Author Topic: [IC] GMK Forge (GB 3/20 - 4/20! - Pricing update and new vendor!)  (Read 84334 times)
Offline chanchan
    • atxkb
Re: [IC] GMK Forge (formerly Burnt Orange) - Colors & Deskmat update!
« Reply #100 on: Mon, 03 February 2020, 01:48:38 »
Just tossing this in there that if it was the white mods (burnt orange legends) and blue accents it would be ideal imo. 🤘
Offline driftingbunnies
Re: [IC] GMK Forge (GB Date and vendor update!)
« Reply #101 on: Wed, 12 February 2020, 17:32:15 »
Updated with GB date, current status, and artisan collabs.   :eek:
Offline Zeelobby
« Reply #102 on: Wed, 12 February 2020, 17:46:43 »
Man. That Magnus cap. I've followed and dropped a lot of cap GBs lately, but I may need to actually get down on this one. Everyone needs an orange set.
Online dvorcol
  • Discord: dvorcol_5071
« Reply #103 on: Wed, 12 February 2020, 20:25:23 »
All blanks in all kits are convex, right?
« Reply #104 on: Wed, 12 February 2020, 20:30:46 »
That's the intention but I'll have my vendor confirm with GMK.
Offline mta
« Reply #105 on: Thu, 27 February 2020, 00:22:38 »
Quite excited for this set.
Offline monkt
« Reply #106 on: Thu, 27 February 2020, 18:28:03 »
The base kit shows the alternate white arrow keys with orange legends, but the renders show the white arrow keys with blue legends. Which is correct?
« Reply #107 on: Thu, 27 February 2020, 18:29:44 »
White arrows with orange legends
« Reply #108 on: Fri, 06 March 2020, 10:39:15 »
Final kits are posted! Pricing will be available next week once we receive the final quotes. Thanks everyone for your support! Let's make this happen!
Also for those who are interested in the 40s kit, we unfortunately had to cut that out but the base kit does include a 1.25u R3 which means that you can outfit a 40s board with the correct row profiles if you purchase a split spacebars kit.
« Last Edit: Fri, 06 March 2020, 11:22:59 by driftingbunnies »
Offline Serious salamander
« Reply #109 on: Fri, 06 March 2020, 11:50:13 »
Looking great! I'm definitely in.
As a favor, could a non-color blind person give me their opinion on what color board this would best fit? Thanks in advance!
« Reply #110 on: Fri, 06 March 2020, 11:54:01 »
I believe this set will look really good on your run of the mill colors like black/gray/white/silver boards. If you decide to get the secondary alphas, that combination should go well with any color board.
« Reply #111 on: Fri, 06 March 2020, 12:37:36 »
Thanks! I'm in for base and space bars, it's a great looking set.
Offline konstantin
  • Formerly constexpr
« Reply #112 on: Fri, 06 March 2020, 12:57:03 »
What's the R3 1.25u Fn key for? Shouldn't that be a 1.75u Function key?
Also, might I suggest replacing the R3 #~, R4 \| ISO keys with R3 \|, R4 <>? Those make more sense for basic ISO support than incomplete ISO-UK.
« Reply #113 on: Fri, 06 March 2020, 12:59:15 »
The R3 1.25u Fn key allows for 40s profile support for a majority of 40%s. Unfortunately the Base kit is already set so no more changes to ISO compatibility.
Offline mta
« Reply #114 on: Fri, 06 March 2020, 13:14:10 »
No chance of making this end the 25th instead? :P
« Reply #115 on: Fri, 06 March 2020, 13:16:29 »
Depending on how things go, we might consider extending it a few days.   ;)
Offline konstantin
Re: [IC] GMK Forge (GB 3/20 - 4/20!)
« Reply #116 on: Fri, 06 March 2020, 13:45:27 »
Alright, thanks for the info.
Offline AaronR
« Reply #117 on: Mon, 09 March 2020, 02:34:52 »
Would it be possible to have Daily Clack proxy for Australia or even have switch keys for Aus as a proxy?
« Reply #118 on: Wed, 11 March 2020, 21:08:56 »
GB Thread is ready for approval!  :thumb:  https://geekhack.org/index.php?topic=105102.0
« Reply #119 on: Wed, 11 March 2020, 21:09:22 »
Unfortunately it's a bit too late to have an Aus proxy  :(
JK! Daily Clack is on board :)
« Last Edit: Thu, 12 March 2020, 08:26:47 by driftingbunnies »
Re: [IC] GMK Forge (GB 3/20 - 4/20! - Pricing update and new vendor!)
« Reply #120 on: Thu, 12 March 2020, 08:27:18 »
Pricing has been added!
Offline fishinaspacesuit
« Reply #121 on: Thu, 12 March 2020, 09:03:28 »
From the RAMA M60-A (HHKB) render, there's a R3 1.75u Control Key, but that's not in any of the kits?
https://imgur.com/jcXrL8b.png
https://i.imgur.com/csNx6EJ.jpg
« Last Edit: Thu, 12 March 2020, 09:05:06 by fishinaspacesuit »
« Reply #122 on: Thu, 12 March 2020, 09:12:03 »
The renders were made when that key was actually in the base kit. It was removed at a later date. I'll remove the renders to avoid confusion. Thanks for pointing that out.
« Reply #123 on: Thu, 12 March 2020, 09:17:22 »
Dang that’s a bummer, I would love that 1.75u R2 Ctrl for HHKB, looks like the only 2 options now are Stepped Caps and Caps
« Reply #124 on: Thu, 12 March 2020, 09:36:27 »
Sorry :(, it's difficult to balance what are considered duplicate keys and pricing since each set will attract a different mix of buyers. Unfortunately that key was cut.
