Author Topic: Amy recommendations for a 65, 67, 75, or tkl case?  (Read 12096 times)
Offline pradyungn
    • Pradyungn
« on: Sat, 05 October 2019, 10:06:30 »
I'm looking for a good case that I can use in a build, preferably one that comes with a PCB or plate and is under 400$. The form factors I'd prefer are listed above, but my first preference is one of the 65 or 67 cases. Thank you!
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Amy recommendations for a 65, 67, 75, or tkl case?
« Reply #1 on: Sat, 05 October 2019, 10:44:46 »
The high profile aluminum Clueboard is a pretty premium 66% layout kit for the price ($229) IME. I love mine to bits & wouldn't hesitate to recommend it. Right now only the V2 kits are available while they finish up the design on the V4.5 kits so you may want to wait for those. Although I doubt there will be much difference in the looks of the two. V4.5 will probably just add layout options & further refine the integrated plate design it uses. https://clueboard.co/clueboard-66-v2
Offline pradyungn
    • Pradyungn
« Reply #2 on: Sat, 05 October 2019, 10:52:41 »
That looks like a great option!
Offline Rob27shred
« Reply #3 on: Sat, 05 October 2019, 11:49:56 »
Glad I could help!
Offline lolafineday
« Reply #4 on: Sat, 05 October 2019, 22:52:18 »
Check out the iron165, it's running its gb in a few weeks.
Sent from my SM-G975F using Tapatalk
Offline pradyungn
    • Pradyungn
« Reply #5 on: Sun, 06 October 2019, 02:29:02 »
That looks insane!!!
