Author Topic: Tactile equivalent of Box Pink  (Read 2366 times)
Offline Statement
« on: Thu, 03 October 2019, 17:47:10 »
Hi all, currently only just starting to fall down the rabbit-hole of keyboards and and currently trying to find my perfect tactile switch.
Currently I have bought two GMMK compacts (one for work and one for home) so I can easily try various switch types.
I've settled on that I definitely want clicky switches for home. Started with Gateron blues (which I liked more than an older board with cherry blue), and recently bought a set of Box Pinks which are an amazing upgrade and seem be at a nice point between tactile enough for typing, but ignorable enough when mashing in games, stiff enough to not bottom out, but not too fatiguing, not to mention the click is a much nicer sound than blue's. I feel like it may be difficult to find something I enjoy more than this.
For my work board I started with Gateron browns (okay, but a bit light and not enough tactility overall) and have since moved to Hako Royal Clears which I quite like, but are a bit fatiguing. I think after using this for a few weeks I would prefer some pre-travel and a bit lighter overall.
Anyone have any suggestions on what the closet tactile switch to box pinks would be?
Offline Venaros
Re: Tactile equivalent of Box Pink
« Reply #1 on: Thu, 03 October 2019, 19:35:01 »
Other clickbar switches, like Box Pale Blue or Jades.
Offline Kevadu
« Reply #2 on: Thu, 03 October 2019, 23:53:04 »
Those wouldn't be tactile...
That said there really is no tactile equivalent of clickbar switches.  The sharp, clean bump of the clickbars doesn't exist in the tactile world.
Offline IOVERCALLHISTIOCYTES
« Reply #3 on: Fri, 04 October 2019, 01:38:00 »
Try a Zealio, novelkeys has a sampler pack of zilent zealios tealio and healio. I use navies and like the big click bar, but use novelias or zealios if I need to share an office.
Offline Venaros
« Reply #4 on: Fri, 04 October 2019, 16:23:30 »
Yeah, I didn't really read the post right.
Offline elli
« Reply #5 on: Fri, 04 October 2019, 16:57:42 »
maybe zealiostotles, if you can jailhouse those?
