Author Topic: Topre keycaps  (Read 50666 times)
Offline LightningXI
  • PPD
    • ArtisanMacro
Re: Topre keycaps
« Reply #50 on: Tue, 12 May 2020, 00:46:49 »
https://www.realforce.co.jp/en/products/R2-US-KT/index.html
Yeah R2 keycaps are officially on sale, not sure where to get them yet though.
That's nice. Wish they also did blanks.
Offline opensecret
  • 公开的秘密
Re: Topre keycaps
« Reply #51 on: Mon, 25 May 2020, 15:10:12 »
Domikey is offering a few different sets of Topre keycaps, both on their own site and at Amazon. They’re ABS double-shot, and designed for the HHKB.   A set with blue kecaps, and gray and yellow modifiers, for example, is at:  https://www.amazon.com/doubleshot-Atlantis-Mechanical-Keyboard-Professional/dp/B07WJ2DZJP/ref=sr_1_1?dchild=1&keywords=topre%2Bkeycaps&qid=1590435527&sr=8-1&th=1.
Does anyone have experience with these?
" alt="" class="bbc_img" />
IBM Model M |Matias Mini Quiet Pro|Plum 84EC-S|RealForce 103U-UW & 87U-UW|Omnikey Ultra T| 2 Omnikey Ultras| WASD V2| Xmit Hall Effect|
Offline btctopre
Re: Topre keycaps
« Reply #52 on: Mon, 25 May 2020, 17:46:21 »
(Attachment Link) " alt="" class="bbc_img" />
comment i made about them on leddit a few months back-
i never got the full set on the board (i started with replacing the bottom row keycaps, and as soon as i saw the height difference i stopped putting them on), but here's a quick comparison for you.
height/profile comparison (against realforce keycaps)-
* top row: similar profile but domikeys have less cup to them (so they're flatter/look like they have more surface area), and they are slightly taller
* second row: same as above, except domikeys are noticeably taller
* third row: same as above, except domikeys are even more noticeably taller
* bottom rows: profile is definitely less angled, and domikeys are yuge in comparison
* quick crappy pic of all rows so you can see-https://i.imgur.com/elFnrZO.jpg
keycap texture comparable to worn keycaps (so opposite of kbdfans super texture sets), thickness is comparable, and keycap noise is a slightly higher tone (but it seems so negligible that you wouldn't notice a difference after a day of typing on them).
*edit- i should note that the sound comparison was done on purple sliders in a hhkb.*
all-in-all, they seems fine if you use the set as just the set, and don't plan on doing any mix/matching with rf/pfu/kbdfans sets and/or artisans based off of the profiles of those sets.
