Author Topic: Current Keycap Sculpts [Croak] and (Unnamed) oni.  (Read 5303 times)
Offline bmmcwhirt
    • KB9YEN
« on: Sat, 24 August 2019, 23:03:57 »
I'm working on some sculpts for some new designs. This will be my second attempt at doing Artisan keycaps, the first time a few years back was a learning experience and never resulted in a product.
First is Croak, my take on a stylized frog face.
225097-0
225099-1
225101-2
And here is my GIANT unnamed oni. I've not done the mount and the horns will probably be sculpted and molded separate.
225103-3
225105-4
225107-5
Curious what everyone's thoughts are. Neither is finished yet, but Croak is getting close.
Offline popcap
Re: Current Keycap Sculpts [Croak] and (Unnamed) oni.
« Reply #1 on: Sun, 25 August 2019, 15:15:29 »
The first doesn't immediately read frog but you did say it was a stylized rendition. The oni looks like it will turn out very nice.
What kind of sculpting clay are you using? I like how smooth it looks.
Offline bmmcwhirt
    • KB9YEN
« Reply #2 on: Mon, 26 August 2019, 02:07:29 »
Croak, I've been on the fence about adding his tongue. Also when he's cast in color the idea of frog will come out more. The tongue design I have might be easily broken off and would be a separate mold.
As for the clay, I am using Super Sculpey Firm, which is not really that firm when you start working with it. You can toss your sculpt in the fridge when not working on it to get a firmer clay until it warms back up. Part of the smoothness is I use soft silicone tools with a very light hand. By light I mean you use more pressure when you feather dust than I do when I am smoothing an area. Here is a link the the exact ones I am using.  https://www.amazon.com/gp/product/B073QHHCZL/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1  However any of the soft silicone ones will work. Also I use additive modeling where I add small balls or rolls of clay to build a feature instead of carving.  This is due to the small size and it the opposite of what you do when working on larger sculpts.
Offline popcap
« Reply #3 on: Mon, 26 August 2019, 15:58:46 »
Would love to see it when you've casted it.
Also thanks for the tips I don't have any of the silicone shaper tools so going to have to give that a try.
Offline bmmcwhirt
    • KB9YEN
« Reply #4 on: Wed, 28 August 2019, 16:31:30 »
Here is what it could look like with the tongue added. This inst attached just a quick moch up with it laid ontop.
225316-0
Offline popcap
« Reply #5 on: Wed, 28 August 2019, 17:54:42 »
Getting somewhere, looking forward to seeing how it turns out when your done.
Offline AuthenticDanger
« Reply #6 on: Wed, 28 August 2019, 18:01:15 »
Careful not to go too large or it'll rub on other keys!
F Keys belong on the left.
