Author Topic: New to Vintage Mechanical Keyboards  (Read 3667 times)
Offline TheBasic
« on: Thu, 12 September 2019, 16:29:18 »
Hi,
I've recently been looking at a lot of vintage keyboards on Ebay because they've caught my eye. I love gaming, is there a good vintage keyboard you would recommend to me? I've no idea which ones are good and which ones are ****.
Many thanks
Rhys
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: New to Vintage Mechanical Keyboards
« Reply #1 on: Fri, 13 September 2019, 13:06:21 »
Welcome :)
Whichever keyboard feels good to you isn't ****.
Offline TheBasic
« Reply #2 on: Sat, 14 September 2019, 07:41:13 »
Yea but you do have any models to advise so I dont waste my money?
Offline ideus
  • Björkö.
« Reply #3 on: Sat, 14 September 2019, 08:01:18 »
You can do well with any board carrying blacks. You may ask the seller to remove one key and send you a picture to verify it.
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #4 on: Sat, 14 September 2019, 10:00:02 »
Look for Cherry G-80XXXX models for pretty decent PCB mounted boards from Cherry with super awesome keycaps. Almost any older ALPS boards that can be easily made to work over USB (Apple AEKs & AEKIIs, Dell bigfoots with the linear mod on SKCM blacks, etc.) are all a good choice too if you can find a clean one. The cleanliness of ALPS switches is super important as they are a little more sensitive to dust getting into them & gunking up the works. I've gamed on a good bit of the mentioned boards & didn't have any issues with them. Hope this helps you out a bit!
Offline TheBasic
« Reply #5 on: Sat, 14 September 2019, 17:32:02 »
Thanks man, really appreciate it!
