Author Topic: NEC APC-H410E Keyboard Clean-Up  (Read 2858 times)
Offline OldIsNew
« on: Thu, 26 September 2019, 22:30:52 »
I've been curious about NEC blue oval switches so when I came across this board for a decent price, I went ahead and picked it up. As appears to be common, the board was severely yellowed but otherwise in good shape.
227053-0          227055-1          227057-2
There was moderate gunk inside but not too bad:
227059-3         227061-4         227063-5       227071-6
I did read in other posts about using care to remove the keycaps from these switches, but despite trying to be careful I did manage to pull the top off the F9 switch. After tracking down the spring, the switch was not difficult to reassemble and luckily the top switch cover plate  didn't break so I was able to just snap it back in place. Part of the lower switch cover plate is missing but it hasn't caused a problem and the switch works fine (I guess until dirt gets in it anyway).
227069-7
I retrobrighted the case and keycaps and got pretty good results:
227067-8
The light keys are grey double shot and the dark keys are black double shot.
The board works well with an AT to PS2 adapter to Blue Cube and also works with the PS2 keyboard/mouse converter I got off Amazon now that the original Blue Cube no longer  seems to be available.
227073-9
I really do like the blue oval switches and should be getting some decent use out of this board.
« Last Edit: Thu, 26 September 2019, 22:34:55 by OldIsNew »
Re: NEC APC-H410E Keyboard Clean-Up
« Reply #1 on: Fri, 27 September 2019, 03:14:08 »
Good to see an old board that wasn't absolutely filthy when rescued, I might have been tempted to keep the yellow look as it appeared to be even throughout though it looks great brightened too.  Enjoy :)
Offline invariance
  • ...here with all the other boson's
« Reply #2 on: Fri, 27 September 2019, 04:16:32 »
Nice work  :thumb: :thumb:
The only BS I
want to hear is
from a Model M:
PN:1391401
DOB: 04FEB87
      Wyse 85      Mtek K104
SMK Blue: Chicony KB-5181; HyperX Aqua: HyperX Alloy Origins *Yet-to-rebuild: A 69 key C. P. Clare Foam & Foil assy *Rubber: Digital LK46W-A2; uSoft Natural Pro RT9401, Natural Multimedia 1.0A RT9470, Natural Ergonomic 4000 KU-0460; "Avid" Sejin SLKR2233; "Diamond Touch" Mitsubishi 6511-PB
