Author Topic: Distance from top of plate to top of case?  (Read 3701 times)
Offline ab042896
« on: Wed, 14 August 2019, 19:39:47 »
I've had trouble finding a definitive answer, but to achieve keycaps whose edges are just barely "recessed" into the case, how far is the plate from the top of the case? Are there certain values someone has knowledge of for any existing boards?
Offline rondg
Re: Distance from top of plate to top of case?
« Reply #1 on: Wed, 14 August 2019, 21:44:44 »
I think it's between 7mm and 7.5mm? Not sure though..
Offline nevin
« Reply #2 on: Wed, 14 August 2019, 21:46:26 »
Put a cap on a switch & measure it. You can clearly see where the switch clips onto the plate.
