Author Topic: Flashing a UT47.2 through QMK GUI + Toolbox: doable?  (Read 6066 times)
Offline pott
« on: Sat, 31 August 2019, 01:06:22 »
I got my UT47.2 capped, but I'd like to redo the keymap to my preferences.
QMK GUI doesn't have much for this keyboard. For those interested, I'm attaching the JSON I used for this particular keymap.
I don't know much about nor use Github. I flash my keyboards using the QMK GUI and QMK Toolbox.
Is this a safe procedure here?
The UT47.2 documentation doesn't talk about it, referring only to the compiling option.
Hence why I'm hesitant to flash this new firmware to it. As far as I can see, it SHOULD work (being careful to select the atmega32u2 controller). I made sure to include the RGB commands as well.
 If I'm wrong though I may not recover from this! Hence why I'd rather make sure...
Thanks for any confirmation/warnings!
* ut472v1(3).json (1.31 kB - downloaded 153 times.)
« Last Edit: Sat, 31 August 2019, 01:37:35 by pott »
Offline pott
Re: Flashing a UT47.2 through QMK GUI + Toolbox: doable?
« Reply #1 on: Sat, 31 August 2019, 14:53:06 »
Flashing worked just fine, and new keymap is uploaded. Some stuff is weird, that's for another thread.
Offline mchaput
« Reply #2 on: Sat, 28 September 2019, 23:48:38 »
How did you get the UT47 into DFU mode? I just put together my UT47.2 kit, and supposedly you can hold down ESC while plugging in to trigger the bootloader, but it's not working for me.
QMK toolbox keeps saying:
*** Keyhive - UT47.2 disconnected -- 0xFEED:0x0
*** Keyhive - UT47.2 connected -- 0xFEED:0x0
...but it never sees the device ready to flash.
Offline walletburner
  • Formerly wokechill
« Reply #3 on: Sun, 29 September 2019, 12:06:04 »
if you're having trouble, the peeps in the 40% discord should be able to help! https://discord.gg/NKjgFxj
Offline pott
« Reply #4 on: Wed, 02 October 2019, 13:25:40 »
There's a reset button at the bottom of the PCB.
You can also map one of the keys/key combinations to Reset the board (I've not tried it on UT47.2, but it's worked on another of my QMK boards).
I used QMK Toolbox for everything: I check 'auto-flash' or whatever it's called, press the physical Reset button, and then it's all automatic from there.
