the spacebar kit to get the spacekeys they need for Alice-like boards. Currently, if they buy base and spacebars, they will be stuck without a second B key.
  • Are you sure that you need all three homing variations of the numpad 5 key? Maybe stick with just one (e.g. nub) and drop the other two to save on a couple of keys (or make room for something more useful).
Edit: additional suggestions
« Last Edit: Sat, 05 December 2020, 17:02:44 by konstantin »
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #207 on: Sat, 05 December 2020, 18:51:29 »
Will take into account. Thank you sir
Offline DuellM
  • Keyboard Fatty
Re: [IC] GMK Astral
« Reply #208 on: Sat, 05 December 2020, 18:53:00 »
Yes!! It’s finally happening
Offline sup3r170va
Re: [IC] GMK Astral
« Reply #209 on: Sat, 05 December 2020, 22:59:52 »
Love the subtle set.
Any chance for icon mods rather than text mods?
ie more similar to mods in GMK cafe.
Thanks.
Offline LXVRGS
Re: [IC] GMK Astral
« Reply #210 on: Sun, 06 December 2020, 00:05:13 »
while i dont agree with the stance on removing mod pipe tilde/mod at least giving people the option to still have those keys is a fair compromise. Looking forward to snagging a set.
Offline fabijolo
  • I like expensive plastic.
Re: [IC] GMK Astral
« Reply #211 on: Sun, 06 December 2020, 00:23:26 »
I absolutely love this update, especially the novelties look really nice. Great to finally see this project moving forward!
Offline sagarsiddhpura
Re: [IC] GMK Astral
« Reply #212 on: Sun, 06 December 2020, 01:02:07 »
Oh ma gad
Offline foysauce_
Re: [IC] GMK Astral
« Reply #213 on: Sun, 06 December 2020, 05:11:15 »
Finally the notification I've been waiting for :)
Offline ShyNeiht
Re: [IC] GMK Astral
« Reply #214 on: Sun, 06 December 2020, 10:35:55 »
It looks very good! Was wondering if there could be some other novelties that were not just 1u sized and instead able to switch the enter button, or the r1 keys that are 1.25u. Also wondering if we could get them in the same color as the Esc button for a better contrast.
« Last Edit: Sun, 06 December 2020, 10:50:13 by ShyNeiht »
Offline forevermadrigal
Re: [IC] GMK Astral
« Reply #215 on: Sun, 06 December 2020, 16:43:48 »
Did the render in OP change? Renders looks more two toned than I recall
Offline Ram
Re: [IC] GMK Astral
« Reply #216 on: Mon, 07 December 2020, 00:24:07 »
reminds me a bit of blurple ngl
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #217 on: Mon, 07 December 2020, 12:44:02 »
Thanks.
Will definitely consider it
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #218 on: Mon, 07 December 2020, 12:46:23 »
Kit renders were done separately from the first handful of renders. Same colors. Lighting is just a little different for the kit renders.
Offline maximize
Re: [IC] GMK Astral
« Reply #219 on: Mon, 07 December 2020, 13:03:31 »
Besides using the same general hue, they're completely different, and this Astral IC was posted over a year ago.
Offline Galakc
Re: [IC] GMK Astral
« Reply #220 on: Mon, 07 December 2020, 14:41:31 »
Love the pastel blue, soft and beautiful tone
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #221 on: Mon, 07 December 2020, 21:11:29 »
Sorry it's taken so long. It's been quite the hectic year.
Offline maximize
Re: [IC] GMK Astral
« Reply #222 on: Mon, 07 December 2020, 22:14:15 »
No complaints here, mate! Just pointing out that your idea was here first, so more like Blurple should be compared to Astral (if at all), not the other way around. Cheers!
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #223 on: Mon, 07 December 2020, 23:14:40 »
We're back now friend. Had some IRL duties to take care of, but we're back now  :thumb:
Offline Ciantha
Re: [IC] GMK Astral
« Reply #224 on: Tue, 08 December 2020, 00:07:23 »
What rows are the novelties? Are there 8 row 1's and then 2 for 2,3,4?
Offline pdlif
Re: [IC] GMK Astral
« Reply #225 on: Tue, 08 December 2020, 00:32:40 »
This is so nice! Nice to have you back and excited to see this come to life!
Offline microscopicmint
Re: [IC] GMK Astral
« Reply #226 on: Tue, 08 December 2020, 06:23:01 »
The novelties are perfect! Would have loved ISO-UK support for this set though.
Can't wait for the GB  :thumb:
Re: [IC] GMK Astral
« Reply #227 on: Wed, 16 December 2020, 01:16:29 »
I am so ready for this set... Yes! Yes! Yes!
Offline kimhoon9
Re: [IC] GMK Astral
« Reply #228 on: Wed, 16 December 2020, 03:56:50 »
I shouldn't be allowing myself to join another keycap GB but the colors are so niceeeeeee 😩
Offline KT-afk
Re: [IC] GMK Astral
« Reply #229 on: Wed, 16 December 2020, 04:05:49 »
Any chances for more of the purple accent or blue accent in arrows and esc keys etc? Looks really good!
Offline SenseiJia
  • Hey you.
Re: [IC] GMK Astral
« Reply #230 on: Wed, 16 December 2020, 11:01:13 »
It's happening!!!!!!!! It's about time.
Offline NaturalPack
Re: [IC] GMK Astral
« Reply #231 on: Wed, 16 December 2020, 11:57:10 »
Will take into consideration  :thumb:
Offline stevenopoly
Re: [IC] GMK Astral
« Reply #232 on: Wed, 16 December 2020, 19:12:40 »
^ hell yes brother
So glad this is still alive. I was beginning to think this was vaporware.
Offline glack23
Re: [IC] GMK Astral
« Reply #233 on: Wed, 16 December 2020, 19:17:05 »
+1 support
Sent from my Pixel 3 using Tapatalk
Offline ShyNeiht
Re: [IC] GMK Astral
« Reply #234 on: Sun, 03 January 2021, 00:12:09 »
+1 support
Another +1 support, especially a purple enter key
Re: [IC] GMK Astral
« Reply #235 on: Sun, 03 January 2021, 01:07:35 »
Gib
Offline Zaprey
Re: [IC] GMK Astral
« Reply #236 on: Thu, 14 January 2021, 15:51:23 »
excited to finally see this moving towards group buy. However, I'm disappointed that UK-ISO has been left out :(
Offline blaqbern
Re: [IC] GMK Astral
« Reply #237 on: Thu, 14 January 2021, 19:51:02 »
Curious about this as well. It would be nice to have four R4 1U novelties instead of just two so you could fill the macro column on boards like the Zenith and J-01.
Alternatively, you could add two more R1 novelties. Not quite as good, but I think having all R1 macro keys still works on those boards.
Set is looking great. Excited for this one.
Offline KKoNaM
Re: [IC] GMK Astral
« Reply #238 on: Thu, 14 January 2021, 23:23:52 »
don't tell me this is going to be in GB at the same time as Dots r2? RIP my wallet
Offline Sandy
  • Formerly cogitoergofemme
  • Sandy - Peach Tray Maker
    • the peach · studio
Re: [IC] GMK Astral
« Reply #239 on: Sun, 17 January 2021, 00:49:17 »
I'm really excited for this. I'm sure someone asked for this but are there pantones or ral codes? it would really help to see the true vision of this set. I was really excited for alpine but then the colors changed so drastically (only to make it more accurate) and I want to be more informed about the sets I buy now as far as colors go.
🍑C11🍑KWA.6🍑GPK60 47-GR1RE🍑Vast60🍑Rose60🍑EHKB🍑Viktus Sinne🍑Boop65🍑Jelly60 Pro🍑Fuji65🍑Ginkgo 65🍑S7.7🍑Treasure Type-9 II🍑Thermal R2🍑Jelly 60🍑
Offline crispgm
Re: [IC] GMK Astral
« Reply #240 on: Sun, 17 January 2021, 02:03:42 »
I am in and is it possible to be TKL base set?
Offline mxrixs
  • Mxr aka Marius
Re: [IC] GMK Silver (Open Discussion)
« Reply #241 on: Sun, 17 January 2021, 16:14:59 »
is there a barely visible difference between the alphas and mods? or are my eyes tricking me?
I am pretty sure there is a differnce
Re: [IC] GMK Astral
« Reply #242 on: Sun, 24 January 2021, 23:43:01 »
Gib Gib Gib Gib Gib
Offline bert039
Re: [IC] GMK Astral
« Reply #243 on: Thu, 28 January 2021, 12:08:43 »
Sorry if I missed it but any chance for mac icon mods?
Offline Havattack
Re: [IC] GMK Astral
« Reply #244 on: Mon, 08 February 2021, 22:14:09 »
Did you decide not to do the dark astral then?  :'(
Offline maximize
Re: [IC] GMK Astral
« Reply #245 on: Sat, 13 February 2021, 00:13:05 »
Any update on the timing of this?
Offline andreiborisov
Re: [IC] GMK Astral
« Reply #246 on: Mon, 15 February 2021, 09:10:09 »
I love the set, but the kitting is all over the place:
1. Move ISO support in the base kit.
2. Move the second B in the base kit, so alice users could purchase either the extension kit or the spacebars kit.
3. Add stepped R3 control.
4. Add 3u and 2.75u spacebars.
Offline 3yatt
Re: [IC] GMK Astral
« Reply #247 on: Mon, 15 February 2021, 10:17:58 »
Can I ask what the theme/inspiration for the set is?
I love this so much and would like to know for description purposes :)
Offline Arila
Re: [IC] GMK Astral
« Reply #248 on: Tue, 16 February 2021, 15:24:50 »
Uhmm where has this set been all my life :eek: I'm in!!!
Offline Alpacacino
[IC] GMK Astral
« Reply #249 on: Mon, 22 February 2021, 10:21:59 »
Was “meh” about the set before, but after seeing the novelties and deskmat, this set has moved to MUST GET for my DnD battlestation
