Author Topic: Seeking Feedback & Advice: DSS FĒI  (Read 6487 times)
Offline NoPunIn10Did
    • NoPunIn10Key
« on: Thu, 15 August 2019, 20:36:21 »
DSS FĒI
This idea is nowhere near the Interest Check stage yet, and I could certainly use some constructive feedback.  I'd like to do something similar to this as a DSS profile set in ABS doubleshot.  The color scheme is inspired by a beautiful set of Mahjong tiles that I bought from Singapore (from Mahjong Studio).
Updated Drafts (19 Aug 2019):
Older Drafts:
https://imgur.com/1vtJilP
https://imgur.com/9hdZZQh
« Last Edit: Mon, 19 August 2019, 08:48:52 by NoPunIn10Did »
Offline Sup
Re: Seeking Feedback & Advice: DSS FĒI
« Reply #1 on: Fri, 16 August 2019, 07:18:25 »
Way to many colored legends.
current
Coming soon
    • NoPunIn10Key
« Reply #2 on: Fri, 16 August 2019, 10:37:24 »
Can you clarify?  Do you prefer most keys to all have legends of the same color?  Or is it that the pattern of the colored legends is too distracting?
Offline Sup
« Reply #3 on: Sat, 17 August 2019, 04:57:21 »
Like the legends all have different color. It doesn't look clean but more chaotic. I think the modifiers should have one color and the Alpha's aswell. This makes the key set look cleaner.
current
Coming soon
    • NoPunIn10Key
« Reply #4 on: Sat, 17 August 2019, 10:12:53 »
So what I’m toying with currently is to keep all keys the same base/background color, getting rid of the white, lime, and rose keys. However, the legends will still have variation in color.
Kind of like Vilebloom or 1976, except it’s the legends with a patterned gradient rather than the keys.
« Reply #5 on: Sat, 17 August 2019, 16:53:46 »
do not like the legends and DSS seems to have received mixed reviews
    • NoPunIn10Key
« Reply #6 on: Mon, 19 August 2019, 08:56:00 »
How about this?  Colored legends are still in the modifiers, but not in the alphanumerics.
As for DSS, I really think it has a lot of potential but just needs to iron out a few quirks.  Like the bottom modifier / spacebar row might need to be R3 or R2 profile, for instance (the spacebar is already its own variation of R3).  The sculpting otherwise is very similar to the popular GMK / cherry profile, but with a more DSA-like keytop texture (which I really like).
