Author Topic: [GB] Duck Octagon V3 Kustom Keyboard (75%) - Shipped/Complete  (Read 130806 times)
Offline JubJubCity
Re: [GB] Duck Octagon V3 Kustom Keyboard (75%) - Public Sheet Up!
« Reply #50 on: Sun, 01 September 2019, 14:35:06 »
Any estimate on the when the invoices will be out? Just being irrationally afraid of missing the Sept. 4th deadline.  :))
I second this!
Offline DevilxXx16
« Reply #51 on: Sun, 01 September 2019, 16:08:23 »
Hello,What will be the value declared on the package?
duck usually underdeclares, if memory serves correctly, at $35
Perfect,Thank you.
Offline Nothatso
« Reply #52 on: Mon, 02 September 2019, 15:57:31 »
I second this!
Thirded'
I've never purchased a Duck board before. Is this sort of time frame typical?
Offline elton5354
« Reply #53 on: Mon, 02 September 2019, 21:27:50 »
Updated deadline to September 15.  Currently sending out invoices now. May not finish it by tonight though.
Offline JubJubCity
« Reply #54 on: Mon, 02 September 2019, 21:37:46 »
Awesome, Thanks for the update!
Offline rondg
« Reply #55 on: Tue, 03 September 2019, 16:51:31 »
I cancelled my spot because my hobby funds will arrive on the 15th  :(
Offline elton5354
« Reply #56 on: Tue, 03 September 2019, 19:55:11 »
Hmm not sure if i understood correctly (or rather if google translator works) but i saw on duck's insta there might be ano problems for the grey version ? Have those been resolved ?
Where did you see that? Can you link?
every board has ano problems with grey, has been an issue since literally the beginning of time in keyboards
there will probably be a delay and then it'll be close enough to be fine
Puddsy's right. Gray may have some issues and each board's gray might not be the same.  I'm sorry I forgot to mention this before.  If you want to change your colour/cancel your order, please email me.
If you do decide on sticking with gray, I do NOT guarantee the gray's anodizing quality.
I apologize again. :(
Offline cirrus82
« Reply #57 on: Tue, 03 September 2019, 21:32:06 »
Thanks for the heads up. What kind of quality issues would there be?
I really like the gray and want to consider taking the risk but would like a better understanding of what could go wrong.
Offline elton5354
« Reply #58 on: Tue, 03 September 2019, 21:41:37 »
I believe it's the consistency of the colour. It is very hard for the anodizing manufacturer to get the colours to the same gray quality Duck wants.  So there may be some inconsistency, but Duck/Truecustom will try their best, but they cannot guarantee it.  It has nothing to do with the case quality, only the colour is the issue.
It may be a bit late, but I stopped invoicing those that chose gray as their case colour.  I will only invoice after you accept that I can't guarantee the anodizing quality of gray.
Thanks and sorry for the inconvenience.
Offline JubJubCity
« Reply #59 on: Tue, 03 September 2019, 21:53:41 »
Thanks Elton i just responded to your email about keeping my case color Gray.
Offline cirrus82
« Reply #60 on: Tue, 03 September 2019, 22:01:47 »
Thanks, really appreciate the candor. I'm looking forward to the gray, I'll take the risk too.
Offline romeo
« Reply #61 on: Wed, 04 September 2019, 01:14:56 »
took the risk for a grey too. Me and my friend got two grey, so the worst scenario is that we have 4 pieces all on different shade :) - Worth it.
Offline Oblotzky
  • Backspace is for people that make mistakes.
« Reply #62 on: Wed, 04 September 2019, 04:00:29 »
Both my LSV3 and Orion V3 were declared at 35$ yep.
Offline JubJubCity
« Reply #63 on: Wed, 04 September 2019, 20:45:48 »
Invoice Paid! Looking forward to getting the gray case in my hands.    :thumb:
Offline elton5354
« Reply #64 on: Wed, 04 September 2019, 21:12:12 »
If you're on the waitlist and have gray as an option and agrees to the terms, please email me if you still want in. Otherwise, I will email the next ones that did not pick gray.
Thanks
Offline elpepe21
« Reply #65 on: Wed, 04 September 2019, 21:36:57 »
I sent you an email, still want in!
Offline papedahut
« Reply #66 on: Thu, 05 September 2019, 07:53:53 »
Email send  ;)
Offline kacase
  • All things bright and beautiful.
    • 9di
« Reply #67 on: Fri, 06 September 2019, 01:22:45 »
Wohoo!
I was far down the wait list and did not expect to be part of the gb.
And yet... here we go!
Blacked out octagon coming!
Orion V2 | Rama M65-A | Rama M67-A aka. Exent | Keycool TKL | Cherry MX Board 3.0
Offline minhvo
« Reply #68 on: Fri, 06 September 2019, 03:20:05 »
[removed]
« Last Edit: Fri, 06 September 2019, 18:18:02 by minhvo »
Offline nathanchere
« Reply #69 on: Fri, 06 September 2019, 09:52:49 »
Can I get my invoice updated to remove the extra plate?
Offline Dreamre
    • kbdlife
« Reply #70 on: Fri, 06 September 2019, 10:21:59 »
You have to email him, read the OP.
Offline elton5354
« Reply #71 on: Sat, 07 September 2019, 14:27:52 »
I'll be flying to my cruise vacation tonight, so I may or may not have internet for an entire week. So if I don't respond, I should be able to after Sept 15.  (I know there are internet packages on cruises, but I'm too cheap :D)
Offline Charizard
« Reply #72 on: Thu, 12 September 2019, 20:54:45 »
Anyone willing to add an extra plate/PCB to their order?  I've got a v2 case, just need something to put inside of it.  Can ship to MT in the USA.
PM me and we can work something out, I'll pay a premium ^_^
Offline sapphyr
« Reply #73 on: Thu, 12 September 2019, 23:53:18 »
Is the PCB with this QMK compatible?
Offline foo4542
« Reply #74 on: Sun, 15 September 2019, 20:01:31 »
Is the USB port type-C or mini?
Offline Pennywise359
« Reply #75 on: Thu, 19 September 2019, 11:02:14 »
Plate files avail ne? :p
Offline Yehuo.
« Reply #76 on: Fri, 20 September 2019, 14:17:37 »
 Why is the order not updated? I am not in the Waitlist, why didn't I receive the invoice?
Offline KetchyKech
« Reply #77 on: Fri, 20 September 2019, 18:37:11 »
If i can piggyback an order for a PCB, id be very grateful....(busted octagon v2 pcb replacement needed...)
please slip into my dm's if you are willing ! thank you!  :thumb:
Offline cyyz
« Reply #78 on: Tue, 24 September 2019, 11:49:24 »
Any idea when the payment sheet will be updated?
Offline JackieX
« Reply #79 on: Fri, 27 September 2019, 09:04:32 »
Hi. i dont see any update from you
Offline elton5354
« Reply #80 on: Sun, 29 September 2019, 07:52:21 »
Updated
Offline Thyreophorous
« Reply #81 on: Mon, 30 September 2019, 19:11:31 »
When were invoices supposed to be sent out for those that selected gray? I replied to your email on the 10th saying I wanted to switch to silver, and assumed you'd send an invoice when you returned from your trip. I still haven't gotten one, and it looks like I was removed from the buyers spreadsheet. So that's cool I guess.
Not active on GH so signed up with different social user. Would have been under Zvitedge.
« Last Edit: Mon, 30 September 2019, 19:28:12 by Thyreophorous »
Offline vaughno
« Reply #82 on: Wed, 02 October 2019, 18:21:01 »
Can you still order one
Unikorn | Orion v3 | GSKT-00
« Reply #83 on: Wed, 02 October 2019, 18:25:03 »
Offline vaughno
Offline elpepe21
« Reply #85 on: Tue, 08 October 2019, 22:24:43 »
wait red was an option?
Offline DevilxXx16
« Reply #86 on: Sun, 20 October 2019, 05:32:37 »
Updates? production time? est shipping time frame? Thread seems dead. :|
« Reply #87 on: Sun, 20 October 2019, 13:22:20 »
in v2 yes not v3
may have been an option in korean or chinese GB, i didn't check
welcome to duck GBs
it'll show up when it's ready
Offline Astyrialis
« Reply #88 on: Sun, 20 October 2019, 22:06:52 »
Is ordering still available, and does it support ISO?
Edit: A supported layout image would be appreciated, cause the product page link provided does not work for me.
« Last Edit: Sun, 20 October 2019, 22:08:49 by Astyrialis »
Offline JubJubCity
« Reply #89 on: Sun, 20 October 2019, 22:33:55 »
Ordering has closed
Offline Iksion
« Reply #90 on: Fri, 22 November 2019, 19:44:24 »
Any news here?
KBD75v1 | Kira | Melody96 | TX75v2 | TX-CP | hbcp | Keycult No.2 rev.1 | NK65 | Duck Octagon v3 | Percent Volt | TX65v2 | KY-01 | Sunsetter | Mr. Suit | J-01 | Dolphin 2021 | Phase One 65 | KBD8x Mark ii
Offline 19thmech
  • GHS.RAR
    • Gone Hacking Studio
« Reply #91 on: Wed, 27 November 2019, 01:47:13 »
Hi All,
Long shot but worth the try. If anyone want to free up their spot please message me and ill be more than happy to fill in.
thanks
Offline kacase
    • 9di
« Reply #92 on: Tue, 10 December 2019, 17:33:59 »
I just checked kbdlab and it seems like the first octagon v3s are being sent out (at least in korea)
this is obvioiusly a ****ty google translate translation, where deduction = groupbuy
it has last been edited on the 5th of december, so the change is pretty recent.
My old account for kbdlabs didnt work anymore, so I had to sign up again, which weirdly takes two days to activate. So I can give you guys a little more info then.
« Last Edit: Tue, 10 December 2019, 17:37:15 by kacase »
Offline The Equals D
« Reply #93 on: Tue, 10 December 2019, 17:52:38 »
A guy posted his on reddit the other day and said he got it from the Korean GB.
Offline cyyz
« Reply #94 on: Tue, 10 December 2019, 18:36:36 »
Duck replied to an instagram comment saying that it might ship next month.
Offline JubJubCity
« Reply #95 on: Tue, 10 December 2019, 20:33:44 »
Hot Damn!
Offline elton5354
« Reply #96 on: Tue, 24 December 2019, 10:17:04 »
Hi all,
There are currently no new updates. The keyboard is still being manufactured and will update you as we progress. Please email me if you have any address changes.
Thank you and wishing all of you Happy Holidays and a Happy New Year!
Elton
Offline elton5354
« Reply #97 on: Thu, 02 January 2020, 15:12:35 »
Hi all,
The keyboards are being prepared for shipment and address changes are no longer allowed. I will update you when it ships.
Thanks.
« Reply #98 on: Thu, 02 January 2020, 15:24:16 »
Hi all,
Thanks.
Wow, that was faster than I expected, hyped to get my first duck board
Offline JubJubCity
« Reply #99 on: Thu, 02 January 2020, 19:50:01 »
Hi all,
Thanks.
Hip Hop Hooray
