Author Topic: Removable Switches  (Read 2178 times)
Offline tedfs3
    • No Mercy Given
Removable Switches
« on: Sun, 15 September 2019, 21:33:07 »
Are there any other full keyboards with removable switches like the Redragon K551-N ? Just discovered this inexpensive testbed for different switches and am wondering if there are any other options out there similar or better.
Offline woodruff
Re: Removable Switches
« Reply #1 on: Mon, 16 September 2019, 09:39:35 »
gmmk is superb (60%, tkl, 100%, ansi and ISO)
https://www.pcgamingrace.com/products/gmmk-full-customized
There is also the hexagon something (ansi only).
Offline tedfs3
    • No Mercy Given
« Reply #2 on: Thu, 19 September 2019, 20:04:30 »
Is it possible to turn the RGB stuff off on that one or no RGB at all ? That looks promising.
