Author Topic: Unicomp M Replacement Controller  (Read 1757 times)
Offline ManOnTheMetalIsland
« on: Tue, 24 September 2019, 01:08:19 »
I've got a Spacesaver M and the computer will not recognize it. I've changed the USB cable, but it still will not work. Are there any replacement boards available?
Thanks
Offline yui
Re: Unicomp M Replacement Controller
« Reply #1 on: Tue, 24 September 2019, 03:42:28 »
What did you actually get the Unicomp mac model or the IBM SSK (Space Saver Keyboard, TKL version of the M)?
For both Unicomp should be able to help you (20 usd for a replacement controller from the last mail i got from them), or there also exist a custom Bluetooth M controller for older sdl style M that someone here makes and sells on ebay.
« Reply #2 on: Tue, 24 September 2019, 16:41:25 »
Mac model. I emailed Unicomp like you suggested and I'm waiting for a response.
