Author Topic: [IC] GMK Astral Dark  (Read 84915 times)
Offline 002 DC
Re: [IC] GMK Astral Dark
« Reply #50 on: Fri, 03 January 2020, 17:43:50 »
imo dark and light are equals to me. Just curious if this would support alice with a all the alice keys?
Offline ddnomad
« Reply #51 on: Fri, 03 January 2020, 19:11:23 »
Would you consider adding two 1.5u Code and two 1u Alt keys to the base for tsangan compat for mac users. similar to that of GMK minimal?
Double that, alt where super/cmd should be offends my perfectionism :D
Offline Shutter_Shock
« Reply #52 on: Fri, 03 January 2020, 20:49:43 »
I second this. It’s great for Mac users. Also, wouldn’t mind seeing some turquoise/light blue thrown in. Maybe esc/enter accents or in the mod legends? Idk. “Galaxy” color schemes tend to include turquoise in with the purples and navy, and I’ve always loved it.
Offline UltimateCheeze
« Reply #53 on: Fri, 24 January 2020, 13:09:09 »
Legend has it that if you combine Astral Light and Dark you get Taro.
Jokes aside, this looks nice.
Offline brookwin
« Reply #54 on: Fri, 24 January 2020, 20:18:26 »
any updates tho
Offline hawkfan13
  • Food is Food
« Reply #55 on: Sat, 25 January 2020, 07:51:25 »
Interested in this version!
Offline Eipplepod
« Reply #56 on: Sat, 25 January 2020, 08:13:26 »
I would love to see an ISO-Norde kit and split spacebar
Offline dabbaranks
« Reply #57 on: Wed, 29 January 2020, 01:08:50 »
100 percent, need more dark purple sets!
Offline Dopamine
« Reply #58 on: Wed, 29 January 2020, 06:06:21 »
I like this allot
Offline TNbiscuits
« Reply #59 on: Wed, 29 January 2020, 15:55:50 »
they both look very nice, want both
Offline 3ambutter
« Reply #60 on: Wed, 29 January 2020, 16:05:33 »
In for dark if the base kit isn’t too high. GL
Reborn60 | Keycult No.1 Rev.1 | SKB60 | TGR x SINGA UNIKORN | GSKT-00
Offline chanchan
    • atxkb
« Reply #61 on: Mon, 03 February 2020, 01:51:04 »
this looks great! really interested. any hope we'll see a gb in 2020?
Offline hkiri
« Reply #62 on: Tue, 04 February 2020, 15:15:42 »
I hope this won't get shelved. This is really nice!
Offline jpg2401
« Reply #63 on: Tue, 04 February 2020, 17:09:27 »
I would personally love to see a Icon Only child kit. Also, I feel that the 1.5u Backspace key looks better as an icon only key or as Delete
Savage 65 | GSKT-00 || Valhalla | X60 V2
Offline Nitaru
« Reply #64 on: Sat, 29 February 2020, 10:17:03 »
This looks amazing! Any updates?
Also, if you're only going to run one, I would personally go with dark.
Compatibility - Icon mods
« Last Edit: Sat, 29 February 2020, 10:47:29 by Nitaru »
Offline konstantin
  • Formerly constexpr
« Reply #65 on: Sat, 29 February 2020, 13:24:39 »
Hi, I have a few kitting suggestions:
  • If you're using “Scroll” and “Num” legends, I suggest using “Caps” instead of “Caps↲Lock” for the stepped caps legend. This will help achieve a uniform, one-line look across the set.
  • Change the “Menu” legend to “Fn”. The fact is that 1.25u Fn is a very commonly used key, and whilst “Fn” can fulfill the role of both Fn and Menu, the same isn't really true for “Menu”.
  • Add R3 PgUp and R4 PgDn keys to help cover some popular 65%/75% right column options.
  • Consider using System or Super instead of Code. Here's why.
  • Consider dropping the 2u Shift and adding a barred numpad 5 instead.
« Last Edit: Sat, 29 February 2020, 13:26:41 by constexpr »
Offline saqneo
« Reply #66 on: Sat, 29 February 2020, 13:48:50 »
I strongly agree with the first three suggestions here.
For me, Super > Code >> System, though I usually just go for icon mods if they're available.
In terms of 2U shift vs. the extra num key I think preferences will vary. Among my customs none even have a num pad but I also think 2U shift is a layout smell. I built 2U once which taught me it's better to overload "? / Rshift" or just going 65%.
Sent from my SM-N960U1 using Tapatalk
Offline konstantin
« Reply #67 on: Sat, 29 February 2020, 14:16:07 »
Another key you might want to consider dropping is the off-centered stem 6u spacebar. I have 4 boards with 6u spacebars, and on all of them I'm using centered stem keys. Nowadays, if a PCB supports 6u, it'll either support both variants or just centered stem; therefore, I don't think having both in the kit is really necessary.
Offline Edward
« Reply #68 on: Sun, 05 April 2020, 02:04:33 »
I'm in for Colevrak/Base  :D
Offline fropsie
« Reply #69 on: Sun, 05 April 2020, 02:24:02 »
Yes.
Offline aaronlau
« Reply #70 on: Sun, 05 April 2020, 21:57:36 »
I love it ! My only suggestion would be to make it Icon Mods only ? But other than that, I'm looking forward to this ! Best of luck ! :D ;D
Offline leexy
« Reply #71 on: Sun, 05 April 2020, 22:56:09 »
thread necroed
Offline vivek.yyy
« Reply #72 on: Sun, 24 May 2020, 16:49:03 »
a space themed accent set would be cool, maybe with stars or comets?
Offline krzank
« Reply #73 on: Sun, 24 May 2020, 17:56:49 »
Very nice.
Compatibility:
R3 `~
Russian and/or arabic alphas (with R3 `~Ё and R3 `~ذ respectively).
less important: R4 PgDn / R3 PgUp / R2 Home
Offline solomonshv
« Reply #74 on: Sun, 24 May 2020, 18:20:49 »
i already bought a nautilus but i'll get this too if it ever sees the light of day
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
Offline mafez
« Reply #75 on: Mon, 25 May 2020, 13:58:48 »
I need 40s. This kit is great!
Offline yjchan27
« Reply #76 on: Mon, 25 May 2020, 23:48:25 »
It looks pretty much better than light one.
I hope GB open soon~~
Offline The_Runz
« Reply #77 on: Tue, 26 May 2020, 11:32:20 »
Yep, definitely
Offline GMK_Andy
    • GMK
« Reply #78 on: Tue, 26 May 2020, 11:33:30 »
Looking good! Subtle dark theme is very nice :thumb:
Offline sagarsiddhpura
« Reply #79 on: Sun, 31 May 2020, 14:06:39 »
I like both.
Offline rath_k
« Reply #80 on: Sun, 31 May 2020, 19:14:55 »
Would you consider doing this set in reverse dye-sub? Infinikey's newest sets are looking pretty good.
Offline Xemnova
« Reply #81 on: Sun, 31 May 2020, 20:28:38 »
Initially I was thinking of going for Deep Navy since I like dark blues, and while I was going to get it I decided not to since it seemed almost borderline white on black. I love the coloring of this set (and the Astral set). This one has nice dark blues but also doesn't feel harshly dark, and the light Astral is a nice pastel. I would go for both sets honestly. It would be cool, and I'm not sure how this would be achieved persay, if the two sets could combine into a third set, since they're so closely related.
Offline foysauce_
« Reply #82 on: Sun, 31 May 2020, 22:10:35 »
I don't like this set as much as the light version simply because there have been a lot of dark purple sets as of late (GMK Black Lotus, Nightshade, Rouge, even Taro which has the dark alphas as an option. I get that this IC came out a long long time ago before those sets, but looking at the current landscape). I personally find some of those sets to fulfill my need for dark purple. I do really love the light version however, because it fills a bigger void with its unique colors.
« Reply #83 on: Mon, 01 June 2020, 14:25:41 »
Will def buy. Please make both Astral sets to GB. Thanks
Offline eibbun
« Reply #84 on: Mon, 22 June 2020, 00:50:34 »
definitely dark
« Reply #85 on: Mon, 22 June 2020, 12:47:16 »
super crisp, i like this one more than the lighter one. a mix of the two would be my preference, almost like the gmk taro
« Reply #86 on: Fri, 26 June 2020, 04:30:31 »
Excited for this. Please make it into a GB
Offline ergusto
« Reply #87 on: Fri, 26 June 2020, 06:00:03 »
Would be an instant buy for me. Love those colours, please don't change the hues!
Offline Solotov
« Reply #88 on: Fri, 26 June 2020, 06:30:30 »
Is this set dead already?
Flex is love, flex is life.
Offline edasaur
« Reply #89 on: Sun, 28 June 2020, 12:59:32 »
Not sure, but I did see OP make a post at the end of last month. Still crossing my fingers that this moves to GB soon.  :)
« Reply #90 on: Sun, 28 June 2020, 22:57:38 »
I’d be in for this if it’s still alive and I haven’t spent too much money on other sets when it runs. I’m hoping to pick up an NK65 entry edition, and this will look killer with the purple polycarbonate case.
Offline Zaprey
« Reply #91 on: Sun, 26 July 2020, 11:21:44 »
absolutely amazing, but i think it would look better with icon mods
Offline esmtll
    • scottmitchell.co
« Reply #92 on: Sun, 26 July 2020, 13:04:26 »
Please, please please, Cmd or, at the very least, two of each 1.5u Code and 1u Alt.
Offline esmtll
    • scottmitchell.co
« Reply #93 on: Wed, 29 July 2020, 14:16:50 »
Second this!
(and thanks, Starston3, I'm going to start using this graphic on every IC I'm seriously considering!)
Offline jp5486
« Reply #94 on: Wed, 29 July 2020, 21:24:04 »
this looks good. :)
« Reply #95 on: Sat, 08 August 2020, 04:51:56 »
Count me in
Offline Noworries
« Reply #96 on: Sat, 08 August 2020, 05:58:34 »
Loving the dark theme. Please keep the ISO UK caps bc I will definitely buy the base kit
Offline santela
« Reply #97 on: Sat, 08 August 2020, 07:21:37 »
This just objectively looks great, even though the colorway isn't my thing. Great job!
Offline lorphex
« Reply #98 on: Fri, 14 August 2020, 05:56:59 »
Highly prefer the dark theme. Would like to see the mod keys be even darker.  :thumb:
Offline dibstern
« Reply #99 on: Fri, 14 August 2020, 06:17:43 »
If you add command and alt keys for Mac users then I’m in
