Author Topic: If you could only have one?  (Read 6995 times)
Offline kwantz
« on: Sun, 06 June 2010, 22:17:41 »
If you could only have one keyboard to use for the rest of your life, what would it be?  also factor in durability, because this will the only keyboard you will ever get.....
what would it be
me the HHBk, i have never owned a top notch mechanical keyboard... but im going to say this, because of its looks lol. I cant even give a 100% honest answer since i have no experience. except for an old school apply keyboard from when I was a young child. It was a beastly 10 pound keyboard i bet
« Last Edit: Sun, 06 June 2010, 22:26:42 by kwantz »
Offline didjamatic
« Reply #1 on: Sun, 06 June 2010, 22:19:02 »
Northgate Omnikey
Offline iMav
  • geekhack creator/founder
« Reply #2 on: Sun, 06 June 2010, 23:06:07 »
The HHKB Pro 2.  If I could only have one keyboard, it would have to fill all roles.  Home use, portable, work, etc.
Superior key layout, portable, USB hub, removable cable.
Offline spolia optima
« Reply #3 on: Mon, 07 June 2010, 02:02:53 »
Ibm 1391401
keyboards!
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #4 on: Mon, 07 June 2010, 02:13:03 »
thirteen-aych-six-seven-oh-five
kishy.ca
Offline Tr0j4nM4x1mus
« Reply #5 on: Mon, 07 June 2010, 02:13:24 »
something with cherry switches (cause you can replace them) & double shots cause if it's yer only keyboard ever, not only will the letters never wear off but the keys are way thicker too
Keyboards - 4 Cherry G80-3000lscrc-2 (two with black DS keys one with black & white DS keys)
HHKB Professional white
2 ABS M1 (modded with complicated alps one with pinks & one with rubber bumper whites)
2 IBM Model M\'s one 89 & one 97
Dell AT-101W black (modded with rubber bumper whites- M1 keys)
Focus FK2001 with cover
Focus FK2000 with cover
Unicomp Model M black mighty mouse
Cherry G84-4100 white
Looking For - Compaq G80-1838
Offline Half-Saint
« Reply #6 on: Mon, 07 June 2010, 03:33:44 »
IBM Model M all the way!
IBM Model M (6) - Acer Alcatel 6312-KW - IBM Model M Space Saver - IBM Model M 122-key - Cherry G80-3000 (2) - IBM Model F AT - TG3 BL82A (2)
[SIGPIC][/SIGPIC]
_______________________________________________
My geek blog: http://onlyageek.blogspot.com/
Flickr: http://www.flickr.com/photos/mr_mayhem/
Offline ch_123
« Reply #7 on: Mon, 07 June 2010, 05:41:37 »
It's a tie between the HHKB and the M13.
Offline itlnstln
« Reply #8 on: Mon, 07 June 2010, 08:50:30 »
I would probably go with the Model M.  The Northgate would last you forever, but I don't think I could live with the ALPS switches.  My G80-1863 would come in at a close second.  The HHKB is nice, but I don't think it could be my only one.
Offline bhtooefr
    • bhtooefr.org
« Reply #9 on: Mon, 07 June 2010, 08:53:10 »
Existing boards?
Tough, but I'm leaning towards an EnduraPro.
Better would be a 104-key BeSpr board with a TrackPoint IV.
Offline Rajagra
« Reply #10 on: Mon, 07 June 2010, 09:20:57 »
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #11 on: Mon, 07 June 2010, 11:37:37 »
Quote from: kishy;190480
Just in case anyone failed to figure out what that is...
Quote from: ch_123;190503
...M13
kishy.ca
Offline bhtooefr
    • bhtooefr.org
« Reply #12 on: Mon, 07 June 2010, 12:15:30 »
That's the black M13, right?
Offline chimera15
« Reply #13 on: Mon, 07 June 2010, 12:17:55 »
Assuming I could get new switches for them when they wear out, siig minitouch's of course.  The layout is perfection. I've already bought a lifetime supply pretty much.  No other fully compact board has the ability to be a chameleon and change switches like the minitouch can.  I have some set with dampers, some set with light springs so the keys almost feel like montereys or blue cherries, and others with stiffer pure white or blue alps.  I can't conceive of a better board than it really.
The one alternative might be a deck with blue cherry's... I suppose that one might hold up longer as well.  I don't really like where the function key is placed on those though, or the non L shaped enter key.
« Last Edit: Mon, 07 June 2010, 12:33:38 by chimera15 »
Alps boards:
white real complicated: 1x modified siiig minitouch kb1903,  hhkb light2 english steampunk hack, wireless siig minitouch hack
white with rubber damper(cream)+clicky springs: 2x modified siig minitouch kb1903 1x modified siig minitouch kb1948
white fake simplified:   1x white smk-85, 1x Steampunk compact board hack
white real simplified: 1x unitek k-258
low profile: 1x mint m1242 in box
black: ultra mini wrist keyboard hack
blue: Japanese hhk2 lite hack, 1x siig minitouch pcb/doubleshot dc-2014 caps. kb1903, 1x modified kb1948 Siig minitouch
rainbow test boards:  mck-84sx
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #14 on: Mon, 07 June 2010, 12:22:46 »
Quote from: bhtooefr;190538
Yup. If only those white-on-black keys were still available...
kishy.ca
Offline JBert
« Reply #15 on: Mon, 07 June 2010, 16:31:22 »
A hybrid between the model F's mechanism and the guru-board's layout/trackpoint combo. Oh, and it's programming potential.
The storage list:
Currently ignored by: nobody?
[/SIZE]
Offline EverythingIBM
« Reply #16 on: Mon, 07 June 2010, 18:42:36 »
Either a Model F AT or a KB8923.
Offline nowsharing
  • Swoop
« Reply #17 on: Mon, 07 June 2010, 19:51:44 »
talk about SPOOKY girlfriends
And the world's creepiest father-in-law.  Great film.
Offline Pixel_Outlaw
« Reply #18 on: Tue, 08 June 2010, 09:09:02 »
Probably my Lexmark model M. The whole question of how long will USB be around comes into play here too but you did say if it could be used for the rest of my life. I love the detachable 10 foot long cord, perfect for keeping in the pocket or just hanging out with in the library. A keyboard is a friend one keeps at the fingertips!
Brown and black are the colors of cowardice. May my springs shake the heavens!
Offline ricercar
  • mostly abides
« Reply #19 on: Tue, 08 June 2010, 21:13:38 »
My modded Kinesis Contour Essential, Cherry Browns with Trackpoint, connects with ADB, AT, PS/2, USB compatibility, so I could use it with ANY machine that could power up on that desert island.
Offline Harry_Y
« Reply #20 on: Tue, 08 June 2010, 21:22:51 »
Quote from: didjamatic;190401
Northgate Omnikey
Yes, I should have never gave mine away.
Offline Infinite north
« Reply #21 on: Tue, 08 June 2010, 21:37:12 »
In 2 years your would be trying to open a coconut with the ipad not the other way around.
Offline Buckling_Summer
    • http://www.elitesportservices.com
« Reply #22 on: Sat, 19 June 2010, 18:28:40 »
Quote from: ripster;190644
From the OP....
I'd worry more about looks when it comes to having only one Girl than only one keyboard.
Saw this movie last night - talk about SPOOKY girlfriends.  I liked it.  But I like offbeat movies.
type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="640" height="385">[/youtube]
The ending was all the money!
BTW, do the letters on the SIIG wear off ?
PRESENT POSSESSIONS:
 Buckling Spings: IBM Model M 82G2383 Lexmarkian (1995) / IBM Model F PC-AT keyboard 84 keys (6450200)
XM Simplified 1 (Monterey K110 or AK-CN2 or Hua-Jie) Siig MiniTouch KB-1948 GeekHack Spacesaver edition
Offline chimera15
« Reply #23 on: Sat, 19 June 2010, 21:52:56 »
Quote from: Buckling_Summer;194788
No, they're not double shot, but the coloring goes far down into the key. It would take a lot of wear for them to come off.
You can look at this one:
http://cgi.ebay.com/VINTAGE-SIIG-MiniTouch-KB1903-Keyboard-Clicky-JKA10032-/200481700764?cmd=ViewItem&pt=PCA_Mice_Trackballs&hash=item2eada3fb9c
Looks like one of the heaviest used minitouch's I've seen. The keys are shiny, but the lettering's still there.
I've also sanded some yellowed keys I got with one of my kb1903's that was beat up, early from Bob, to try to get rid of the yellowing and make them blanks, and the lettering didn't dissappear till I was far down into the key.
« Last Edit: Sat, 19 June 2010, 21:58:28 by chimera15 »
Alps boards:
Offline gr1m
« Reply #24 on: Sat, 19 June 2010, 22:28:44 »
Quote from: ripster;191120
In the dessert island scenario other things are far, far, more important.
No! WILSOOOOOOOOON!
Offline Oqsy
« Reply #25 on: Sun, 20 June 2010, 00:59:05 »
The parameters of this hypothetical leave too much to interpretation...   I'd go with a NIB 42H1292 freshly bolt modded and internal usb adapter modded with a built in satellite world phone, solar panels for powering both, and a side-mounted case containing a fishing pole, LOTS of hooks and line, a swiss army knife, a magnifying lens, a water distilling apparatus, flares, LOTS of toilet paper, more flares, a backup satellite phone, a shortwave / HAM radio, a few more flares, a first aid kid, and brightly colored key caps to keep my spirits up.
[sigpic]Currently in use: Rosewill RK9000 and CH DT225[/sigpic]
"Private misfortunes make for public welfare."
Offline InSanCen
« Reply #26 on: Sun, 20 June 2010, 01:51:22 »
Black M13. Easy.
Currently Using :- IBM M13 1996, Black :
Currently Own :- 1391406 1989 & 1990 : AT Model F 1985 : Boscom 122 (Black) : G80-3000 : G80-1800 (x2) : Wang 724 : G81-8000LPBGB (Card Reader, MY) : Unitek : AT102W : TVS Gold :
Project's :- 122 key 1389620 Wireless ESP32 :
'Pooter :- Xeon E5-2680v4 : Machinist MR9A : 2x16GB DDR4 : Radeon RX6600 : NVME & Spinning rust :
