Author Topic: Stuck with converting AEK II to USB.  (Read 2340 times)
Offline SebFindsWeirdThings
« on: Sat, 21 September 2019, 06:22:56 »
Hello guys,
I've been trying to convert this Japanese AEK II to USB using pro micros for a few weeks now and I'm starting to think that the whole keyboard might just be dead.
I've got images showing what I have at current time -
With this setup, the AEK flashes its LEDs and doesn't respond afterwards. I have a feeling the black cable (labeled as PSW or Power On) might have a place on the pro micro, but I honestly have no idea where to put it. I think I have the correct labelling for the cables anyway - tested it with a multimeter and all.
Any help would be appreciated - I'd love to get this board back to it's original glory.
« Last Edit: Sat, 21 September 2019, 07:14:07 by SebFindsWeirdThings »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Stuck with converting AEK II to USB.
« Reply #1 on: Sat, 21 September 2019, 06:55:13 »
I think you need to take the black wire to the #3 through hole & do not use the red wire. Basically reverse what you got going on with those 2 wires right now. I've never USB converted an AEK myself, but I do have a ADP cable that someone converted with a Pro Micro that came with an AEK I bought. That is the only difference in the way mine is wired vs yours at least.
Offline Tactile
« Reply #2 on: Sat, 21 September 2019, 07:00:49 »
You'll need all four wires connected. The best place for instructions or to ask questions would be in this thread.
REΛLFORCE
« Reply #3 on: Sat, 21 September 2019, 07:04:26 »
Thanks, I'll try that now
Offline Rob27shred
« Reply #4 on: Sat, 21 September 2019, 09:15:46 »
No problem! How did it go, did it get it working over USB doing that? Like I said before USB converting vintage boards is pretty far out of my wheel house. Although considering the ADP to Pro micro cable I got is set up almost the same way with the just the black & red wires switched I figured it was worth a shot. Tactile's comment does make a good bit of sense, but if it had to have all 4 wires connected I'd imagine my ADP to Pro Micro cable wouldn't work. Since it just has 3 wires connected & the red wire sniped down by the sheathing.
