Author Topic: Open source Kailh Hot-swap PCB  (Read 4755 times)
Offline tedfs3
    • No Mercy Given
« on: Sun, 15 September 2019, 22:03:53 »
Are there any open source designs using the Kailh Hot-swappable sockets ? I just discovered the Redragon K551 and it's implementation of hot swap aren't the best but it does work. Looking at studying better options and designs if possible.
Offline equalunique
Re: Open source Kailh Hot-swap PCB
« Reply #1 on: Sun, 15 September 2019, 22:14:17 »
Here's the most prominent example I know of. It's split/ergo/40% - https://github.com/foostan/crkbd/tree/master/corne-cherry
Sent from my Ono-Sendai Cyberspace 7 using Tapatalk
Offline nevin
« Reply #2 on: Sun, 15 September 2019, 22:31:49 »
wow. super tiny split ergo
love it!
Offline equalunique
« Reply #3 on: Sun, 15 September 2019, 22:45:26 »
love it!
It can go smaller! One can actually break off the outer columns of each half, making it the same size as a minidox.
Offline nevin
« Reply #4 on: Sun, 15 September 2019, 22:53:49 »
don't think i'd be able to go that small unless all i did was write. but cool nonetheless.
Offline tedfs3
    • No Mercy Given
« Reply #5 on: Sun, 15 September 2019, 23:21:20 »
No footprints in that but I'll check it out more.
Offline CaninoDev
« Reply #6 on: Mon, 16 September 2019, 03:17:21 »
Check out https://github.com/jmdaly/CO60
