Author Topic: [GB] Duck Octagon V3 Kustom Keyboard (75%) - Shipped/Complete  (Read 129812 times)
Offline rkarp
    • hypertext.dev
Re: [GB] Duck Octagon V3 Kustom Keyboard (75%) - Shipped/Complete
« Reply #150 on: Thu, 30 April 2020, 13:30:14 »
i recently received a back plate for this board but does anyone know the best way to stick the plate to the bottom. The plate itself doesn't seem to have any type of adhesive to it.
I used double sided tape.
Awesome thanks, will have to pick some up in these trying times
My double sided tape was a bit thick at .6mm, and now my weight protrudes a bit.  And I can't get it off.  Oh well I guess.  Doesn't really have too much, if any negative impact.  There's like .5mm clearance between the desk surface and the protruding weight. Guess I'll just have to be careful when handling.  My Octagon is a heavy beast now though.
Offline tdris
« Reply #151 on: Wed, 20 May 2020, 19:37:27 »
Hey! Does anyone know of an outline or something that I could use to custom cut a diffuser so it looks something like this? I know there is a file or something going around. Thanks in advance!
Offline ytkwong
« Reply #152 on: Sun, 16 August 2020, 16:33:08 »
Anyone looking for PC Plates for the Octagon v3, check out https://www.reddit.com/r/mechmarket/comments/ib0scl/usfl_h_duck_octagon_v3_pc_plates_w_paypal/
Feel free to reach out to me on Reddit. =)
Offline hillmu
« Reply #153 on: Tue, 13 October 2020, 21:49:54 »
What software am I supposed to use to remap this? Is there a version of Jigon that's supposed to work?
I was able to remap using QMK and the keymap for the Octagon V2.
https://config.qmk.fm/#/duck/octagon/v2/LAYOUT_75_ansi
Sry for trouble, did you find that right top LEDs not work after QMK flash?
« Last Edit: Tue, 13 October 2020, 22:31:22 by hillmu »
Offline hillmu
« Reply #154 on: Tue, 13 October 2020, 23:38:53 »
Just flashed Duck Octagon PCB via QMK. Everything is fine except media keys (vol+, vol-, mute)... they are not working at all. Does anyone got a clue how to fix this?
Sry for troulbe, is right top led working well after you flash via QMK? I found problem here. Would you help to send your hex file to me if your Octagon are working well with all leds?
Offline Mavarina
« Reply #155 on: Mon, 23 May 2022, 09:38:19 »
Hi I never received my keyboard, is there anyway to contact you?
