Author Topic: [GB] M0llY is Here  (Read 40193 times)
Offline TheKeyCompany
  • Because You Need the Feels...
    • The Key Dot Company
[GB] M0llY is Here
« on: Thu, 10 October 2019, 16:49:25 »
TheKeyCompany Presents: M0llY
We're thrilled to have you meet M0llY. It's a refined take on a timeless design and features an integrated USB-C hub. A fully Geometric replica of the Apple M0110A, this board is a shot of nostalgia turned up to eleven with a sleek modern revision.
https://www.youtube.com/watch?v=fj0qS_Urel0
https://thekey.company/collections/upcoming-releases/products/m0lly
What's Included
PCB
- QMK Firmware
- MX / Alps compatibility
- Based on the TKC1800 design; its bulletproof
- Matte black w gold silk screen
- You must solder switches, indicator LEDS, and in-switch LEDs (if used)
- All SMD components pre-soldered in factory
- 1 year TKC warranty
- USB-C output via hub
CASE/PLATE
- Aircraft Grade Aluminum 6061
- 7.5 lbs Unbuilt
- Top Plate Mount
- PVD Brass Plate, 1.5mm thick
- 7 degree typing angle
- PVD Brass Flower Weight
- PVD Brass Front Badge
- Gloss Black PVD Stainless Hardware
- Alps plates available as an add-on product
- Additional Plates, PCBs, and Front Badges are available
PLATES
BADGES
WEIGHTS
HUB
- Internal Hub Daughterboard
- USB-C output
- USB-A 3.1 input
- High Speed Data Transfer
- High Amp Charging
COLOR OPTIONS
Black / Silver
Black case. Bright Silver Plate, Weight, and Badge Finishes.
Black / Gold
Black case. Bright Gold (Brass) Plate, Weight, and Badge Finishes
Silver / Black
Apple Silver case. Black plate finish with a Dark Nickel badge and weight finish.
Pink / Black
Flat Out Fabulous pink case. Black plate Finish with a Dark Nickel badge and weight finish.
Blue / Silver
Aquatica Blue case. Bright Silver Plate, Weight, and Badge Finish
White / Black
E-White case. Black plate Finish, with a Dark Nickel Badge and Weight finish.
Get your fix for $449 for most colorways.
You asked, we deliver. White M0llY is available for $479. (E-White Coating)
LAYOUT CONFIGURATIONS
The M0llY features a Plethora of Layouts options as well as having a PCB that's both ALPS and MX compatible, with your choice of ALPS or MX plates at time of purchase!
Where Can I Order?!
M0llY orders begin Friday October 11th at 9pm EDT (GMT -4:00). Limit to 200 but this CAN increase based on demand. Expected time of delivery will be in Late March!
Thank you guys for your continued support of TheKeyCompany, and as always, we're proud to deliver a product that you guys can customize, adore, and be proud to put on your desk everyday, we strive to make it more than just an input device and we hope that's reflected in each and every one of our Products.
Show your support by showing M0llY in your GH Sig: (copy paste below into your signature page)
Code: [Select]
[url=https://thekey.company/collections/m0lly][img width=300 height=120]https://i.imgur.com/cX7uAC7.jpg[/img][/url]
Mod Edit: Added [GB] tag to thread title (OP, feel free to remove this note at your discretion)
« Last Edit: Mon, 11 November 2019, 13:30:36 by HoffmanMyster »
Re: M0llY is Here
« Reply #1 on: Thu, 10 October 2019, 16:50:30 »
[Reserved]
Re: M0llY is Here
« Reply #2 on: Fri, 11 October 2019, 20:08:59 »
Approved :thumb:
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: M0llY is Here
« Reply #3 on: Fri, 11 October 2019, 20:18:28 »
Oh ****... Pulling on my heartstrings & wallet! Unfortunately, I doubt I'll be able to make this party.  :-\
Offline donut_sauce
Re: M0llY is Here
« Reply #4 on: Fri, 11 October 2019, 20:30:22 »
This looks great!
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: M0llY is Here
« Reply #5 on: Fri, 11 October 2019, 20:45:32 »
Will you be adding an option to engrave the random badge :cool:
Re: M0llY is Here
« Reply #6 on: Fri, 11 October 2019, 20:51:18 »
Unfortunately engraving is a logistical nightmare haha, we figured it'd be best to leave it blank and if someone wanted to get a custom engraving of it they could!
Offline merkz
Re: M0llY is Here
« Reply #7 on: Fri, 11 October 2019, 21:06:14 »
I pre ordered this as fast as I could! Ordered the black w/ brass. Reeaaaallly excited
Offline portbaron
Re: M0llY is Here
« Reply #8 on: Fri, 11 October 2019, 22:27:47 »
Sigh. Guess I'll get a few.
| LIVING THE 1800 LIFE |
Re: M0llY is Here
« Reply #9 on: Fri, 11 October 2019, 22:31:38 »
Pretty sure I can guess who you are on that comment and your signature :-)
Re: M0llY is Here
« Reply #10 on: Fri, 11 October 2019, 23:15:57 »
hnnng those color options!
Offline donutcat
  • I have ideas. Sometimes they're even good ideas.
    • Donut Cables
Re: M0llY is Here
« Reply #11 on: Sat, 12 October 2019, 00:17:03 »
I'm curious about the choice of ports here. A in and C output seems like a bit of a mixup tbh; C makes plenty of sense for either the input or out put but A for a device input seems fairly odd, especially in the context of people probably needing an A to A ≥3.1 cable for full usage. Perhaps there's something I'm not seeing?
Offline BlindAssassin111
  • I design keyboards and stuff.
    • Viktus
Re: M0llY is Here
« Reply #12 on: Sat, 12 October 2019, 00:42:27 »
It is Type-C for the board to pc, Type-A for plugging in something to charge, a flash drive, a mouse, etc.
Offline donutcat
    • Donut Cables
Re: M0llY is Here
« Reply #13 on: Sat, 12 October 2019, 01:00:43 »
Ok, so maybe it's just me being stupid. But at the same time the way that
...features an integrated USB-C hub....
...- USB-C output via hub...
is worded sounds to me like the hub connection is through the C port? Leaving the A for the board? IDK, maybe it's just me with that late-night small brain.
Offline C³—Ears
Re: M0llY is Here
« Reply #14 on: Sat, 12 October 2019, 01:54:18 »
Great Design!Good luck with the buy,my friend
Re: M0llY is Here
« Reply #15 on: Sat, 12 October 2019, 06:46:50 »
Thank you my friend! Glad to see you on here!
Offline SantiGo
Re: M0llY is Here
« Reply #16 on: Sat, 12 October 2019, 07:08:35 »
nice.... can i Have one with out logo ?
Offline Steezus
  • Keeper of Facts
Re: M0llY is Here
« Reply #17 on: Sat, 12 October 2019, 08:58:34 »
The pink and blue colors look amazing. I really like the design however, not the biggest fan of the logo design on the back. I think that a brass(gold) and aquatic blue option would look amazing. Good luck with the GB!
« Last Edit: Sat, 12 October 2019, 09:00:23 by Steezus »
Offline ImperfectLink
Re: M0llY is Here
« Reply #18 on: Sat, 12 October 2019, 18:47:24 »
Ordered as soon as it opened. This GB deserves the attention.
Offline mydens
Re: M0llY is Here
« Reply #19 on: Sat, 12 October 2019, 18:54:14 »
Damn, why so expensive? Chinese tariffs hurt.
« Last Edit: Sat, 12 October 2019, 18:56:06 by mydens »
Offline KingOfMemes
Re: M0llY is Here
« Reply #20 on: Sat, 12 October 2019, 19:33:55 »
Brass weight + badge, along with the 1800/numpad tax makes that price right on the money imh
Offline Jhambone9160
Re: M0llY is Here
« Reply #21 on: Sat, 12 October 2019, 20:19:18 »
Ordered. E-white w/black, plus pvd brass plate, pvd brass badge, and extra pcb. Looking forward to the e-white with pvd brass plate and badge look. :)
Offline geewiz
Re: M0llY is Here
« Reply #22 on: Mon, 14 October 2019, 09:27:02 »
In for an E-white to go with Extended2048.
Offline Techichi
Re: M0llY is Here
« Reply #23 on: Mon, 14 October 2019, 11:01:16 »
Damn, I have to pass and I am not happy about it. This board is sick!
Offline celta
Re: M0llY is Here
« Reply #24 on: Tue, 15 October 2019, 03:13:23 »
Does e-white stand for egg white? Like the color of the old apple keycaps on AEK's? Or is it a flat pure white?
Offline Lil
    • designedbydark
Re: M0llY is Here
« Reply #25 on: Tue, 15 October 2019, 03:31:29 »
Electrophoresis
Sent from my G8341 using Tapatalk
Offline spakecdk
  • Browns are best
Re: M0llY is Here
« Reply #26 on: Sun, 03 November 2019, 07:55:59 »
Will the blue be the same as ultramarine on Mekanisk's boards? https://i.imgur.com/dERHrnu.jpg
Re: M0llY is Here
« Reply #27 on: Sun, 03 November 2019, 08:37:37 »
It’s the same Pantone color.
Offline HouseOfKeebs
Re: M0llY is Here
« Reply #28 on: Sun, 03 November 2019, 13:18:55 »
How does e-coating compare to anodizing? Is it closer to cerakote?
Offline joerush25
Re: M0llY is Here
« Reply #29 on: Mon, 04 November 2019, 16:24:51 »
Am I the only one that hates that huge flower on the back? Reminds me of those cheesy novelties you get with every MaxKey SA set
Acrylic Tofu w/ Lubed Tealios
    • Viktus
Re: M0llY is Here
« Reply #30 on: Mon, 04 November 2019, 17:09:51 »
e-coating is like a hybrid coating. It is similar to anodizing but not the same process. It leads to a really nice finish though, hard to explain if you haven't had the chance to see it in person.
Offline celta
Re: M0llY is Here
« Reply #31 on: Mon, 04 November 2019, 19:47:13 »
Any chance I could get a recommendation? I've got some nice old AEK alps keycaps which are nearly in perfect condition and I'm wondering whether it would look better with an E-Coat White or an Apple Silver M0lly. Think I could get some second opinions?
Offline Damage
Re: M0llY is Here
« Reply #32 on: Tue, 05 November 2019, 20:34:22 »
Man, I think I burned through my budget getting into the LZ Physix GB, so I don’t think I can get a M0lly. :(
I just wanted to post and say that I think this board will be a classic before you know it if it turns out as presented. Really well done design and detail—and distinctive, too. Best of luck with everything. You deserve huge success.
Offline iaman
Re: M0llY is Here
« Reply #33 on: Tue, 05 November 2019, 21:32:05 »
My gut says the e-white but both would look great!
Offline megaforce
Re: M0llY is Here
« Reply #34 on: Thu, 07 November 2019, 23:56:12 »
cant believe no one posted this
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
Offline Adelscott
Re: M0llY is Here
« Reply #35 on: Fri, 08 November 2019, 01:50:25 »
And that's why...
Please think about ISO users, add a split left shift to your "alice style" keyboards
Offline aeryxz
    • aeboards
Re: [GB] M0llY is Here
« Reply #36 on: Mon, 16 November 2020, 21:07:59 »
N E AVAIL
Offline Cujo96
« Reply #37 on: Tue, 17 November 2020, 18:40:44 »
N E AVAIL
Not if you ordered through a vendor lmaoooooo
Offline Neodeus
« Reply #38 on: Wed, 18 November 2020, 08:14:46 »
Received my M0lly. Looks great. Waiting for non-trash stabs to come in the mail before I can build.
Offline paperassgasket
« Reply #39 on: Thu, 11 March 2021, 00:02:00 »
So... extras Friday huh?
That's nice but what's up with the PC m0lly?
Offline MichelKami
« Reply #40 on: Thu, 11 March 2021, 10:16:25 »
TKC continues to put out heat :thumb:
Offline BananaMan
« Reply #41 on: Wed, 17 March 2021, 16:11:01 »
Do I just use regular 1.8 MM LEDs I'd use for the switches for the indicator LEDs? Sorry if that's a dumb question.
Offline Lyle88
« Reply #42 on: Tue, 22 June 2021, 05:23:26 »
Just out of curiosity, has anyone modified the DXF file for the plate to make it fixed layout? Thinking of getting a PC plate cut and just wondering if anyone knows what sort of time investment a change like that would be..
Sent from my SM-G970F using Tapatalk
Offline andred
« Reply #43 on: Tue, 22 June 2021, 19:37:42 »
I found that 3mm LEDs are perfect.
Offline geewiz
« Reply #44 on: Wed, 23 June 2021, 06:55:30 »
I'm considering adding these LEDs. What's the best way of estimating the required length up from the PCB?
Offline andred
« Reply #45 on: Wed, 23 June 2021, 12:46:24 »
Good question. I've not soldered mine yet, and I am not a soldering pro. I might try to rest the PCB into the case top for soldering so I can slide the LEDs into position and let gravity hold them at the correct length.
If you figure out a good technique let me know!
