Author Topic: [IC] GMK Leek  (Read 10566 times)
Offline Aiwanei
    • ThocKeys.com
[IC] GMK Leek
« on: Tue, 13 August 2019, 14:47:51 »
Leek, noun: a plant related to the onion, with flat overlapping leaves forming an elongated cylindrical bulb which together with the leaf bases is eaten as a vegetable.
The word leek is also used commonly in place of a leak, when a new keyset, keyboard or other information is leeked.  So what better way to talk about leaks then to type on some GMK Leek key caps.  In the interest of limiting color matching and other issues, I am looking at using stock GMK Colors, specifically WS1, N7, AE, 3A and 3B.  It uses White legends on the keys that are N7, and N7 colored Legends on all other keys.  Ideally it would include a couple novelties in the base kit such as an image of a leek, and I'm open for further ideas.  Basically since this is such a meme colorway, I want to see if anyone else enjoys this concept other than me before pursuing too far.
Here is my inspiration
And here is GMK Leek in all it's initial glory
75%
104-key
Alice
60%
Update 1:
After some initial feedback, I've already reworked it some, I have gotten rid of 3B shifting 3A up and added more keys with WS1 to the design.
Update 2 8-15-2019: Gotten a couple of renders done from KBRenders, looking at the WS1 and feeling that I may end up getting some renders in CP to compare since WS1 may be too white, vs a more natural creamy white of CP may match better.
224520-0
224522-1
« Last Edit: Thu, 15 August 2019, 21:14:49 by Aiwanei »
ThocKeys.com
Offline merlin64
    • MechMerlin
Re: [IC] GMK Leek
« Reply #1 on: Tue, 13 August 2019, 14:48:41 »
Good leak.
Offline quinnx
Re: [IC] GMK Leek
« Reply #2 on: Tue, 13 August 2019, 14:49:43 »
GMK tomato when
Offline biothermal
  • Art
Re: [IC] GMK Leek
« Reply #3 on: Tue, 13 August 2019, 14:55:04 »
Offline 8six753o9
Re: [IC] GMK Leek
« Reply #4 on: Tue, 13 August 2019, 16:13:55 »
You beat me to it!  Would it be too Farfetch'd  to ask for this novelty?
Offline nasp
Re: [IC] GMK Leek
« Reply #5 on: Tue, 13 August 2019, 16:32:57 »
Why does it have to be GMK though? ;)
What if I like my leeks shiny *hint* *hint*
Offline rooski15
Re: [IC] GMK Leek
« Reply #6 on: Tue, 13 August 2019, 16:35:05 »
Like this?
Offline Nigolski
Re: [IC] GMK Leek
« Reply #7 on: Tue, 13 August 2019, 16:36:12 »
Offline IOVERCALLHISTIOCYTES
Re: [IC] GMK Leek
« Reply #8 on: Tue, 13 August 2019, 18:24:21 »
Awesome. Please leak leek novelties.
Offline OtherAndrew
Re: [IC] GMK Leek
« Reply #9 on: Tue, 13 August 2019, 18:33:34 »
this leek is undercooked
Offline fer.real
Re: [IC] GMK Leek
« Reply #10 on: Tue, 13 August 2019, 18:50:14 »
What if I like my leeks shiny, too?  And SA profile?
Offline eas
Re: [IC] GMK Leek
« Reply #11 on: Tue, 13 August 2019, 19:22:56 »
My Dad in Law from Shandong is totally in.
ne cicada novelty avail?
Offline ba7777
Re: [IC] GMK Leek
« Reply #12 on: Tue, 13 August 2019, 22:09:33 »
LMAO
Re: [IC] GMK Leek
« Reply #13 on: Tue, 13 August 2019, 22:13:05 »
gradient sets typically do well with the reddit crowd
Offline lewisflude
  • Hand Engineering
    • Hand Engineering
Re: [IC] GMK Leek
« Reply #14 on: Wed, 14 August 2019, 01:23:00 »
ISO support?
Offline pheonix991
Re: [IC] GMK Leek
« Reply #15 on: Wed, 14 August 2019, 14:18:17 »
Low effort.
Offline arrowM
Re: [IC] GMK Leek
« Reply #16 on: Wed, 14 August 2019, 14:35:54 »
Something about this works really well. I'd love to see some renders!
Offline merlin64
    • MechMerlin
Re: [IC] GMK Leek
« Reply #17 on: Wed, 14 August 2019, 14:37:09 »
Can we see this rendered on a Leeku board?
Offline Aiwanei
    • ThocKeys.com
Re: [IC] GMK Leek
« Reply #18 on: Wed, 14 August 2019, 19:59:05 »
Since there actually seems to be interest, I am working on finding someone who can do some renders, since that is definitely not be specialty.
ThocKeys.com
Offline infinitykw
  • Amazed by the beauty of industrial design
    • zFrontier Profile
Re: [IC] GMK Leek
« Reply #19 on: Wed, 14 August 2019, 21:53:54 »
AHAHAHAHAHAHAHAHAHAHAHHAHAHAAHHAHAHAHHAHHAHAHAHAHAHA  xswl
Offline infinitykw
    • zFrontier Profile
Re: [IC] GMK Leek
« Reply #20 on: Wed, 14 August 2019, 21:57:19 »
Im gonna buy a base kit and novelties if this goes real.
Re: [IC] GMK Leek
« Reply #21 on: Wed, 14 August 2019, 22:08:13 »
Low effort.
normally i'm all for it but it would seem like they actually put some time into this
even if the renders are just KLE, OP seems kind of new and might not know who to ask for proper keyshot renders
they're anticipating coverage and thinking about what this would look like on different boards, and they're responsive to feedback
i've seen less effort put into more successful ICs than this
you go, OP
« Last Edit: Wed, 14 August 2019, 22:09:45 by Puddsy »
Offline Visionaire
Re: [IC] GMK Leek
« Reply #22 on: Thu, 15 August 2019, 12:10:09 »
I mean, if people have feedback... this is the place to give it. An interest check. Let the OP know if you like it or not, what you like or not and let them take that feedback as they CHECK INTEREST. Sarcastic and judgmental comments aren't helpful.
Offline Kokaloo
  • 🤘(• ω •)🤙
Re: [IC] GMK Leek
« Reply #23 on: Thu, 15 August 2019, 14:45:39 »
Dye-Sub DSA might be a better fit, like from SP!
Offline Aiwanei
    • ThocKeys.com
Re: [IC] GMK Leek
« Reply #24 on: Thu, 15 August 2019, 15:41:44 »
Once I have a bit more feedback, and get some renders out for cherry profile, I may put out a google form for the idea of different profiles instead of cherry profile gmk (DSA, SA, KAT?) since I have seen a few comments now of people asking about a different profile.
ThocKeys.com
Offline goldworms
Re: [IC] GMK Leek
« Reply #25 on: Sat, 17 August 2019, 20:43:05 »
i dig it!!!!!!!
I've tried rendering the colorkit that's so attractive ;)
224676-0
224678-1
Offline Aiwanei
    • ThocKeys.com
Re: [IC] GMK Leek
« Reply #26 on: Sun, 18 August 2019, 19:35:50 »
i dig it!!!!!!!
Those renders look great!
ThocKeys.com
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] GMK Leek
« Reply #27 on: Sun, 18 August 2019, 19:51:31 »
Jokes :))
