Author Topic: [IC] 8008 Ink Switches | GB STARTS SEPT 6TH!  (Read 59652 times)
Offline alper_maestro
Re: [IC] 8008 Ink Switches ARE NOT DEAD! BIG UPDATE!
« Reply #100 on: Fri, 14 August 2020, 17:48:59 »
Finally  :)
Offline Techlet
« Reply #101 on: Fri, 14 August 2020, 18:39:22 »
So, has there been any word from Gateron confirming that these are indeed actual Inks?
Curious to find out if these will have the same sound, and also if these will be plagued with loose leaves and very inconsistent scratchiness as later batches of Inks.
« Last Edit: Fri, 14 August 2020, 18:49:43 by Techlet »
Offline Omarpixel9
  • I like keyboards and pixels
« Reply #102 on: Mon, 17 August 2020, 04:03:31 »
I'm curious as well. I feel like we need more details on these.
60% gasket mount
Offline Domantas
« Reply #103 on: Wed, 19 August 2020, 16:35:46 »
wants this, but also want to be sure it is ink. Maybe just make transparent grey housing and pink stem to make it more obvious it ink ? :/
« Last Edit: Tue, 25 August 2020, 16:16:06 by Domantas »
Offline Domantas
« Reply #104 on: Thu, 03 September 2020, 08:13:35 »
Nice, these look great. Will there be an EU Proxy for the GB?
+1
Offline GarrettSucks
  • All project timelines at at timelines.omnitype.com
    • Omnitype
Re: [IC] 8008 Ink Switches | GB Starts Sept 6th!
« Reply #105 on: Thu, 03 September 2020, 20:02:10 »
Hey! Just coming in to let yall know info on the GB! Will make a GB thread tomorrow :)
GB Dates: Sept 6-20
Unlimited GB
$0.75 a switch
Proxies:
Dixie Mech
Mykeyboard.eu
iLumKB
Daily Clack
Offline Stev!e
« Reply #106 on: Thu, 03 September 2020, 20:07:56 »
Hopefully the keycap set will return someday as well :D
Offline L8T
Re: [IC] 8008 Ink Switches | GB STARTS SEPT 6TH!
« Reply #107 on: Thu, 03 September 2020, 20:58:01 »
And how long will it take for me to receive it if i decide to buy it? like 2 months or more than that?
Offline Domantas
« Reply #108 on: Fri, 04 September 2020, 12:12:17 »
+1
Offline ab042896
« Reply #109 on: Fri, 04 September 2020, 12:17:08 »
What weight(s) are going to be offered?
Factory lubed or no?
Offline titanium
« Reply #110 on: Sun, 06 September 2020, 00:28:09 »
The samples that TaehaTypes trialed on his stream were not lubed. Going to be same springs as gateron yellow so 63.5g slow
