Author Topic: [Pre-IC] Looking for feedback, SA "Red Planet"  (Read 15680 times)
Offline Freeaboo
« on: Fri, 04 October 2019, 11:51:06 »
Here is the current version of my first key set, "Red Planet". Looking for comments/criticisms to touch it up before I move into the interest check stage.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
Re: [Pre-IC] Looking for feedback, SA "Red Planet"
« Reply #1 on: Sat, 05 October 2019, 09:00:21 »
Looks good, you should add novelty kit with astronauts
Just my thoughts
Offline Freeaboo
« Reply #2 on: Sat, 05 October 2019, 13:40:16 »
I most certainly will, keep your eyes out for the IC!
Offline IOVERCALLHISTIOCYTES
« Reply #3 on: Sun, 06 October 2019, 08:25:26 »
I’d buy. Split spacebars plz.
Offline Techno Trousers
  • ʘ_ಠ
« Reply #4 on: Tue, 08 October 2019, 17:38:40 »
Needs a Mars rover novelty, for sure
Offline Freeaboo
« Reply #5 on: Fri, 11 October 2019, 12:20:43 »
Absolutely! (Now, just to figure out how to add that to my renders...)
Offline Freeaboo
« Reply #6 on: Fri, 11 October 2019, 12:27:19 »
UPDATE:
-profile switched to DSA, sorry if this upsets some of you
-the orange color used for the alphas has been darkened and muted a bit
-renders with blender!! (I know they're kinda dark, I'm still learning blender atm)
Cheers!
