Author Topic: Pok3r RGB bricked? layer lights on doesn't register keypress  (Read 4754 times)
Offline funkden
« on: Tue, 20 August 2019, 01:01:28 »
Hi,
I swapped cases for my Pok3r RGB and it just stopped working. It's a dual PCB RGB. The layer light I use is on. It shows as usb HID device in journalctl but pok3rtools doesn't list it and it doesn't register any keypresses.
The RGB layer does fall off a lot but the pins go into the plug ok for the two layers.
I'm a bit lost, it's not my only board but I will be a bit sorry if it's dead:(
Anyone faced a similar situation. I was thinking to flash it with poker_qmk but I guess if pok3rtools doesn't work then there is little chance of that.
Sent from my SM-G950F using Tapatalk
Offline Sup
Re: Pok3r RGB bricked? layer lights on doesn't register keypress
« Reply #1 on: Tue, 20 August 2019, 09:54:04 »
Maybe something is shorting if your case is aluminium.
current
Coming soon
Offline pixelpusher
« Reply #2 on: Tue, 20 August 2019, 10:42:07 »
Hi,
what do you mean the RGB layer falls off a lot?
Offline funkden
« Reply #3 on: Tue, 20 August 2019, 11:06:58 »
As soon as I pick it up it falls off. The connector pins are all.ok
Offline funkden
« Reply #4 on: Tue, 20 August 2019, 11:32:51 »
No.its since I changed it to my Keyboardbelle 1984. I'm so unhappy about it
Offline funkden
« Reply #5 on: Tue, 20 August 2019, 11:33:36 »
Hi,
As soon as I pick it up it falls off. The connector pins are all ok and it lights up. Maybe something else is broke.
Offline funkden
« Reply #6 on: Tue, 20 August 2019, 12:56:33 »
Fixed!! The pcb connector plug had become too pushed up and the two PCs were not connecting. I pushed it down gently with a screwdriver each end now the RGB board stays in place and doesn't fall out. TLDR; The pins in the second RGB board were not in the plug until I pushed it down. Probably from too much case changing! Happiness returns!
Offline pixelpusher
« Reply #7 on: Tue, 20 August 2019, 13:02:29 »
glad you got it fixed.  What keyboardbelle case did you get?  Show it off, man!
Offline funkden
« Reply #8 on: Tue, 20 August 2019, 13:37:19 »
Yeah sorry ha ha here you go. To be honest I prefer it with my dev tty HS60 but time I dont have tonight!
Offline funkden
« Reply #9 on: Tue, 20 August 2019, 13:47:02 »
Here you go. Not ideal with DSA Granite and I dont normally put the lights on.
Offline pixelpusher
« Reply #10 on: Wed, 21 August 2019, 07:00:10 »
That’s pretty sweet with the rgb
Offline funkden
« Reply #11 on: Wed, 21 August 2019, 10:00:14 »
Thanks. It does look great with /dev/tty but is a bit noisy in the office compared to them in an aluminium case. I might try lining the case with neoprene like my alu ones
