Author Topic: GK61 software not working anymore  (Read 35841 times)
Offline SabreRed
« on: Sun, 15 September 2019, 18:11:26 »
My GK61 just came in the mail and within hours of using it started, disconnecting and reconnecting every few second and now the software wont let me apply any keybind or change RGB kighting. Any suggestions are welcome thanks in advance.
the keyboard I bought: https://www.amazon.com/dp/B07PT9NRRY/?coliid=I2E4VI6XM89A0F&colid=20829KCRKSVE6&ref_=lv_ov_lig_dp_it&th=1
Keyboard Driver: www.jikedingzhi.com/downloadlist?driverID=41
Offline pixelpusher
Re: GK61 software not working anymore
« Reply #1 on: Sun, 15 September 2019, 20:13:27 »
Hmm.  Did you try a different cable?  Worth a try
Offline SabreRed
« Reply #2 on: Sun, 15 September 2019, 20:52:43 »
I don’t have another usb-c right now but I can pick one up later, but i’m pretty sure it’s something I did when I was setting up an RGB profile
Offline pixelpusher
« Reply #3 on: Sun, 15 September 2019, 22:10:46 »
This same board is sold a few different places. I bought mine through the group buys posted here on geek hack. The vendor site is here with software downloads:
http://www.pc-100.com/downloads-mechanical-keyboard/
I believe you have to log in to see the page, which is silly.  But maybe try that version of the software.
Offline avrteck
« Reply #4 on: Wed, 08 July 2020, 11:47:16 »
I just had the same issue. I tried applying a light effect but the software crashed and now my gk61 connects and reconnects all the time and the software doesn’t recognize my keyboard. It’s been a while since you posted this but have you found out a solution?
