Author Topic: [IC] GMK Coral - benefiting the Coral Reef Alliance (GB: Oct 11)  (Read 78765 times)
Offline wellbeing44
  • kebord good kebord fun yum yum
Re: [IC] GMK Coral (Overseas vendors chosen!)
« Reply #50 on: Tue, 20 August 2019, 07:25:08 »
I think it looks great!
Hate to be that guy, but I'll sign a petition to change the purse caps to an alternate icon.  :))
I think this is a reasonable suggestion, or change it all to text
Offline konstantin
  • Formerly constexpr
Re: [IC] GMK Coral
« Reply #51 on: Thu, 22 August 2019, 22:18:17 »
Checking in on this set again — WOW, I have to say it looks great now! That light blue accent really made all the difference. The deskmats look really nice as well.
I did notice a small issue with your base kit, though: you have R1 End and R1 PgDn keys for 1800/CP compat, but they can't really be used without a numpad. Would you consider moving those keys to the numpad kit, and adding R3 PgUp, R4 PgDn (popular options for 65%/75% layouts) to the base kit in their place?
Also, are the triple F and J in the base kit: scooped, barred and regular? If so, do you think it's worth offering the regular F and J at all? I don't think many people use non-homing F and J keys.
Finally, don't give in to Emir's demands, he's been getting his way a bit too much lately :D I think the padlock caps works well with the set — keep it!
Offline HoodrowThrillson
Re: [IC] GMK Coral
« Reply #52 on: Thu, 22 August 2019, 22:25:03 »
Hey there, I will look into the 1800/CP compat thing once we get quotes back from GMK (our rep is OOO till the 26th). I didn't notice the up/down was incorrect (I need to look into this).
The tripled F J are scooped, homing, and normal (I wanted to give everyone an option). I will probably cut the homing or scooped, not sure yet.
#teampurselock
Sidenote, if anyone is reading this. We're on track to hit an Oct GB date.
EDIT: So I copied Vaporwave's base kit but took out the numpad, hmm.
« Last Edit: Thu, 22 August 2019, 22:28:05 by HoodrowThrillson »
[Mostly] Retired from Keyboards
Typing on: TKL One - Zealios v1 - 55g TX Springs, TX Films, Lubed with 205g0 - Xiami Beige Cadet + RGB
Collection: IDB60 (gone), Austere (gone), Matrix 1.2og (gone), Matrix 2.0add (gone), RS (so lit), Infinitum (gone), THRILL Proto (destroyed), Matrix 2.0add xmas Starry Night (gone), RS60 (traded), MC65 (traded), Jane v1 CE (gone), GSKT-00 (gone), TKL One Poly (returned), TKL One, RS60, Serenity Proto, Boulevard Proto
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Coral
« Reply #53 on: Thu, 22 August 2019, 23:10:27 »
Keep the homing ridgies, will ya. To be fair, could have a vote.
Offline konstantin
Re: [IC] GMK Coral
« Reply #54 on: Fri, 23 August 2019, 01:29:54 »
Your current R2 PgUp, R3 PgDn are also correct, but it'd be nice if you could add R3 PgUp, R4 PgDn as well. A lot of recent sets are moving in this direction.
I don't think cutting homing (aka. barred) or scooped is a good idea. If I'm being honest, I don't remember the last time I saw a GMK set run normal F and J If anyone does use them, it's a very small number of people. So normal is probably what you should cut.
Offline popkorn62
  • No keyboards for old men
    • Mekibo
Re: [IC] GMK Coral
« Reply #55 on: Fri, 23 August 2019, 02:35:06 »
I think purse is here to stay. PLEASE!
https://mekibo.com/
Offline wellbeing44
Re: [IC] GMK Coral
« Reply #56 on: Fri, 23 August 2019, 03:19:29 »
I asked on discord and the mods won't be changed, or have text mod kits added.
Offline SUB01
Re: [IC] GMK Coral
« Reply #57 on: Fri, 23 August 2019, 03:47:16 »
Man I'm sad. I thought this set was for the baller-est of ballers with 140 full ano aluminum keycaps. :c
Re: [IC] GMK Coral
« Reply #58 on: Fri, 23 August 2019, 05:44:40 »
I will be adding R3 PgUp and R4 PgDn (I use a Tada68 at work)
No sorry.
Will consider a vote, I need to do research into recent GBs to figure that part out. Didn't realize they cut normal F J in favor of scooped and homing F J. Will report back.
Offline manassy
Re: [IC] GMK Coral
« Reply #59 on: Fri, 23 August 2019, 15:05:19 »
oh my god, that light blue /turquoise deskmat....!!! im in love
Re: [IC] GMK Coral
« Reply #60 on: Fri, 23 August 2019, 20:03:29 »
I am hoping to have prototypes to me soon (hoping before GB starts for photos).
Offline nasp
Re: [IC] GMK Coral
« Reply #61 on: Fri, 23 August 2019, 20:13:57 »
Why do you put the extra B in the 40's kit and not the spacebar kit?
Re: [IC] GMK Coral
« Reply #62 on: Fri, 23 August 2019, 21:02:29 »
Have no fear, I will add that a B to the spacebar kit.
Offline popkorn62
    • Mekibo
Re: [IC] GMK Coral
« Reply #63 on: Mon, 26 August 2019, 20:50:28 »
Still waiting for GMK’s quote...
https://mekibo.com/
Offline dvorcol
  • Discord: dvorcol_5071
Re: [IC] GMK Coral
« Reply #64 on: Mon, 26 August 2019, 21:46:05 »
GMK now has 1.25u and 1.75u R4C molds.  It's not too late for Coral to switch to convex where applicable, is it?
Re: [IC] GMK Coral
« Reply #65 on: Tue, 27 August 2019, 06:16:03 »
Is this in regards to the spacebar kit? I will probably end up switching them to convex, been working on a few things in the background.
Offline dvorcol
Re: [IC] GMK Coral
« Reply #66 on: Tue, 27 August 2019, 08:35:12 »
The Spacebar kit and two others.  I think all the blanks the Coral Relief and 40s kits can be convex.  Is that the plan?
Re: [IC] GMK Coral
« Reply #67 on: Tue, 27 August 2019, 09:31:53 »
I'll need to go back and look to see what the up-to-date sets look like (can't remember off the top of my head), but I will probably make that happen.
Offline guzzi
Re: [IC] GMK Coral
« Reply #68 on: Tue, 27 August 2019, 09:34:07 »
Very much into the idea and inspiration for this set, as well as the charity aspect.
Some thoughts on my part:
- As of late it's become somewhat of a trend to include a second Tab key in mod-colored alpha kits so that
you can build an entire second board with the remaining mod keys. It will surely boost the appeal of the kit overall
- The name "Coral Relief Kit" seems unfitting for the alpha kit. Given that it's an integral part to the idea of this set, and that the alphas
might not run if interest is too low, giving this name to the novelties makes more sense, especially considering the design of the novelties themselves.
- Novelties are nice, but the kit seems a little lean. Having GMKs steep pricing for small child kits in mind, it might need some work. Adding two R4 1u seashells
at the very least for Tsangan/HHKB seems like a no brainer to me.
- I have the suspicion that this unique red might be tough to nail, so be on the lookout for an equivalent RAL-color, as numerous designers have stated, that GMK prefers to work with those over pantone
Re: [IC] GMK Coral
« Reply #69 on: Tue, 27 August 2019, 15:31:53 »
Thanks for your input! I greatly appreciate it.
- 2nd tab key, I will look into that for sure.
- Coral Relief Kit is named that since I plan on giving 100% of proceeds I receive from that kit to the Coral Relief Alliance (one of a few ways I plan on giving). I do plan on running to kit as I received feedback that people want to see this kit come alive.
- I will look at adding additional novelties for sure!
- I agree, this color will be hard to match. I will need to sit down and find a suitable RAL equivalent color but that is my FINAL fallback. I plan on working with GMK to ensure we get a color pretty damn accurate, even if it does delay the shipment (assuming we hit MOQ).
hey you, if you're reading this, it means I can tell you a secret.
GB date is tentatively set for October 11th! I'm very excited but I don't wanna let anyone know till I get some more details together.
« Last Edit: Tue, 27 August 2019, 18:06:31 by HoodrowThrillson »
Offline Randalljai
Re: [IC] GMK Coral
« Reply #70 on: Wed, 28 August 2019, 12:52:35 »
I've reread the thread twice now, but didn't see details on the desk mat sizing? Maybe I'm just blind...
Re: [IC] GMK Coral
« Reply #71 on: Wed, 28 August 2019, 13:11:34 »
Sorry, I haven't posted that anywhere! I need to double check but afaik it was 900mm x 400mm
Re: [IC] GMK Coral
« Reply #72 on: Sat, 31 August 2019, 20:32:39 »
Good evening,
Updated IC with a few renders from Clavier.
Artisan is being made by Salvun (we are open to ideas if you have some, we're tossing a few around right now)
GB is on track for the original Oct 11 date.
Additionally, we are going to run the "Coral Relief" kit. I believe we have enough interest in the kit for it to be successful.
Offline dingusxmcgee
Re: [IC] GMK Coral
« Reply #73 on: Sat, 31 August 2019, 20:59:38 »
Good evening,
Awesome!
I would love to display this kit at work and the coral relief kit looks awesome.
Looking forward to the GB!
Offline PocketAces
Re: [IC] GMK Coral
« Reply #74 on: Sat, 31 August 2019, 23:27:22 »
I LOVE the colors! And I'm a massive fan of matching/complimentary deskmats.
But what about having the deskmat designer format a similar (but still different to avoid repetition) pattern or graphic to be used as a desktop wallpaper to complete the look on everyone's desk?
I'm in on this either way! Patiently waiting for October 11th!
Offline Rensuya
  • Blue is my spirit animal
    • Link to the discord!
Re: [IC] GMK Coral
« Reply #75 on: Fri, 06 September 2019, 20:51:32 »
Little late to the party but I absolutely love this keyset! It's very elegant and the theme is very strong. Pretty cool that this is also supporting the coral reefs. I'll be joining for sure, great job  :thumb:
+1 for the no purse lol
Offline SmilingPudding
  • 60% is the best layout.
    • Instagram
Re: [IC] GMK Coral
« Reply #76 on: Fri, 06 September 2019, 21:23:15 »
It would be super nice to have white modifiers.
Offline SuddenlyDonkey
Re: [IC] GMK Coral
« Reply #77 on: Sat, 07 September 2019, 17:12:55 »
In for the base, alphas, and space bar kits; they look great.  Mats are crazy busy and novelties could use some flavor.
Starfish, seahorse, sea turtle, octopus, moray eels, and puffer fish might all be cool to base artisan ideas on.
Looking forward to the GB.
Offline wakaward
Re: [IC] GMK Coral
« Reply #78 on: Fri, 13 September 2019, 15:39:07 »
I'm in for the Base, Coral, 40's, and Novelties kit. I do think the novelties could include atleast 2 more keys though as I think they could include more of the Limpet Shell as a base color. A turtle or a starfish would be a great graphic to include on them. Looking forward to the GroupBuy !!!
Re: [IC] GMK Coral
« Reply #79 on: Sun, 15 September 2019, 13:08:53 »
Updated the IC, not many more updates until we head into GB stage.
Changes:
Final kitting that was sent to GMK.
We are starting GB on Oct 11.
Added additional renders.
Re: [IC] GMK Coral (Kits Finalized, GB Starts Oct 11!)
« Reply #80 on: Sun, 22 September 2019, 09:05:05 »
IC updated,
Donation percentages announced:
Base kit: 25%
"Coral Relief" kit: 100%
40s kit: 25%
Spacebar kit: 25%
Novelties: 25%
Orders with shipping/billing address in Australia: 100%
Transparency plan announced:
I plan on releasing the total donation amount shortly after the group buy is finished (assuming we are able to hit MOQ). A screenshot of my donation via the Coral Reef Alliance's website, as well as, the donation amount being pulled from my bank account will be posted together. I plan on having a post group buy update across all channels.
Offline dantambok
Re: [IC] GMK Coral - benefiting the Coral Reef Alliance (GB: Oct 11)
« Reply #81 on: Sun, 22 September 2019, 11:25:39 »
TIL that you'll be donating part of the proceeds. In for a set, i love the sea.  :thumb:
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
« Reply #82 on: Mon, 23 September 2019, 17:56:48 »
Awesome, thank you :)
Offline SwitchKeys
    • SwitchKeys
« Reply #83 on: Tue, 24 September 2019, 02:33:01 »
My only disappointment is no Walking Dead novelty  :(
« Reply #84 on: Tue, 24 September 2019, 06:55:14 »
Hahaha, sorry about that mate  :-[
I am donating all proceeds from Australian shipping/billing address orders so I hope that makes up for it.
« Last Edit: Tue, 24 September 2019, 08:33:41 by HoodrowThrillson »
Offline mimalik
« Reply #85 on: Tue, 24 September 2019, 09:04:15 »
Thx a ton for setting proper coral reef kit, I will be going for that, as I would love to combine it with some blue or grey mods form other sets. Most of the drops either skips on F row or numpad with alternate alphas, so....... tip my hat to you on this sir.
« Reply #86 on: Sat, 28 September 2019, 10:31:56 »
Good afternoon here from the East Coast,
Just a short and sweet update. I have gone ahead and released pricing for GMK Coral.
Sign up here to receive updates about Coral. I heard Salvun artisan designs might be shown in the next email update
« Reply #87 on: Sat, 28 September 2019, 10:55:01 »
Good prices. The inclusion of split space bars in the coral kit is a boon for me.
If I'm looking at the kits right, there's some ISO compatibility keys hidden in the Coral kit. Anyone who wants the base for ISO use and isn't buying coral get at me or another non-ISO user
« Reply #88 on: Sat, 28 September 2019, 11:45:01 »
I tried to make it not that hidden but I guess I didn't do a good job  :-[
There are iso compat keys in the Coral Relief kit
« Reply #89 on: Sat, 28 September 2019, 12:55:16 »
hidden to me as I don't usually look for them! There's more sets now with the ISO keys out of the base kit and mingling with things I'd usually buy-the accent color here, in w numpad for Cafe or Minimal.
Offline popkorn62
    • Mekibo
« Reply #90 on: Sat, 28 September 2019, 15:12:45 »
We need to make this happen cuz...
https://mekibo.com/
« Reply #91 on: Sun, 29 September 2019, 07:26:07 »
Offline walletburner
  • Formerly wokechill
« Reply #92 on: Sun, 29 September 2019, 12:26:06 »
 :p i like dis
Offline xchangmanx
« Reply #93 on: Mon, 30 September 2019, 01:07:13 »
 :thumb:+1
« Reply #94 on: Mon, 30 September 2019, 12:11:55 »
Mini update,
Today I am pleased to announce the coral wrist rest in collaboration with MarbleKeeb
Some more info on these wrist rests:
The Coral Pink one will be available on 11th October in direct collaboration with the GB for GMK Coral.
https://geekhack.org/index.php?topic=101926.0
At that occasion, 20% of the 65 USD (=13 USD) will be donated to the Coral Reef Alliance for each Coral Pink Marble wrist rest sold, and proof of donation will be provided.
The Coral Pink marble wrist rest is a perfect color match for this keycaps set and it is a great opportunity to try to help the threatened coral reefs.
This GB will be a raffle and will end at the same time as the GMK Coral GB.
28 pieces will be directly available and shipped in November, if there is a high interest for this color (60+ ), I can order another run of production, but quantity of the base material is currently limited for this one and it would take about 3 months before shipping.
See GB page here
See more photos of the coral wrist rests here.
Offline NoxNoxNox
« Reply #95 on: Mon, 30 September 2019, 14:24:08 »
Potentially too late now to change, but one thing I noticed that I think this set also could benefit from is including an extra 'Tab' key in the coral relief set as doing so would allow somebody to use the basekit + coral relief kit to cover a full size ANSI layout plus a 60% Tsangan - Except we're missing a 2nd tab key.  And the only way to get that missing Tab key is to buy a whole 2nd base kit.  There seems to be an extra R2 1.5U '\' key in coral relief that is already included in the base kit which is (I think?) redundant.
« Reply #96 on: Mon, 30 September 2019, 14:29:17 »
I will admit that I realized this mistake (of not including tab on alphas) really late in the process. This is my first ever design so please excuse the error. I may ask GMK to see if they'll be able to swap the extra R2 1.5U for a tab.
Offline Bawsky
  • Give Deathcaps pls
« Reply #97 on: Mon, 30 September 2019, 15:31:08 »
Really like the novelties.
Offline sarahnicole
  • //add comment here later
« Reply #98 on: Mon, 30 September 2019, 15:43:52 »
Ughhh this is nice and so is the wrist wrest
Offline Jaystice
« Reply #99 on: Wed, 02 October 2019, 22:50:19 »
Goddamn it just joined Fireflies group buy and looks like im spending even MORE money this month RIP my wallet
Bottom Text
