Author Topic: 65% / 75% optical keyboard PCB  (Read 8406 times)
Offline sfchun
« on: Tue, 27 August 2019, 13:11:52 »
Hello everyone,
I'd like to train myself on small keyboards.
I did some random google seach ... but couldn't find my holy grail yet.
So I thought I can build it by mylself ... but couldn't find the right PCB to start with.
The feature I whish to have :
- Layout 65% or 75% keyboard for optical switches
- usb-c connector and bluetooth
I don't know if such a PCB exists...
60% (iGK61p) is NOT an option I'd like to keep the directional arrows as physical keys.
If I'm not mistaken, I can't use the iGK64 for optical switches.
If I have no alternative, I'll need to go for a TKL keyboard layout...
Thanks for your help
Best Regards,
« Last Edit: Tue, 27 August 2019, 14:08:06 by sfchun »
Offline ErgoMacros
Re: 65% / 75% optical keyboard PCB
« Reply #1 on: Tue, 27 August 2019, 14:02:15 »
If I'm not mistaken, I can use the iGK64 for optical switches
From your link it looks like iGK64 supports Cherry MX switches. Alas, none of these are optical.
I think you likely need different software in the controller, and PCB circuitry, to support optical.
Today's quote: '...“but then the customer successfully broke that.”
Offline sfchun
« Reply #2 on: Tue, 27 August 2019, 14:08:29 »
Thanks for your answer.
Sorry it was a typo, I mean can't :)
I fixed the mistake in the post.
Offline sfchun
« Reply #3 on: Tue, 27 August 2019, 15:13:26 »
Apparently I missed the fact that iGK62 is an optical PCB !
But, no bluetooth.
I'll think about it.
