Author Topic: Cleaning White Keycaps Trick!  (Read 11317 times)
Offline OnTheBrink
  • Work Hard. Play Harder.
    • Wired In Store
« on: Sat, 07 September 2019, 13:19:31 »
Sorry if someone discovered this before me but I discovered a really good way to clean white PBT keycaps .
The Magic Eraser!
Check out the difference in this photo. I couldn’t get the black scuff and stains off but it came off with ease using the Magic Eraser:
Offline Benitone
Re: Cleaning White Keycaps Trick!
« Reply #1 on: Sat, 07 September 2019, 14:11:29 »
ultrasonic cleaning works too, with ink and graphite
« Reply #2 on: Sun, 08 September 2019, 22:04:44 »
That requires a lot of effort.
And you'd have to repeat it for 84+ tiny pieces of plastic.
I've found that soaking in warm water with a couple of denture tabs works well, and I can give them a quick scrub with a toothbrush when taking them out, in case there is any ingrained dirt.
Offline _rubik
« Reply #3 on: Sun, 08 September 2019, 22:31:49 »
Denture tabs or bust.
Offline OnTheBrink
    • Wired In Store
« Reply #4 on: Mon, 09 September 2019, 16:25:57 »
Unless I'm missing something (not being rude), it seems like your method takes more time tbh. I literally just took each key and swiped with the barely moist magic eraser once or twice and the dirt was gone. Took me like 20-30 mins to do 70 keys.
« Reply #5 on: Sun, 15 September 2019, 22:07:07 »
Do yours end up smelling minty fresh?
Mine do :D
I only scrub the really bad ones, thinking of those two Model M keyboards I got a while back, one was really dirty.
Usually I spread the keycaps out on a sheet of newspaper to dry while I am cleaning the rest of the keyboard.
Doesn't take much time at all.
And, more importantly, not much effort.
