Author Topic: Good Cable Brands?  (Read 2063 times)
Offline filcomanfilthy
Good Cable Brands?
« on: Sat, 28 September 2019, 09:30:44 »
Hi, Im looking for a good cable that i can buy offline. I would like it to be USB-C male to USB-A male. I am wondering about customs as well as ones you can just buy as they are. What are your favorites? I am extremely adamant about material and am looking for the sturdiest, most durable sleeving material. Anything helps, and thanks!
Filthy
Re: Good Cable Brands?
« Reply #1 on: Sat, 28 September 2019, 09:31:16 »
... that i can buy online
Filthy
« Reply #2 on: Sat, 28 September 2019, 10:28:30 »
I can't speak to your extreme requirements, but I have had good experience with upper line Ankers.
- D Trump 2026-09-28
Offline Techno Trousers
  • ʘ_ಠ
« Reply #3 on: Sat, 28 September 2019, 11:54:35 »
Not sure if Drop will run these steel braided cables again. You might be able to find an equivalent somewhere else. I can't imagine there would be a sheathing material more durable.
https://drop.com/buy/logiix-piston-connect-steel-braided-cables
Offline lolafineday
« Reply #4 on: Sun, 29 September 2019, 05:46:33 »
Pexon cables, coolcable, zap cables, summitcables etc...
Sent from my SM-G975F using Tapatalk
Offline Steezus
  • Keeper of Facts
« Reply #5 on: Sun, 29 September 2019, 14:04:14 »
I personally have always been a fan of Pexon's cables. In fact, I had just put an order in for two more cables recently. I always go with a double sleeving of paracord and then techflex. The double sleeving really helps the cable "remember" it's initial shape, especially with coiled cables. Now I have been away from the keyboard scene for a bit and noticed a lot more companies popping up. I found most places to be back-ordered and are opening up slots on a biweekly basis. So it may just come down to going with whoever is available at the time.
