Author Topic: Hello, I'm a Topre Addict  (Read 3202 times)
Offline Phantomk
  • Coffee Specialist
« on: Sat, 21 September 2019, 19:43:20 »
Hello everyone!
Psstt.... you, yeah you... got any of that Topre stuff?
but yeah, I have an HHKB Type S and a FC660C, still looking to add more.
Thank you for coming to my TED Talk.
« Last Edit: Sat, 21 September 2019, 22:33:31 by Phantomk »
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Hello, I'm a Topre Addict
« Reply #1 on: Sat, 21 September 2019, 21:20:31 »
Welcome, but no you can not have my Topre! :p
Offline _rubik
« Reply #2 on: Sat, 21 September 2019, 22:44:32 »
Can't call yourself a Topre addict until you've added a 55g Realforce  ;)
Looks like I also know what's next on your list. Welcome!
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
« Reply #3 on: Sat, 21 September 2019, 23:36:04 »
Topre you say?...I love me some topre. Welcome fellow Texan!
Offline ihateregister
  • I like cookies. Yum!
« Reply #4 on: Mon, 23 September 2019, 10:46:24 »
Huge Topre fan, tried many many keyboards... steelseries, corsair, coolermaster, logitech, ducky, deck keyboards, etc (Cherry Reds, Browns, Blacks, Romer, etc)
I now own three full size Realforce RGB keyboards, all modded exactly the same.. with the hypersphere silencers, small 0.5 mm spacers on the support stems (so I get the full key travel range), and lubed with thick "Finish Line Extreme Fluoro 100% DuPont Teflon Grease" (I use roughly 6 grams per keyboard). I want to go away from ABS, and switch all the keycaps with the double thick backlit PBT keys from Ducky.
My next project is to install USB-C support via a sparkfun USB-C breakout board with a 5-pin 2.0mm JST-PH connector, and a 5mm (ID) Magnetic Ferrite Core Cord RFI EMI Noise Suppressor Cable Clip, and a custom built zap cable with a QD 5-pin Aviator cable.
I've seen people wear out USB connectors on bluetooth mouse often, I don't want that to ever happen to my Realforce RGB keyboard.. yeah, I'm weird.
