Author Topic: Siemens Q500 QUME with 4P4C connector  (Read 12896 times)
Offline Mikhail
« on: Mon, 02 September 2019, 15:04:46 »
Hi there! I became the happy owner of this keyboard!
Its vintage Cherry blacks
Double shot ABS
New old stock, good condition, only dust.
Got as gift!
But, it have a 4P4C connector, and people says that it's "Keyboard from the terminal for programming automatic telephone exchange by Siemens" and it's can't work with PC.
I've tried to connected into PS/2 like https://geekhack.org/index.php?topic=51079.0
and any other pin-out. Don't work.
As I understand, I need to make an active converter. I found a specialist who could develop one, and he requested ~ $ 170.
I find it economically unprofitable.
Can I find ready-made solutions - buy existing ones, find schemes for self-assembly? Any suggestions?
« Last Edit: Sat, 06 March 2021, 17:09:58 by Mikhail »
Offline yui
Re: Siemens Q500 QUME with 4P4C connector
« Reply #1 on: Thu, 12 December 2019, 09:44:15 »
I did not see your post earlier (only just followed a link in an other post) but from what i've read online it seems to by a wyse keyboard, so using soarer's wyse converter (https://geekhack.org/index.php?topic=52597.0) or maybe rewiring it with a tmk or qmk controller
Offline Mikhail
« Reply #2 on: Sat, 06 March 2021, 17:08:36 »
Today i tried Soarer_WYSEverter_v1.30 with Teensy 2.0. Not work. Hid listen:
Listening:
remaining: FFFC
WYSE...
error: WYSE clock low - not connected?
Keyboard ID: 0000
Code Set: 2 (extended)
Mode: AT/PS2
Also I tried replace clock and +5V like http://www.kbdbabel.org/conn/kbd_connector_qvt2xx_qx15.png
Also not work((
Offline yui
« Reply #3 on: Wed, 10 March 2021, 03:03:06 »
then maybe the best option would be to either retro-engineer the protocol (harder without specs or a computer to talk to) or to retrofit it with a QMK pro micro/teensy and retrace the matrix, it also mean removing that vintage intel microcontroller though.
or you can also sell it but it will likely be destroyed for its switches by the next owner, because peoples still harvest vintage black switches for some reasons.
Offline Mikhail
« Reply #4 on: Wed, 10 March 2021, 04:49:30 »
(I was able to ring + 5v and ground to the controller, ground - pin 4, + 5v - pin3. Not like Wise. I tried the remaining two options for connecting date and clock, both did not work with the firmware for Wyse and for IBM.)
Switches i already harvested and changed with MX Blue))
But anyway this keyboard have good sound even with MX Blue!
I want make it work with PC and return to who give me.
I can draw a schematic how's matrix traces goes to the controller. I would be cool if someone tells me after how connect teensy 2.0 (or something) to old controller place and make .hex file!
« Last Edit: Wed, 10 March 2021, 04:55:02 by Mikhail »
Offline Edelman
« Reply #5 on: Wed, 28 February 2024, 04:04:00 »
Do you find any solutions yet?
Offline Mikhail
« Reply #6 on: Wed, 28 February 2024, 08:37:52 »
No.
Also I seen din-5 versions of this kb on Taobao
Offline TomahawkLabs
« Reply #7 on: Wed, 28 February 2024, 09:04:03 »
No.
As someone who has gutted a full size board and handwired it to work on modern USB systems, that's my vote. It'll cost you more than $170 in your own labor/time, but once it's handwired you can add modern controllers for more fun. I did lose out on the LED features since I removed the PCB which was how they were mechanically connected in place so they were removed from the final build.
Something to consider if you cannot find a way to convert the signal.
Always looking for Alps SKCM/SKCL switches. Feel free to DM.
AMD 5600x | RTX3080 | 2x 1TB NVME + 4x 4TB HDD | B550M Pro-P | 32GB RAM | RM850x | Node 804 | Schiit Modius/Magnius + Audeze LCD-2 | 2x Dell S3422DWG
GMMK 1 Full Size Barebones | Zealio 67g ; Apple M3501 handwired | Alps SKCM Damped Cream
SA: Camping
