Author Topic: Best USB Hubs?  (Read 6694 times)
Offline didjamatic
Best USB Hubs?
« on: Thu, 03 June 2010, 16:32:18 »
What are the best USB hubs you've seen/wanted/used?
Powered vs Passive?
Cool expensive USB hubs at Thinkgeek
Cheap usb hubs at Meritline
Popular usb hubs at Amazon
Offline ricercar
  • mostly abides
Best USB Hubs?
« Reply #1 on: Fri, 04 June 2010, 11:55:24 »
7-port powered.
Offline maxlugar
Best USB Hubs?
« Reply #2 on: Fri, 04 June 2010, 14:10:11 »
This is one of the better, more expensive powered USB hubs I've come across.  I like the multiple format memory card reader feature.  I'm probably one of the last few holdouts who still uses compact flash memory (in my iPAQ 210) and it's not easy to find many CF readers these days.
http://www.iogear.com/product/GUH286/
A low cost self-powered hub I use at the office is "Cables To Go" 4 port hub.   There doesn't seem to be a model number on it.  I can attach multiple vintage keyboards (Model Ms, Model Fs) using Blue Cube USB adapters to this hub without experiencing any problems.
Emperor of the IBM 84-key AT Model F Darkside
Offline didjamatic
Best USB Hubs?
« Reply #3 on: Fri, 04 June 2010, 14:13:04 »
I still use CF as well...
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
Best USB Hubs?
« Reply #4 on: Fri, 04 June 2010, 14:37:49 »
I've had hit/miss success with cheapo ebay hubs...vast majority are just fine, but some are baaaad.
Something common to all the cheap ones though...if you unplug it and then immediately replug, even in a different port, it 'malfunctions' (as Windows says). Seemingly you need to let all the electricity "dissipate" before plugging it back in or it goes wonky.
I have a 7 port powered hub off ebay like this. It's also covered in bright colourful LEDs. Works great even with high draw devices but has that weird replugging symptom.
I also have a neat 4 port one where the ports can swivel out the side...gimmicky, but saves space in laptop bag.
« Last Edit: Fri, 04 June 2010, 14:40:18 by kishy »
kishy.ca
Offline mr_a500
Best USB Hubs?
« Reply #5 on: Sat, 05 June 2010, 13:22:06 »
Handy thread... I was just wondering what powered hub to use with my Amiga 3000.
Quote from: maxlugar;189622
Thanks. I'll check that out. I got a cheapo Chinese multi-card reader that totally fell apart a few minutes after I got it. I bought it mainly for reading CF cards (my Amiga 500 CF), but the damn CF port didn't work on the adapter. Then the solder holding the SD slot fell off and the microSD pins broke. I guess I can't expect much for $1, though.
Offline InSanCen
Best USB Hubs?
« Reply #6 on: Sat, 05 June 2010, 15:08:52 »
Hubwise, I use a Maplin own brand 13 port powered. As I too am a CF holdout, I use a separate cardreader, amongst other on it.
Works fine for me, and I have just tried to duplicate Ripsters "Plug, Unplug" error, but it just registers the device as expected, which is good, as I am prone to "aww, crap, forgot to..." moments, meaning it goes straight back in the port.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
Offline chimera15
Best USB Hubs?
« Reply #7 on: Sat, 05 June 2010, 19:41:51 »
My favorite is a cyberpower cp-h420p.   It's only 4 port, but it's got a nice 2.6 amp powersupply with it, and I rarely have any power consumption issues with it which most other hubs I have do have.
http://www.cyberpowersystems.com/products/accessories/usb_hubs/cph420p.html
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline iMav
  • geekhack creator/founder
Best USB Hubs?
« Reply #8 on: Sat, 05 June 2010, 21:05:32 »
I need a 10+ port USB hub (powered).  I seem to go through cheap ones pretty quickly  (buy a new one every year it seams).
Anyone use the 16 port "super hub" from ThinkGeek?  I'm seriously thinking of buying it (and hoping it lasts)
Offline TexasFlood
Best USB Hubs?
« Reply #9 on: Sat, 05 June 2010, 22:30:29 »
Quote from: iMav;190044
Biggest one I have is a D-Link 7 port which works well.  There are a few different models of Koutech 10 & 13 port USB 2.0 Hubs hubs on Newegg with positive ratings.  I have no personal experience with these or the ThinkGeek 16 port one though.
Offline didjamatic
Best USB Hubs?
« Reply #10 on: Sat, 05 June 2010, 22:33:45 »
Here's a "16 port USB hub" on ebay for only $.99
Offline didjamatic
Best USB Hubs?
« Reply #11 on: Sat, 05 June 2010, 22:58:09 »
It looks like CyberPower makes a 7 port as well.  I've been very happy with one of their 1500va UPS's for home use.
I'd like to hear more details on the MSFT changes in Win7, so far I've been very impressed with 7's support of hardware on my laptop, still on XP on home PC.
Offline TexasFlood
Best USB Hubs?
« Reply #12 on: Sat, 05 June 2010, 23:09:04 »
Quote from: ripster;190093
This was interesting in that Koutech review.
Maybe that was the problem with my Dlink DUB-H7.  I put it on my HTPC since it didn't disconnect MP3 players properly on my main PCs.
That looks like my D-Link 7-port.  I don't have Windows 7 yet so haven't tried that yet.  I plan to put Windows 7 on my WMWare workstation box once I build it though, if I ever get to it, :sad:  That motherboard supports USB 3.0, on at least some of the ports I think, for whatever it's worth, which I suspect isn't much.
Offline mr_a500
Best USB Hubs?
« Reply #13 on: Tue, 03 January 2012, 09:25:00 »
Did you ever get one of those? I just bought one on sale. Even half price it was damn expensive. It better be worth it.
(yes, this is a zombied thread...but I also bought a zombie at ThinkGeek)
« Last Edit: Tue, 03 January 2012, 09:41:34 by mr_a500 »
Offline czarek
  • Keep the momentum going!
    • FalbaTech
Best USB Hubs?
« Reply #14 on: Tue, 03 January 2012, 09:32:44 »
I've got couple of those DLinks (4 and 7 ports versions). Never had any single issue with them. Great hubs.
Offline davkol
  •  Post Editing Timeout
Best USB Hubs?
« Reply #15 on: Tue, 03 January 2012, 12:33:23 »
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum
« Last Edit: Tue, 03 July 2018, 08:19:05 by davkol »
Offline nar
Best USB Hubs?
« Reply #16 on: Tue, 03 January 2012, 12:50:44 »
I use this. The Ultra ULT31808
As I usually use both a desktop and a laptop, the dual computer thing is awesome.
Keyboards: Topre HE0100 | REALFORCE 103UB & 104UB-DK | FILCO Majestouch 2 Ai Cherry MX Blue | CHERRY G84-4101SPAUS
Offline sordna
Best USB Hubs?
« Reply #17 on: Tue, 03 January 2012, 13:10:10 »
I use a Targus PA050U 4-port USB hub. It's powered, but I use it without the power supply it came with; as long as you don't hook up power hungry hard drives it works fine! I tried a webcam, a keyboard, and 2 usb sticks at the same time without power and they worked without a hitch! Can't beat it at just 5 bucks on amazon.
